Connecting plugs on DVD 5.1 surround sound
I am trying to synch the speakers, etc... on the Bush DVDAV14K 5.1 surround sound DVD player without the users manual. Do you know of an online access to this user manual or can you help?
  • pwadaly Nov 15, 2008
    I have the same problem... has anyone managed to solve it?
snakehead
  • 1074 Answers
SOURCE: Koss KS4125 user manual download
go to www.service-manual.net they will have your manual cost about $11.99 US.good luck.
Posted on May 14, 2007
heyvakoo1
SOURCE: Quick Start Guide for Durabrand DVD 1002
hi
here is the website for the manual
http://www.lenoxx.com/2005/manuals/DVD1002/IB-DVD1002(AT)-WM-E-032706-.pdf
Posted on Oct 25, 2007
welcomejee
  • 10594 Answers
SOURCE: user manual
Download required user manual form LG Support You can view manual if you install DJVU viewer in PC as manual is not in pdf file.
Posted on Mar 03, 2009
chain saw
  • 94 Answers
SOURCE: Purchased without a manual, LOGIK LDVR78 DVD Recorder
E-BAY OR LOGIK WEB SITE
Posted on Mar 14, 2009
Vanguardian
  • 106 Answers
SOURCE: i have a targa vcr/dvd player and i dont have the user manual
This .PDF should be the manual you're looking for.
http://www.service.targa.co.uk/dokumente/DPV-5400x_manual_EN.pdf
Posted on Aug 28, 2009
My question is. . Is it possible to use a philips HTS3450 surround sound system without the blueray player?
Depends on how you intend to hook it up otherwise you will get no sound from the speakers if you delete the DVD player from the circuit. The speakers require a power source and this is provided via the DVD player.
You cannot connect those speakers up to an amplifier or an AV Receiver because the speaker connections are not compatible. The connections to the speaker wire where they plug into the DVD player would have to be changed because there needs to be a left and right wiring connection for each speaker.
So if I were you I would not mess with the system and just route everything via the DVD as it is designed to be done.
Dec 26, 2015 | Philips Audio Players & Recorders
My surround sound won't work now when I play the dvd player
Could be many things - I know, bad answer. There is no simple answer or fix.
Without more info one can only speculate.
Please determine and answer as many or all of the following so that we can help.
1) What is the make and model number of the Surround sound unit?
2) What is the make and model of the DVD player?
3) How is the DVD player connected to the Surround sound unit?
3a) Is it connected via an HDMI cable?
3b) Does the DVD player have regular stereo connections that you are using (we call these analog audio connectors)?
3c) does the DVD player have digital audio outputs that are connected to the Surround sound receiver?
4) Did the DVD player EVER make sound?
4a) if yes - what changed?
4b) if yes - does this happen with different discs?
Now some general points.
I'll assume that the other sources do work and play sound through all speakers when they are supposed to play sound through all speakers.
Then - I'll assume that without changing anything else you select the DVD player input that used to make sound but doesn't now.
Problem could be the encoding option that you have selected when you play the disc.
Many DVD's and Bluray's have audio options that you can select from the disc's main menu.
Dolby digital is the most common - also known as AC3.
Some discs have another digital audio track called DTS.
Not all surround receivers can decode all formats.
Even if your surround receiver claims to be able to decode AC3 and DTS, they will not if you don't connect the correct cable to the receiver and usually map the input to the correct digital audio connection that you are using OR if your DVD player is not capable of outputting all formats.
There are many different ways to connect the gear and many different ways one can configure correctly or not; all contributing to whether you get sound or not.
So in the above example - by selecting DTS, you do not get any sound - then try another audio track option. Basic stereo usually works (also know as PCM - which is audio like a CD).
OR maybe you never properly configured the audio properties of the DVD player.
Go into the DVD's menu or set up options and see what you find but make sure you know how the DVD is connected to your surround receiver!
As you can see - there is no simple answer without a lengthy Q and A exchange first.
May 26, 2014 | Yamaha Audio Players & Recorders
Samsung ps wx30 surround sound system. speakers are plugged in to dvd player. dvd player is connected to tv via hdmi cable. speakers only work when using dvd player and not tv/sky etc.. am i missing some...
Hi,here is my simple solution...
To listen your TV on your
samsung ps wx30 surround sound system ,
** you need to connect "Audio Output " RCA jacks or "Optic cable output" or "HDMI out " of your TV unit
** to "AUX input " or "TV" OR "Any input" of your
dvd player or "Optic Cable input" or "HDMI input"
** than just switch to respective mode on
dvd player corresponding your RCA or Optic connection or HDMI ..
There you go..Your TV sound is on the
dvd player By this means whatever you watch on the
TV (
tuner, satellite , Xbox , etc..) ,it's sound will come thru your
dvd player.
Hope this helps!..if more he?p requires pls let me know..
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 25, 2011 | Audio Players & Recorders
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
Jan 13, 2011 | Spectroniq PD-3000HD
HELPP!! How to connect ''bush dvdav11k'',to TV without DVD Player
HI,
I TOO HAVE BOUGHT THE AV11K. I TOTALLY HATE IT. ITS LIKE ITS BEEN CO-DESIGNED BY THE EUROPEAN SPACE AGENCY AND THE PLAYER AND WOOFER/AMP DONT FIT TOGETHER.
ID LIKE TO SAY THIS THING IS SO POORLY DESIGNED IT REALLY WOULD BE WORTH SENDING IT BACK FOR A REFUND.
ON THE BACK OF THE PLAYER, AND THE WOOFER YOU'LL FIND LETTERS. IE LF,LB,,,,RF, RB. (LEFT FRONT , LEFT BACK ECT). USING THE 'TULIP CABLES SUPPLIED YOU NEED TO CONNECT THE WOOFER AND THE PLAYER TOGETHER MAKING SURE THE LETTERS CORRESPOND.
DO THIS FOR ALL THE CONECTIONS ON BOTH THE PLAYER AND THE WOOFER. THERE SHOULD BE NON LEFT OVER.
THE LETTERS CORROSPOND THE THE POSSITION OF THE SPEAKER IN THE ROOM. SO ( I ADVISE YOU GET A REAL OF EXRTA SPEAKER CABLE FROM EBAY FOR A COUPLE OF POUNDS ) AND PLACE THE SPEAKERS IN ALL THE FOUR CORNERS OF THE ROOM THEN FILL IN THE NEEDED CABLE TO MAKE IT REACH THE WOOFER, WHICH MOST LIKELY YOU WILL HAVE BESIDE OR BEHIND THE TV AS ITS MOST CONVENIENT THERE ( WOOFERS ARE BASS MAKING SPEAKERS AND DONT REALLY CARE WHERE THEY ARE PLACED IN A ROOM.)
YOU SHOULD BE READY TO GO NOW.
THAT IS IS YOU CAN GET ANY SOUND TO COME OUT THE SURROUND SOUND SYSTEM ( LIKE I COULDNT).
THE SMALLER REMOTE IS FOR THE SOUND. THIS CAN BALANCE LEFT AND RIGHT AND VOLUME. AS WELL AS SELECT A AUX INPUT SUCH AS AN IPOD ECT. ( FOR THIS YOU WILL NEED A SIMPLE 3.5 > STEREO PHONO PLUGS. SIMILAR TO THE ONES USED BY THE AV11K.)
WHY IN HELLS NAME THIS SYSTEM IS ON THE MARKET I DONT KNOW. GOD PLEASE RE-ANIMATE MY LAST, AND TRUSTY PHILIPS DVD PLAYER..
HOPE THIS HELPS ALL UNFORTUNATE AV11K BUYS.
YOURS SINCERELY,
ALEX
Jun 04, 2010 | Audio Players & Recorders
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
No sound from rear speakers
Hello, the setting must be "Not Activated" That is for zone 2 setup. If you are setting up 5 speakers the rear speakers should be connected to surround not surround back. Thank you Onkyo USA.
Mar 25, 2017 | Onkyo TX-DS898 Receiver
Hi there, i have a Kenwood V7090D AV receiver. the problem is a) i cannot switch the DSP off without 5.1 switching off as well and b) DSP affests all channels when speakers B is swithched on. if u can...
If you have only Left and Right connected the receiver wont know what to send to the other speakers without some kind of DSP.
If you are using an optical or coaxial connection from a dvd player it may utilize the other speakers if the DVD player is providing that information.
If you dont like the DSP but still want to have all the speakers function while listening to non surround sound material try setting the DSP flat or to a reduced setting.
If you are listening to a DVD with surround sound information and the DSP off still provides no sound to the rear speakers check the manual for that receiver for a "auto surround detection" setting.
good luck.
May 02, 2008 | Televison & Video
BUSH PRO300/AR
hi.
the inputs are not for a tv.
they are for a 5.1 dvd player or similar device, the dvd player will have the same corresponding outputs, join them up and hey presto, sound.
hope this helps
Sep 17, 2007 | Audio Players & Recorders
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
