Question about Compaq Armada E500 Notebook
OK this is whats wrong
OK my Computer isn't an E5OO but it is an ARMADA V300 and whenever I power it on The Compaq Logo appears but when Its gets to the Windows ME logo It goes stright to the windows Startup Menu and it gives 4 choices
1:Normal Mode
2:Logged(/BOOTLOG . TXT)
3:Safe Mode
4:Step-by-step confirmation
It also says that there was a registry/configuration error an that I should Use SCANREG to correct the
No matter what choice i pick it just goes to my Desktop Screen but none of my programs load up its just a blank screen and the only thig I can do that works is CTRL+ALT+DEL and the Task manager is also Blank....What should I do I just dont Understand Can someone Pleeeeeeez help me!??!!!
  • kam22 Jan 15, 2008
    The right click options didnt even pop up.... Oh Yeah and i forgot to say that before it goes blank it asksme if I want to Install new hardware but the hardware is of a CD that may have caused the probleM. Im not sure hat the name of the CD was but whenever I put the CD in It started acting funny so I shut it off ...and whenever I power it on The Compaq Logo appears but when Its gets to the Windows ME logo It goes stright to the windows Startup Menu and it gives 4 choices
    1:Normal Mode
    3:Safe Mode
  • 89 Answers
So, you get no icons? Have you tried to do aright-click on the desktop and select 'recover desktop' or something of that nature?
Posted on Jan 14, 2008
  • Anonymous Jan 15, 2008
    If you are getting the Normal Mode, Safer Mode, etc. choices, can you choose Safe Mode, then log in and attempt to perform a scandisk. Here's an expalnation of scanreg.exe: http://support.microsoft.com/kb/183887
    You may also want to try to see if you can reinstall the video (adapter or card) drivers.
6ya staff
SOURCE:
Compaq armada v300 will not power up. power cable ok, no battery
Hi
Thank you for your query
If the power cable is ok and still there is no power, there is a hardware fault with the motherboard or the DC jack
I would recommned that the laptop be booked in for repair at a reputable PC shop
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
Feb 17, 2010 | Compaq Armada V300 (177748-001)...
My armada e5oo is coming as far as telling me that 'windows is starting up'. After that, it is simply locking up in that position. I don't seem to be able to get response to any key after that. The only...
Hello.
Thank you very much for your prompt response. I have handed the machine and the problem to some on else.So I am not dealing with it any more.
Thank you again for the prompt response.
Oct 11, 2009 | Compaq Armada E500 Notebook
Compaq armada e5oo laptop...right side of screen looses brightnes
It sounds like the inverter on your LCD screen is going bad on you.  You can sometimes find inverters for cheap on eBay, but you will need to get the part number from Compaq to be sure that you are buying the correct thing, and I usually say not to buy any that ship from Asia even though they may be cheaper, as many times they are knock offs.
Mar 30, 2009 | Compaq Armada E500 Notebook
Compaq armada v300
If you have a router on your broadband, you need a RJ45 network cable - right next to the modem port on your laptop is a network port - this will use the correct cables you need to connect to your router.
If you don't have a router but only a broadband modem, just connect it to the USB port on your laptop, install the software and you should be good to go.
Feb 08, 2009 | Compaq Armada E500 Notebook
Compaq Armada V300
Sounds as if the board is starting to fail. Try what I've listed bellow. If that doesn't work then try a bios flash. If it's still giving you the same problem after trying all of these, then I'm afraid you'll have to replace the motherboard.
Try removing the jumper from the harddrive, then restart
or
Take the jumper off restart, shut down, then put it back on again
or
Remove the CMOS battery from system board and boot once . After booting shutdown your system and insert the battery back, start your system and press F1 next time it won't ask you to press F1. Reset your BIOS after that (time,date,etc.)
Please let me know.
Jun 26, 2008 | Compaq Computers & Internet
Compaq Armada M300 Loose Display Screen
There is no adjustment on the m300 v300 m700 v700. These hinges will have to be replaced. I do have a set from an v300 am not sure if they are compatible but you can have them if you want.
Mar 18, 2008 | Compaq ARMADA M300 11.3" Flat Panel LCD...
Memory
you should first download this manual. i believe you need to remove the keyboard....which is fairly simple if you have a small screwdriver.
http://www.eserviceinfo.com/index.php?what=search2&searchstring=Compaq+Armada+E500+and+Armada+V300
Jan 22, 2008 | Compaq Armada E500 Notebook
My compaq armada 3500 wont boot up or only shows the welcome compaq logo
I think that has to do with the BIOS if it cant boot compeletly. Try pressing the key indicated to enter into SETUP if you cant just try and look for a jumper on the motherboard that is written CMOS it may be a button or something.
Jul 18, 2007 | Compaq Armada 3500 Notebook
Compaq Armada E500 Notebook Logo
91 people viewed this question
Top Compaq Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
