Maytag lse7800acw Just installed a maytag LSE7800ACW, stacked washer/dryer combo.  The dryer works fine.  But the washer won't agitate or spin, it keeps running from one cycle to the next as if the knob just keeps going around and the motor wil get hot if you leave it on.  The motor will spin if you disconnect the belts and give a start with your hand.  Will not do this with belts connected.  Seems like it is only getting 120V.  Red wire at motor is 120V.  no others.
  • mickrowan May 11, 2010
    I have the same model but it uses 240v (2 phases) 5000w 24.5 amps. I am looking for a manual.
  • 196 Answers
The motor is faulty. Either the relay contacts are stuck or there is a shorted winding. Best to replace the motor.
Posted on Jan 14, 2008
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
I have a maytag lse7800acw stack on with some years on it which always ran like new until the dryer completely lost power the timer dial won't even tick when you turn it to start it
First, have you check to see if one of the breakers have been thrown?
Second, if the breakers are good, check the "thermal cutoff" for continuity. It is located on the blower housing. Here is the part to order in case it is bad.
Post back your results.
Nov 22, 2012 | Dryers
The dryer on my maytag stacked combo lse7804ace the motor works but the dryer doesnt spin. Broken belt?
You will need to either re-install the belt or replace it. I would assume that it's broken because it's not that common for it to just run off the pulleys.
Oct 19, 2009 | Maytag LSE7806A Top Load Stacked...
CHANGE THE DRYER BELT MODEL LSE7800ACW MAYTAG WASHER/DRYER COMBO can go to the following website and check out how the belt goes on the dryer.
On a front load dryer, you would normally remove the front to expose the drum and belt, after you remove the drum then that exposes the drum rollers, motor, idler arm pulley, etc.
Hope this helps
Sep 29, 2009 | Maytag Dryers
Maytag s1000 stacked washer will not start water fill and cycles.
could be wash spin relay stuck in spin must be 15 years old
Feb 19, 2009 | Maytag LSE7806A Top Load Stacked...
Dryer Drum Won't Spin
Reach inside and grab ahold of the baffle. Try to spin the drum, it should have resistance. If it spins freely you have a broken belt. Hope that helps. Dave
Dec 16, 2008 | Maytag Dryers
I have a maytag stackable washer dryer model number LSE7800ACW when i turn on the washer it will not fill it will not spin it will not do anything but the dryer works just fine. What is wrong
HI. thanks for the question. you have a blown fuse ,inside the washer. remove the front panel. on the left ,you will find a small glass fuse .check that. if its failed you will be able to see, that the small metal strip inside the fuse is broken , if so replace the fuse. thanks the appliance doc . please rate my answer.
Oct 07, 2008 | Maytag Washing Machines
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag washer
This is similar to a problem I had after my power suddenly went out while the washer was filling with water. When the power resumed the washer would no longer run water... all other systems (agitate, drain, spin) worked fine.
A 10 minute, $113 dollar service call revealed that there was a fuse inside the front upper left area that had blown. Remove the 2 screws at the bottom of the front panel to get access to the inside.
Check it out and replace it if necessary.
Jan 20, 2008 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
427 people viewed this question
Top Washing Machines Experts
