Question about ASUS P5P800S Motherboard
Motherboard has power and fans turn but nothing else will
I have an asus p5p800s and evrything was working fine until i shut the computer down one day and turn it back on. The computer will not boot. The motherboard has power and the fans will turn on. Nothing else will come on. The hard drive will not turn on, there is no beeps at power on. There is no video. I have taken the compuetr apart and I still get nothing. I have tested the power supply and it is fine. If i disconnect the hard drive from the motherboard but leave the power connecter on the motherboard I can here turn on and the same thing with the DVD drive. If the dvd drive is conneted to the motherboard the tray will not open but when i dscoonect but leave the power connector in the tray will open. I had this problem a few weeks ago and after disconnecting everything from the computer and then reinstalling it worked and I do not know what I did to get it to work but it only lasted a few day and ten stopped again. This time I can not get to start working. Please let me know if there is any settings on the motherboard that would cause this. Ps I also cleared the CMOS after this happened and it did nothing.
You may have a bad ribbon to you dvd drive.
Posted on Jan 13, 2008
"I tried to install another internal HDD + another 256 RAM (both of them are used) to my computer, operating XP with an ASUS P5P800S motherboard. When I ran the system, the new device was found by the sys....
The hard drive would not show up until you initialize it in the control panel. With everything off the motherboard you should get some post beep. Put the ram back and try again, the next thing to install is the video to see if there is any indication of function. Keep adding things back. If there is no post beep with just the motherboard then you need to test the PSU and if it is OK then CPU or motherboard is bad.
Sep 26, 2014 | ASUS P5p800s Motherboard Intel 848p Lga...
I have an AsusP5P 800 mother board and the unit won't power on.
I had a very similar issue like this, how many RAM modules do you have installed? if you have 2 DIMM installed try removing the memory on at at time(try interchanging the RAMS), see if turns on. if not might be the motherboard itself thats possibly defective.
Feb 14, 2010 | ASUS P5P800S Motherboard
Asus mother board sound driver
Go to the Asus website, www.asus.com. Click on the support link. Lookup your specific board model # and select the operating system you are running. A list of all available files will appear. Scroll down until you find the sound driver. Click on it and download and install. Follow the onscreen instructions and you should be all set. Hope this helps.
Sep 19, 2009 | ASUS P5P800S Motherboard
No Display
hi....good day...>try to replace the ATX power supply...< thanks and good luck...^_^
May 29, 2009 | ASUS M2A-VM (0610839149438) Motherboard
MOTHERBOARD FAILS TO CONNECT TO HARD DRIVES
Check to make sure that your Jumpers are set to the Factory Settings (wether they are opened or closed)
Mar 13, 2009 | ASUS P5P800S Motherboard
Asus p5p800s
It could be that you have a damaged power supply which took out your motherboard. When turning it on, what beeps did it make?
Sep 17, 2008 | ASUS P5P800S Motherboard
Power shutting down
check your power-save settings they could be turning the computer off. it could also be a bad chipset that is getting shorted or a bad fan that is causing the pc to overheat and turn off. hope this helps.
Aug 14, 2008 | ASUS Intel 850 Chipset P4T-E (P4T-E/WOA)...
Asus a8n sli deluxe not powering up
do you have 2 sticks of ram in the pc?
if so try it with one in and do this with both
as in boot it with a single ram stick and try to determine if its a faulty ram stick
also if you can try another power sup unit
please let me know how you get on
Mar 22, 2008 | ASUS A8N-SLI Motherboard
ASUS P5P800S Motherboard Logo
136 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
