Question about WYSE Winterm 9455XL Network Terminal
Jumper settings to bypass password
I bought a this terminal, and the bios is password protected. i need to clear the password
Default passsword is Fireport (note: case sensitive)
To get set password to default unplug power, open case and find jumper next to battery (mounted vertically) on motherboard.
Put jumper to other position. Plug in power, wait ten or so seconds. Unplug power, put jumper back, and voila.
Posted on Aug 30, 2008
  • 2,427 Answers
Unplug your system
Open up the computer,
take the lithium battery off the main board(its the size of a
nickle and silver)
press the power button 7 times
put the battery back in
boot the system
enter the setup and loat the optimised defaults
save and exit.
Posted on Jan 19, 2008
Is asking for password when coms on forgot it
There is usually a jumper on the motherboard that you can remove to clear BIOS settings including password if the password is a request of the BIOS. If it is a Windows or other operating system that is asking for password you are probably going to have to reload operating system. Look on motherboard for small jumper with the word BIOS imprinted next to it. Make sure power is off, remove jumper and restart pc. When BIOS comes up do not set password protection. Shut pc down, replace jumper and your bios settings should be fine. Good luck
Feb 24, 2014 | E-Machines Computers & Internet
I have a toshiba portege m100 with a bios password set that i need to bypass. toshiba want 80 quid just to look at it. some sorces say short clr1 jumper but i cant find it on my machine. please help.
Most DESKTOP computers have a jumper to "clear CMOS settings",
but most NOTEBOOK computers do NOT have that jumper.
The password exists to protect the owner of the computer, should a thief be trying to use the computer.
You probably can remove the disk-drive, and copy the files onto a new computer, if you don't want to pay TOSHIBA to bypass the password.
Feb 26, 2011 | Toshiba Portege M100 Notebook
How to change system bios password
You can reset bios password with 2 method.
(1) open cpu cabinet cover then find motherboard .Pull cmos cell from motherboard for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherboard named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks for using FixYa.
Feb 12, 2010 | Mirra M-120 (MIRRAPERSONALSERVERM120)
Forgot BIOS password
Question: How to clear an unknown BIOS password.
Answer: If you have mistakenly forgot or lost your BIOS password or you receive a password at boot that you do not know, you will need to clear the BIOS password by one of the below methods.
Precaution: When inside the computer please be sure of the potential of ESD.
  • Try using generic BIOS passwords. A complete listing of these passwords can be found on document CH000451.
  • There are utilities designed to help bypass BIOS passwords. An example of a great utility to decrypt / bypass BIOS passwords is the PC BIOS Security and Maintenance toolkit, which is available by clicking here.
  • On the computer motherboard locate the BIOS clear / password jumper or dipswitch and change its position. Once this jumper has been changed, turn on the computer and the password should be cleared. Once cleared, turn the computer off and return the jumper or dipswitch to its original position.
The location of the jumpers or dipswitches may vary; however, here are general locations where these jumpers / dipswitch may be located.
  1. On the edge of the motherboard - Most jumpers are located on the side of the motherboard for easy accessibility, verify by looking at all visible edges of the motherboard.
  2. By the CMOS battery - Some manufactures will place the jumper to clear the CMOS / BIOS password by the actual CMOS battery.
  3. By the processor - Some manufactures will place the jumpers by the processor of the computer. However, note that in some cases these jumpers will be to change the processor and not the password.
  4. Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment.
  5. Other visible location - While it is possible that the jumpers / dipswitches may not be in a visible location, most manufactures try to make things easier by placing the jumpers / dipswitches in another visible location.
Additionally, when looking for the jumper / dipswitch the label of that switch can be anything; however, in most cases will be labeled CLEAR - CLEAR CMOS - JCMOS1 - CLR - CLRPWD - PASSWD - PASSWORD - PWD.
  • On the computer motherboard locate and remove the CMOS battery for at least 10 minutes allowing the computer to lose its information. Note: this will not work on all computers.
  • If your manufacturer has a bypass password this can be entered and allow you access to the BIOS and/or computer. Because of the security risk of a bypass password, generally only older computers will have this option. In addition, it is likely that this information will only be able to be obtained from the computer, motherboard or BIOS manufacturer.
  • On the computer motherboard locate the CMOS solder beads and jump the solder beads to clear the password. The identification and location of these solder beads can vary and if not available in computer documentation is generally only obtainable through the computer manufacturer.
If one of the above solutions do not clear the password or you are unable to locate the jumpers or solder beads, it is recommended you contact the computer manufacturer or motherboard manufacturer for the steps on clearing the computer password.
Sep 19, 2009 | HP Compaq 6710b Notebook
Forgot bios password
does your laptop have a 25 pin serial port?
Jun 27, 2009 | Toshiba (P000191710) for T4850 Sound Card
Is there a backdoor bios password for a Toshiba laptop (model #1805-S253)? A previous employee password-protected the bios but "neglected" to tell us what it is.
The Backdoor passwords are not determined by the laptop manufacturer - the backdoor passwords depend on the manufacturer of the bios itself. Is it an Award biosor an AMI bios etc?
Award BIOS backdoor passwords: ALFAROME BIOSTAR KDD ZAAADA ALLy CONCAT Lkwpeter ZBAAACA aLLy CONDO LKWPETER ZJAAADC aLLY Condo PINT 01322222 ALLY d8on pint 589589 aPAf djonet SER 589721 _award HLT SKY_FOX 595595 AWARD_SW J64 SYXZ 598598 AWARD?SW J256 syxz AWARD SW J262 shift + syxz AWARD PW j332 TTPTHA AWKWARD j322 awkward
AMI BIOS Backdoor Passwords: AMI BIOS PASSWORD HEWITT RAND AMI?SW AMI_SW LKWPETER CONDO
Phoenix BIOS Backdoor Passwords: phoenix PHOENIX CMOS BIOS
Misc. Common Passwords ALFAROME BIOSTAR biostar biosstar CMOS cmos LKWPETER lkwpeter setup SETUP Syxz Wodj
Other BIOS Passwords by Manufacturer Manufacturer Password VOBIS & IBM merlin Dell Dell Biostar Biostar Compaq Compaq Enox xo11nE Epox central Freetech Posterie IWill iwill Jetway spooml Packard Bell bell9 QDI QDI Siemens SKY_FOX TMC BIGO Toshiba Toshiba
Toshiba BIOS Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
Jan 23, 2009 | Toshiba Satellite 1805-S253 Notebook
A friend install my mother computer. how to jumper
Set the jumper to recovery or to clear
CMOS Jumper
1-2 - Mostly normal
2-3 - Clear
0-0-0 Recovery no jumper
Its a basic conscept it can change according to your bios manual you follow - Trace the cmos jumper exactly dont short any other jumper
Jul 25, 2008 | EliteGroup Computers & Internet
I forget my bios password
Answer: If you have mistakenly forgot or lost your BIOS password or you receive a password at boot that you do not know, you will need to clear the BIOS password by one of the below methods. Precaution: When inside the computer please be sure of the potential of ESD.
Additionally, when looking for the jumper / dipswitch the label of that switch can be anything; however, in most cases will be labeled CLEAR - CLEAR CMOS - CLR - CLRPWD - PASSWD - PASSWORD - PWD.
Good Luck, this should get ya back on line/Please dont for get to Vote.Thank You.
Dec 15, 2007 | HP OmniBook XE3 Notebook
WYSE Winterm 9455XL Network Terminal Logo
1,186 people viewed this question
Top WYSE Computers & Internet Experts
Nicholas Bannister
Sunday Ojelabi
Sunday Ojelabi
Are you a WYSE Computer and Internet Expert? Answer questions, earn points and help others
