Question about Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvd-rw dvr 112d
I have just taken an old dvd burner out of my pc and replaced with the pioneer, however the one which I removed had 3 sets of pins an the back :::
and the pioneer has 5 sets :::::
The one which I removed had the top and bottom pins on the left covered with the plastic connector, where shoul it be on the pioneer as it has 5 sets of pins
Many thanks
  • 29 Answers
Look for the mark at the top, MA for master, SL - slave, CS - cable select, these three are main connection for IDE designation using the plastic jumper, just follow where it is in your pioneer.
Posted on Jan 19, 2008
6ya staff
SOURCE:
Pioneer DVR-112D refuses to read CDs?
This unit has alot of issue with CD reading and writing probably its a problem with the lens of this player, so since its still new better take it to the store and have it replace..
Hope that helps........
Aug 10, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
PIONEER DVD-RW DVR-112D won't burn discs. G4, OS 10.4.11
So the driver is either 'malfunctioning' or it's broken...do you know what revision firmware the drive is using? Your disk authoring software may tell you this. The latest version is 1.22 which you can get by Googling PIONEER DVD-RW DVR-112D firmware. Or go to the Pioneer website. I do not know how to upgrade the firmware for the recorder in MAC Land, in PC Land the firmware update is a simple executable file.
If you are running this version you can try to reflash it. Have you tried another brand of DVD disc? Some discs are less compatible than others. Try another brand of DVD
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_3424/426554181POV_DVR-112D.pdf
Oct 13, 2009 | Pioneer DVR-112D Burner
Cannot copy files from computer to Pioneer DVD-RW DVR-112D
Try using another burner use Nero burning ROM or Roxio Creator DE.
Nov 17, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
My dvd burner is missing the drivers
hi. if you will go to...
http://wwwbsc.pioneer.co.jp/product-e/ibs/device_e/dev00001r_e.html
scroll down the page to dvr 112 series firmware the last download for that section should be your driver.
hope this solves your problem. let us know.
Oct 02, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
PIONEER DVD-RW DVR-112D problem
have you tried cleaning the lens? i also had this experience with my dvd rom and what i did, was cleaned the lens.
tell us what happen after you clean it ok.
Jan 14, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer dvr-112D won't read CDs anymore
There would be a problem with cd reader lens
sou need to change it from the company if its in a warrenty or get it repaired from a person who is in to Chip Level Repairing
Jan 05, 2008 | Pioneer DVR-112D DVD RW Dual Layer Burner
Installed new Pioneer DVR-112D
 Are you using an 80-conductor type ribbon cable? The new drive requires 80-conductor cable. Plus, you may need to switch the jumper on the back of the DVR drive to CS.
I just found your motherboard specs
http://h10025.www1.hp.com/ewfrf/wc/document?product=396434&lang=en&lc=en&cc=us&dlc=en&docname=c00063272
It uses SATA and Ultra DMA (80-conductor).
Is the jumper set to master?? You may need to pull the jumper off and see if the DVR drive works with it off.
Oct 29, 2007 | BenQ CRW 4012A (99.B9712.036) CD-RW Burner
Check with a NEW PC - DVD Cable, if it is NOT that.. then I am sorry, but I reckon it's gone faulty somehow? Especially if it causes the PC to not boot. This is a common occurrence, even for NEW units..
Sep 02, 2007 | Pioneer DVR-112D DVD RW Dual Layer Burner
Pioneer DVR-112D DVD RW Dual Layer Burner Logo
201 people viewed this question
Top Pioneer Computers & Internet Experts
Ekse
Damen Wong
Damen Wong
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
