Question about KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher
Lights are on, but wont start
Kitchenaid KUDM01TJ, there is power to the machine. I can push the selector buttons and sometimes the indicator light comes on for the selection and sometimes it doesn't, but the start button will not start a cycle. The drain button always works. I replaced the main control board, and the same problem still happens. It sure seemed like a main control board kind of issue, could the new part be defective (seems unlikely that a defective new control board would have the same signature of problems)
  • 2 more comments
  • Greggrz Mar 18, 2008
    I have the same problem...all lights work and Drain sounds like it wants to run, but nothing happens. Any other function lights, but no action. Water standing in bottom of unit. Cleaned the disposal line well, still no drain, no action.
  • onthebeach42 Mar 20, 2008
    exactly the same thing is happening to me...any help???
  • keyisthekey Sep 07, 2008
    Same as Lisa. Any other ideas for a solution?
  • RIC-RAC Mar 03, 2009
    Same problem. Has no one fixed their d/w with this problem?
    Problem Solver:
  • 9 Answers
The water pump can hum and still have a defective coil.
Posted on Aug 31, 2008
All Cycle Lights on with one blinking sometimes working often not working.
1) tight the connector wires very well and clean with spray contact, of course unplugged the machine
2)resolder all point from the board for colder joint
3) Try again.
4) If the problem persist the problem is the board defective.
5) Call some service tech.
God bless you
Jun 19, 2012 | KitchenAid KUDS301V Dishwasher
Dishwasher wont start, light are flashing
should indicate that a power failure has occurred try pushing start cancel then reset options and re start
Feb 12, 2009 | Electrolux Frigidaire Professional Series...
The rinse light continuous to blink
The blinking buttons indicate the buttons are bad. The console will have to be replaced.
Mar 31, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
KitchenAid model KUDM01TJ
Check for loose wires on all switches and their is a fuse on the electronic panel that should be checked.
Machine wont start
oohhhh. gwl10 os asearly as my knowledge about these machines go, placing a call to manufacture migh be helpfull . do any indicator lights blink when washer stops??? those are the codes so write down which ones are blink, if i had to guess though id lean toward an ou-of-balance switch failure. on my gwl10 thatslocatedunder console on right side, white bar hanging down measuring time tub hits into it. the switch usally corodes out. hope thats somthin anyway
Mar 01, 2008 | Washing Machines
Won't start!
toggle between 'heated dry' and " normal ' until all light illuminate Then press cancel. now ensure door closes properly without striking cabinets slightly. The neutral for most components run through the door switch and jarring actiong causes a fault to be stored in computer. the toggle dance clears the fault code otherwise it will "fault code "again in three operations. hope this helps.
Feb 13, 2008 | KitchenAid 24 in. KUDM01TJ - Multiple...
Whirlpool Dishwasher - lock
This solution is AWESOME...dead on and my unit is back up and running...Thank-You SAS
Dec 22, 2007 | KitchenAid 24 in. KUDM01TJ - Multiple...
Stopped Dead
thermal fuse attached to control board. it is white in color. You should have power at both terminals on this part.
Dec 15, 2007 | KitchenAid 24 in. KUDM01TJ - Multiple...
LOC code flashing on washing machine
Pressing the options and select buttons simultaneously for 5-10 seconds worked. For me it happened this way: on the first attempt, with the indicator lights already "timed-out" and off, pressing and holding the options and select buttons simultaneously for 5-10 seconds caused the lights to come back on and flash the "LOC" code again. But holding the options and select buttons together for 5-10 seconds a second time caused the indicator lights to stop flashing, and allowed me to start the cycle.
Dec 01, 2007 | Frigidaire GLTF2940ES Front Load Washer
Won't start after repair
SUGGEST YOU PULL OUT PLUG THEN OPEN DOOR UNSCREW TOP SECTION OF PANEL TO GAIN ACCESS TO DOOR LIMIT. CAREFULLY BRIDGE BOTH WIRES OUT AND ALSO WITH WATER SWITCHED OFF, SWITCH POWER BACK ON. IF NOTHING STILL, CHECK POWER TO DOOR LIMIT. IF THERE IS POWER, EITHER THERE IS A LOOSE WIRING CONNECTION ON THE BOARD OR IT HAS AGAIN GONE FAULTY.
Aug 22, 2007 | KitchenAid 24 in. KUDM01TJ - Multiple...
KitchenAid 24 in. KUDM01TJ - Multiple Color Built-in Dishwasher Logo
478 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
