Question about GE 32GT660 32" TV
Ge 32gt660 problem
The tv shut itself off while I was watching and now refuses to power back on. Or perhaps I should say it refuses to respond to signals from the remote or the front panel. I have no picture or sound except a buzzing sound that won't quit as long as the set is plugged in. Any ideas what this might be? The set is a hand me down from my sister who had it for probably 7 or 8 years. I've had it about 1 month. If it's not likely to be something I can do a simple part replacement on. Then is it cost effective to fix this aging beauty. I am severely strapped for cash at the moment. And yes, I am well aware of the dangers involved in consumer repair of television sets. I am very experienced in repair of all sorts of other electronics in the house, but admittedly have little experience with television repair.
Thanks in advance, cause I know you'll be helpful,
uncooperativeGE
  • rob Peterson Oct 06, 2008
    the TV turns on and after a while it cycles power on and off. I disconnected the switch board (white connector that has 7 wires)and it works fine. The tv will stay on until i unplug the power cord. I cut two of the three wires going to the remote input (the blue one and the white one on the opposite end) thinking that maybe that was the issue ,however it still cycles power. Im leaning to the swich board thinking the power switch has a short in it. Iam not a tv repair man however I can find my way around the schematic and use a multimeter. Any ideas you have would be greatly appriated. [email protected]
    Problem Solver:
  • 10 Answers
It could be just the fuse which is located near the power inlet in the back.
Posted on Jan 13, 2008
6ya staff
SOURCE:
Toshiba 42SL417U doesnt respond to remote and shuts off
you have a bad power supply or mainboard causing the shutdown most likely the mainboard.
Mar 02, 2013 | Toshiba 42sl417 42 1080p Led Tv 42sl417u /...
When I was watching TV today my Sony Bravia KDL-40V4100 just swutched off by itself. After 15 minutes or so it came back on by itself, I shut it off soon after. Later on today after watching TV for 15...
When tv it shutting itself off by it own does the tv power LED light indication flashes?Tv turn on now,the tv power light indication,just flashes?Yes,than ur tv power supply board is the causes and the problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 12, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Need code for a ge tv
The code is usually on the label on the back of the TV
Aug 03, 2010 | GE 32GT660 32" TV
GE #32GT660 won't turn on.
Your set is possessed! Just kidding. The answer to your question is in your last statement. If you smell something burning your set has experienced a voltage overload which caused a component to overheat and burn and that failed component has rendered your set non-operational.
Unfortunately, this is not an easy fix and will require a trip to the shop. Get an estimate before approving repair. In the new world of disposable electronics the cost of repair may exceed the value of the set.
Aug 28, 2009 | GE 32GT660 32" TV
check flyback.
Jun 02, 2009 | GE 32GT660 32" TV
Tv turns on then powers down
It's probably going into hivoltage shutdown. The hi voltage is going up above the safety limit and shuting down. These can be a nightmare to troubleshoot if you don't have the right equipment. Time to call a pro.
Feb 18, 2009 | GE 32GT660 32" TV
GE TV Model 32GT660
You should be able to access by pushing the menu button. If not I would look for a universal remote that will work for that TV.
Jan 02, 2009 | GE 32GT660 32" TV
Turns on an off by its self
In order to fix it yourself you will need a digital VOM meter (preferably one that can test diodes) a 25 watt soldering iron desoldering wick and a cap analyzer. Otherwise you should take it to a shop.
Aug 17, 2007 | GE 32GT660 32" TV
MY TV WAN'T COME ON
First off, it is impolite to post all in Caps, everyone should know this, it is just internet politeness. That said,You could have a bad solder connection or you overheated a component. If you have no TV repair experience, you are going to need to call in a pro to assist you in this repair. Good Luck
Jun 15, 2007 | GE 32GT660 32" TV
SPECIFIC FIX FOR GE 32GT660
I have the same problem, except that it would turn on by itself and then start changing channels. I had a can of compressed air and sprayed the button areas to see if there were sticking. It worked for a coupe of days, then started happening again. So I searched the web and found a response to a question someone else posted and the ensuing reply "most likely you have one of 2 things going on one is the foam between the buttons and the switches or you may have a switch getting leaky and would need replaced" Looks like I may have to taking the cover off and find some type of electronic cleaner, or replace the buttons. I find it odd that I got hits for the same issue with the same model. hhhhmmmmm?
Nov 21, 2006 | GE 32GT660 32" TV
Televison & Video Logo
77 people viewed this question
Top GE Televison & Video Experts
matt martin
matt martin
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
