Question about Onkyo TX-SR803 Receiver
Onkyo integra a-809 amplifier
Sometimes this amplifier will switch by itself from cd to tv to etc., etc. without being directed to. It will play uninterrupted at times for and hour or so and then "go crazy". Other times it will only play a few minutes before switching from input to input. We think we have eliminated potential problems - such as over heating (it is not) and have pulled some inputs to see if they were a problem - they weren't. Do you have any ideas?
  • 1 more comment
  • midipiano Jan 16, 2008
    We think we fixed the problem. Our Onkyo amp is connected to an Onkyo CD player. There is a small blue cord marked R-1 that hooks the two together so that the amp's remote will also work the cd player. We determined that the infrared signals were feeding back off each other. Taped a piece of paper over one of the infrared sensors and now the amp is behaving!!
  • Anonymous Jun 03, 2008
    I have the same exact problem with my A-809
    YOU HAVE RESOLVED THE PROBLEM?
  • happythecat Dec 31, 2008
    Same problem here. How do you get at the input switch on the A-809? I opened up the amp and could not find a way to get at the back of the switch to DeOxit it. Any suggestions?
    Welcome Back:
    Visited the website for 2 consecutive days.
I recently had an extended episode solving a distortion issue with my Onkyo A-807. I also asked my repairman about the spontaneous switching of the output selector. He told me the output is managed by a motor driven selector located in the back of the unit, not where the dial is, so I don't expect cleaning the contacts at the knob to help. The idea of protecting the remote cable, if you use it, seems more plausible. The contacts at the knob are very difficult to access, and according to my repairman, the motor is in a sealed compartment - so I think remedies other than protecting the remote cable will be difficult.
Just FYI, my distortion problem was from the record selector position "Source". It goes away when the selector is in the "Off" position, or when I disconnect the cable going from my CD recorder to the DAT "REC" jack in the back. I spent a lot of time and money figuring this out. I suspect it is an issue with more than just my unit. If you don't have anything plugged into the DAT jack, or leave the record source on off , you'll never notice this and enjoy a happier listening experience.
Posted on Apr 24, 2010
  • babyrea Apr 12, 2016
    Update: There is a post on Youtube currently where the fellow does what JohnShultz below recommends. I did this and have enjoyed a couple of weeks of no auto-switching. I had more trouble removing the knob than he did, even using the rubber band helper. When I put the knob back on, I didn't push it in too hard. Perhaps the knob being pushed in over time contributed to the problem or maybe it just needed cleaning. I used a Radio Shack product on mine.
Use Deoxit on the switch. It is a contact cleaner available at Radio Shack and Fry's. Exercise the knob well. It worked for me on my newly acquired Onkyo A809.
Posted on Jul 30, 2008
  • 3 Answers
Disable wire from back of the selector motor which has four wire ribbon (Jumper 211) for the A809. Something wrong with logic chip which control the motor. After that it works fine on my A809.Hope this will help.
Posted on Sep 21, 2010
I have had this switching problem on my Onky Amplifier Integra A-807 with only 5 years of usage. Apart from that the tape deck, Onkyo TA-207 would start recording on a protected tape at odd times once the amplifier switches on.
So, sorry that I have not a solution for this, but I wonder, is not Onkyo a good HI-FI brand?
Posted on Dec 27, 2009
I had this problem with the Onkyo A809 just rec'd from ebay. I used Deoxit contact cleaner on the input selector switch and exercised the control well. The problem disappeared. Deoxit is sold at Radio Shack.
I have the same exact problem with my A-809. Started today. The input switch gotes nuts. Would love to see some ideas.
Posted on Jan 16, 2008
  • theruleris
    theruleris Apr 01, 2013
    Had the same problem, it is the source selection rotary switch itself. I de-soldered it completly and the problem went away. I can only switch the input source by remot control. Not really a problem for me. BTW I found it not so hard to reach, carefull with unplugging connectors though, pry them loose don't pull.
Onkyo tx-nr616
harder to do but you can probably still use the display on the unit.
I am unfamiliar with the onkyos but am often setting up integras which are basically onkyos.
Find the setup button on the face of the receiver. It might be called different things but basically you will call up the settings and use the arrows - enter - and return to navigate in and out of the menu options.
Integras have that will allow you to;
configure connected speakers
- sub yes-no
- center yes - no
- rear surround yes-no
- speaker size small-large
input config (mapping audio, video connections to the input names)
ex:
- "Cbl/Sat" -> HDMI 1 - 4
- "BD/DVD" -> HDMI 1 - 4
etc.
You'll get the hang of it.
OR - do you have a small TV with a composite video connection?
I carry around a portable Coby battery powered monitor that has a composite video input for these types of problems. Composite video is always active.
May 26, 2014 | Onkyo TX-NR616
Onkyo Amplifiers & Preamps
Hi ,try cleaning your volume control ,here is a video so you can DIY or contact your local service. :)
Dec 17, 2013 | Onkyo Audio Players & Recorders
The source selector of my onkyo A 807 runs away
HI try this video it worked for me. :)
http://www.youtube.com/watch?v=0Xfm-9jCmjE
Apr 09, 2013 | Onkyo Integra Intergrated Stereo Amplifier...
Cant get tv audio through receiver directly (without satallite, Game, DVD connection)
If your TV doesn't support audio return channel (ARC, which is your TV audio routed back to the receiver through the same HDMI cable), you then need to connect your television audio-out to your Onkyo TV audio input, using a digital cable or an analog one according to the connections on the back of your TV. If you use a digital connection (optical or coaxial), make sure you have the proper digital port assigned to TV on the onkyo I/O assign menu/digital inputs.
In case your TV does support ARC, you need to activate it in the Onkyo's hardware/HDMI setup menu, either by turning on HDMI control (tv or receiver control each other via cable), or by turning ARC on (you'd probably need to activate ARC on your TV as well).
Hope this help,
M G
Jan 03, 2013 | Onkyo TX-NR609
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
Integra DPS 8.5
The Integra DPC-8.5 changer (as opposed to the DPS-8.3 single-play unit -- not sure which you have, as you mention DPS-8.5, a non-existent model) and most of the integra line of players, will sometimes be thrown into brainlock by out-of-step shutoffs. They will usually respond to the Integra/Onkyo instruction manual's directions to turn it off (you're already done that), then unplug the power cord from the back of the machine, wait a few seconds (make it 30 to be safe), then plug it back in and turn it on via the standby switch. The screen should display its welcome message, cycle through startup, and being working again. It is very much like rebooting a PC. In fact there is little difference.
If this doesn't work then something has gone wrong inside and probably has nothing to do with your shutdown method on the way out the door. These things do happen. Hopefully by now you've already figured this out. If not, give it a try. It usually works.
Jul 04, 2008 | Integra DPS-8.3 DVD Player
Onkyo Integra A-809 input selector switching by itself
This is not an IR problem. Could be just loose connectors and dry joints. You'll need to open the unit and visual inspection of the PCB and connector for abnormality.
Good luck.
Jan 20, 2008 | Audio Players & Recorders
Onkyo TX-SR803 Receiver Logo
3,946 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
