Question about JVC AV-32FA44 32" TV
Lost TV picture
Accidentally pressed minus (-) button when finishing watching dvdand lost action for retrieveing TV picture. Tried reversing that action by pressing plus(+)button of JVC remote but could not retrieve TV picture. I have 3 remotes. One for Panasonic VCR/DVD player, one for satellite function and one for I'ART JVC TV . Help!
  • 1 more comment
  • Syl_77 Jan 13, 2008
    There was no solution. I don't know why you are asking for a rating!! Give me a solution and I will give you a rating depending if it helps me. Syl_77
    No, your ad says free solutions. Why would I want to see postings of problems with TV brands other than mine? This is so fake and only a come-on to buy some service or product.. Syl_77
    No.
    Scholar:
  • 135 Answers
Hi there!
I noticed that you were having some difficulty with ratings or something. But I also don't see a solution to your problem. The problem you have is not common and could be anything from electronic to software fault in the EEprom. I would have the transmitting on the remote tested first. It can be done without the TV at a repair technician that has the relevant tools. Note: Don't know who you communicated with, but this service is free as far as we are able to help people like yourself with basic information. Like myself and all the others we do not get paid to sit on this site and certainly don't expect ratings. We monitor our ratings to see how many people we could help with their problems and for me personally, is enough. If you have any question please mail Fixya direct. Good Luck with the problem, JUS004
Posted on Mar 09, 2008
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
I have lost my dish network remote but i have a universal remote i need the code so i can program my remote for my satilite
Here is a way with out the code.
1. Turn on the component (the tv, dvd, etc). 2. Press the TV (or DVD) button first and then the on/off button and hold both until the on/off button remains lit. 3.Press the PLAY button every five seconds until the component turns off.
  • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited
After the component turns off press the REVERSE button every 2 seconds until the device turns back on. Skip to step 7. 4.
  • If your television is an older model it may want to turn on immediately before you get the chance to press reverse. If that is the case and the TV automatically turns itself on then simply follow the step and keep pressing reverse until the component turns OFF. Then skip to step 7.
If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks. 5.
  • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
6. To save the new code, press and release the STOP button.
Aug 24, 2011 | RCA RCR312W Remote Control
I need to set an alarm on my watch but I do not know how. I have a Baby G watch Casio Model BG169A-1AV
press mode until you reach the alarm mode then press and hold set button until the digit blinks. note: the one that blinks can be adjusted, the 24 hr/fwd is to add, the alarm on/ rev is to minus. if your done press set button to finish. i hope this will help you.
Jul 13, 2011 | Casio BG169A-1AV Wrist Watch
I accidentally hid
To make the alarm appear press the button at 8 O'cloc.
To turn off/on the alarm press the button at 2 O'clock.
Jan 05, 2010 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
How do you reset the timer on the lamp without a PIP button on the remote
Howdy,
To reset your Panasonic Lamp Time:
ø Press and hold these buttons for (at least) 5 seconds:
ø Volume Down button (on TV Panel).
ø AND ACTION Button (on remote).
As the remote gets older the ACTION button may not respond unless you press the button dead center and not at an angle.
Thanks for using FIXYA, BIG IRISH.
Oct 08, 2009 | Panasonic PT-52LCX65 44" HDTV
Pressed button on remote and can't watch cable now.
sounds like you make have change input to antennae tv, go to tv-cable setup and highite cable and enter that, if you have instrution book, it will help.
Dec 29, 2008 | JVC AV-30W776 30" TV
I have a RCR312W. Other numbers given are R55N7 4811P. The problem is this: Some how it lost it's programming and I don't have the instructions to reprogram it. I tried to do it from memory, but...
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Jul 09, 2008 | RCA Televison & Video
Progrm my universal remote
When doing the code search for this remote, and you get to the point where the tv shuts off, you press the reverse button BUT the directions should say KEEP on pressing the REVERSE button EVERY 2 SECONDS until the tv turns back on.  THEN PRESS STOP.  The directions I kept on getting were sayng to press it but they did not specify how many times.  YOU NEED TO KEEP PRESSING REVERSE UNTIL IT TURNS ON, THEN PRESS STOP.
I got these directions (after about an hour of searching sites I found) from www.rca.com
  1. f, after five seconds, the component does not respond, continue to press the PLAY button every five seconds until the component turns off.
  2. Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  3. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  4. If the component does not respond, continue to press the REVERSE button every two seconds until the component turns on again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
  5. If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
THIS HELPED ME I HOPE IT HELPS OTHERS WITH THE SAME PROBLEM.
Jul 08, 2008 | RCA RCR311B Remote Control
Setting the clock on my baby g shock watch
Press & hold the adjust button until the time starts to flash.
Press mode button to select hours.
Press forward or reverse button to move hour backward or forward.
Press mode button to select minutes.
Press forward or reverse button to move minutes backward or forward.
Repeat the process for the month/dte/dy/yr
Press adjust again when finished
Mar 09, 2008 | Watches
JVC AV-32FA44 32" TV Logo
44 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
