Failed lid switch on Maytag washing machine
I have a Maytag model #MAV6057AWW and I believe the lid switch has failed. I have removed the lid switch but I have no way of knowing if the switch is indeed bad and do not own any type of continuity tester but was wanting to use jumper wires on the plug from the wiring harness to the switch to bypass the switch. There are four labeled contact: Neutral; Line; Motor; Machine, on the switch contact (male side of plug). What would I jump on the corresponding side of the female side of (wiring harness) to safely bypass this switch.
The reason I believe it is the lid switch is because the machine failed to operate immediately after the lid being dropped closed.
vest6
  • 196 Answers
SOURCE: installing washing machine motor P/N 35-5022, need wiring schematic to hook up to machine internals
The black or brown connection block on the motor should be color coded to match the harness. If not you will need to remove the control panel and find the service guide sheet. This will give you the wiring diagram for the whole machine.
Posted on Jan 13, 2008
  • 177 Answers
Is there a white or black connector that clips on the motor switch? it should be an easy unplug and plug the new motor in.
I dont of any Manufacturer that uses single wire connectors any more.
Are you sure you got the correct motor?
Posted on May 28, 2008
  • 1028 Answers
SOURCE: Kenmore washer
the switch can be bypassed BUT if you do be careful it is after all a safety device to prtect those who "know no better than stick their hand in a wash tub spinning over 700 rpm" the switch may be on the left side just behind left lid hinge on some it was even under right side and others on right edge of lid opening either the screw holes are broke off or lever is not pressing in to activate switch..1 other thing ck screws in hinges if left side is loose have seen it fail to engage switch lever
Posted on Aug 07, 2008
SearsTechToo
  • 261 Answers
SOURCE: GE Washing Machine Replacement Motor - Capacitor? Relay? Schematic?
The new units have all of your schematics, capacitor and a higher price for a reason. With GE I avoid used parts because there is so much electronics you don't want to fry. The wire harness leads match the old and there should not be an extra wire, were would it go if there is not a receptacle for it?
I looked up your unit and the motor replacement is WH20X10009 for the model you quoted. As of now GE is has updated this to model wh20x10006 for around 263 dollars.
Posted on Oct 03, 2008
futureloginn
  • 734 Answers
SOURCE: Kenmore Top loading washing machne F4 error. (110.20052994)
It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
Maytag Bravos wash machine agitates during wash cycle, and drains, but does not spin
hi JJ.
Most Frequent Causes for Washer won't spin. The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity
this link might help you out as well.
maytag washing machine not spinning Google Search
Dec 11, 2017 | Maytag Washing Machines
Ny maytag washer will not turn on. Was working great and next load won't turn on.
You have not shared the model or age of the machine, but I can hazard a guess that the lid switch has failed.
If you can raise the lid, you should gain access to the lid switch, and they are not too expensive to buy, so I would try that first.
If some one who is REALLY good with electrical stuff wants to save even that cost, they could bypass the lid switch first, and see if the machine will work that way.
That might tell you if the machine has completely failed.
God bless your efforts.
May 24, 2016 | Maytag Washing Machines
Maytag mav6057aww makes loud noise while spinning
Is it a scraping sound or more of a rumbling sound? If it's scraping check for screws, nails, necklaces, etc., in the drain holes of the basket. If rumbling sound your tub bearings may be failing.
Jan 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Machine filled with water then just began beeping. Never started to wash the clothes. When turned off and then on again, it makes a buzzing noise and nothing happens.
If your buzzing noise stops after a few seconds, it could be the motor failing to start. If it sounds like a signal buzzer, it could be indicating the lid open, or a failed lid switch.
May 18, 2011 | Maytag Bravos MTW6600T Top Load Washer
Model # lat8826aae my washer doesnt work when i close the top load cover
open timer console and replace fuse can get from any hardware store
Jan 27, 2011 | Maytag Washing Machines
Fills with Water but, that is it
If a machine spins and drains, but won't agitate, that sounds like a timer control problem. Wires can come loose or burn up, but that's not as common as a failed contact. If the machine won't agitate or spin, that could be a lid switch problem, which is real easy to fix.
Mar 25, 2009 | Maytag LAT3600A Top Load Washer
How do you install a thrust bearing on maytag model MAV6057AWW
lean washer back remove dust cover remove c clip holding pulley on ..good luck getting back together ..c clip can be difficult due to lack of clearance ..be sure you put bottom washer back on
Jul 22, 2008 | Maytag Washing Machines
Maytag MAV6057AWW
There are two clips under the front of the lid that have you have to push in while lifting the lid. Then you can get to the two screws behind the front panel.
Mar 30, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Top Load Washer # MAV6057AWW
I have the maytag MAV6057AWW. I had the same problem and today i am discovering that others are having the same problem i was. It first started with the no agitation after the rinse cycle. I emptied out the water and clothes etc. I lifted it, took it apart practically and discovered all was ok. I couldnt figure it out because after putting it back together it worked properly. After a few days it didnt agitate for the wash cycle after filling up with water. I was confused. But then I got pissed of and I slammed the lid shut and it began to work.
It was the switch. I havent replaced the switch, but i have learned to cope with the fact that i have to open and close the lid a 2 or 3 times times before it goes into the cycle.
When it doesn't agitate, its not a mechanical problem, but a safety switch that is failing to close. So either replace your switch or play with the lid a bit.
Nov 27, 2006 | Maytag Atlantis MAV7551 Top Load Washer
Washing Machines Logo
132 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
