Projector self power off
Panasonic PT-AX100U shuts off ~2.5 minutes after turned on.
Requires master switch off and on again to respond to remote.
No error signal of any sort.
  • 5 more comments
  • Anonymous Feb 01, 2008
    Thanks for the attention and input.
    Lamp has little over 500 hours (much lower than the specified lifetime). Made sure the lamp cover screws are tight.
    Maybe I'll give it a try and change the lamp anyway.
    Thanks again.
    Ronen.
  • Anonymous Feb 02, 2008
    It actually seems to work the other way around, which might indicate a thermostat problem.
    It shuts off after 2.5 minutes and the fan continues to cool dowon the unit. However, if I power the thing back up as soon as the fan stops, it works fine (even for long hours). Kind of not getting warm enough in the first place...
    Go figure.
  • Anonymous Feb 26, 2008
    My PT-AX100U has the same problem. Repeatedly changes from green light and working to yellow light with lamp off.
    Started about 14months after purchase. Local shop diagnosed as bad power supply but did not have them do repairs. Still looking for other possible solutions.
  • LEO49 Feb 26, 2008
    Just posted today as guest but wanted to add a fact that I forgot to include.
    The problem started with original bulb and after changing the lamp the problem still continued. New bulb has maybe 400 hours on it and still having the problem.
    Wanted to post a solution to this problem. Panasonic tech support says the iris is the problem. Upon researching this tidbit, I found this site:
    http://www.avsforum.com/avs-vb/showthrea...
    There is much info here on iris problems. I fixed mine with a q-tip with WD40 to lightly lube the iris mechanism.
    Hope this helps someone.....
  • Pastor Keith Apr 28, 2008
    Sanyo PLC-XU48 used in church worship center. Attempts to powers up, light goes green, but then begins to blink red and enter into shut-off mode. No other warning lights illumined.
  • Anonymous May 04, 2009
    My projector has the same problem. About 900 hours on the second bulb. It shuts off repeatedly. I have been living with restarting it until it stays lit, but now it no matter how many times I restart it, it goes out.
    New Friend:
  • 16 Answers
Have you tried looking to see if the lamp has expired? Or could simply be cause by a faulty power supply unit?
Posted on Feb 01, 2008
    MMM yea I hate the thought of having to replace bulbs lol, have you checked the fan? Because if its going for 2.5 min and the fan is not working properly, the thermostat will shut the system down so it wont overheat.
6ya staff
SOURCE:
Projector powers up, after 2 minutes image goes away, projector goes into cool down, then shuts off. why?
FAULT: lamp of your projector is faulty.
Experience: when lamp life is near to end and environment temperature is too low you are facing the same problem and if you are facing this problem in normal temperature then also lamp is faulty.
Sulotion: Just replace the projector lamp
Jan 07, 2011 | Panasonic PT-AX100U-EC DLP Projector
Shuts off after approximately 2 minutes
I have exact same problem. According to the manual its time to replace the bulb. But when I check the runtime on the bulb it shows 326 H. I am not certain if this is the remaing hours on the bulb or the usage to date hours.
I would appreciate anyone commenting and recommending a solution.
Jun 13, 2010 | Panasonic PT-AX100U-EC DLP Projector
PT-AX100U-EC DLP Projector: I replaced the bulb on the Panasonic PT-F1000NT pr...
1.Press the MENU button to display the menu screen, and
then press the F or G button to select the OPTION menu.
2. Press the ENTER button, and then press the F or G button
to select LAMP RUNTIME.
3. Press and hold the ENTER button for approximately
3 seconds. The confirmation screen, “LAMP RUNTIME
RESET.
” is displayed and select OK.
4. Turn off the power.
�� This will reset the cumulative usage time for the lamp
unit to zero.
***Here you go and best of luck!***
May 07, 2010 | Panasonic PT-AX100U-EC DLP Projector
My PT-AX100u will not turn on. The lamp is new, I have done the iris fix, which didn't help. When I turn it on, the green light flashes and after 30 seconds, it goes into shutdown mode and then one red...
Yes please call me Just went thru the same issue with my customers projector it involves more then typing can fulfill. Thanks Jordan Thomas
910 538 2754
PORT CITY AV
Nov 22, 2009 | Panasonic PT-AX100U-EC DLP Projector
Panasonic projector keeps shutting off
Try this utube link. I did it and it solved the problem in about 30 seconds! Don't spend any money or send out your unit. This does it.
http://www.youtube.com/watch?v=6jGwB05_gdk
May 27, 2009 | Panasonic PT-AX100U-EC DLP Projector
5 minute fix guaranteed
worked for me
Apr 05, 2009 | Panasonic PT-AX100U-EC DLP Projector
Panasonic projector PT-AX100U
lamp blown? if not try this first
worked for me
Oct 09, 2008 | Panasonic PT-AX100U-EC DLP Projector
Help me!!!!
Hello folks! I bought my unit on 11/2006. After 1532 lamp hours on eco-mode, my unit would start shutting off after just 2-3 minutes. Same problems you guys are having. Based on the comments I've received from the TECH guy where I purchased the unit, it appears that these units have IRIS problems. Here's how you can tell if its an IRIS problem...according to the TECH guy:
1. Get the unit powered up as usual.
2. Wait until its projecting enough light to see a menu on the screen.
3. Using the remote control, PRESS the "POWER" button again to see the power off confirmation screen, then PRESS the ARROW keys in the following order: RIGHT, UP, DOWN, UP, DOWN, then PRESS ENTER.
4. The EXT OPTION menu should then be displayed.
5. SELECT the "SELF CHECK" option using the arrow keys.
6. Look for the word "IRIS. If that word or any word on that line appears in "RED" color, then the IRIS is faulty and needs to be replaced.
I just called Panasonic's Service dept. and they gave me a CASE NUMBER and asked me to FAX my original INVOICE to them. She told me they are going to review my claim and see if they can provide assistance or whatever. Apparently...Panasonic knows of this problem according to the TECH guy at the place where I bought my unit in late 2006. Good luck! Steve 717-891-2062
Dec 15, 2007 | Panasonic PT-AE100 Multimedia Projector
Open Questions:
1,256 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
