Question about Whirlpool GGW9200L Gas Dryer
Whirlpool GW9200L Gas dryer
When I press the start button the display shows 2 dashes and the dryer does nothing.
  • 3 more comments
  • krossiter Jan 13, 2008
    I just tried the dryer in all the auto and manual option modes. It will work in delicate mode but no others. The switch turns the light on and off when operated with the door or if I press it manually. When in the delicate mode it will turn on and off properly when the door is opened and closed. Do you still think it's the switch? I'll try what you advised next.
    I just got back home and will look for the tech sheet. You can send the PDF to kfrossiter@comcast.net
    thanks
  • krossiter Jan 14, 2008
    I took everything apart and found the tech sheet. Put it in diagnostic mode. had 88 on the screen. When I open the door I get a beep and 39. Tech sheet says I should have a number and letter showing. I close the door , get a beep and back to 88.
    The wet finger test on the sensor gave me a solid beep and 02 on the display.
    Took the sensor harness apart and checked the pin with an ohmmeter. Tested ok. Put it back together tried to run the dryer. No start, pulled the plug apart, tried again and it started. Put the plug back together again and it starts. waited 30 minutes, tried again and it started.
    Manual did not arrive yet as of 8:35 EST.
  • krossiter Jan 15, 2008
    I received the manual. I'll go with replacing the control panel first. Thanks for all your help. Ken
  • krossiter Jan 22, 2008
    Thanks for checking back. Since I put everything back together it has been working 9 out of 10 times. The one time that it does not work we open the door and close it then it works. I'll hold off on replacing parts until it gets worse.
  • 290 Answers
The first thing to check is the door switch. It is a pretty common failure I am running into lately.
Post back with any questions.
Thanks/Mike
Posted on Jan 13, 2008
  • 4 more comments
  • Michael  Lindley
    Michael Lindley Jan 13, 2008
    You can remove the lower front cover of the dryer and get the techsheet out. There is a diagnostic mode you can put the machine into that will help in narrowing down the problem. If it is the door switch as I think it is here is how you replace it.
    Unplug the dryer.
    The door switch will pop out from the front. I use my knife blade to pry out on the right side of the switch and roll the switch out.
    There may or may not be enough slack in the wires for you to be able to get them hooked to the new switch. I am usually able to grab the wires with some needle nose pliers just behind the connectors and pull enough slack to plug the switch in.
    If they are too short you will have to remove the top and console to reconnect them after you put the new switch in.
    Remove the screws at the rear of the top and it will slide back and lift up.
    Remove the screws holding the support that runs from the console to the rear of the cabinet. Slide it off the console and let it rest on the drum.
    You will see two screws holding the console to the cabinet from the inside of the machine. Remove them and the console will slide up and off. You should have enough slack in tke wires to set the console on the drum. From this point you should be able to reach the wires on the door switch.
    Post back if you have any trouble or questions.
    Thanks/Mike
  • Michael  Lindley
    If the dryer will run in delicate mode then it probably is not the switch. There are 2 contacts in the switch, one for the light, one that tells the control the door is closed. The light may work ok but the contact for the door sensor circuit be bad. If the door switch is bad it should not work in delicate mode. I now believe you have a control problem or user interface problem.
    I told you wrong on the location of the tech sheet. It is located under the top of the dryer on the right side panel as you are facing it. Get it out and follow the diagnostic mode instructions. I have a complete repair manual in PDF format I can send you if you post an email address.
    Thanks/Mike
  • Michael  Lindley
    I have sent the manual. It took awhile on my dial-up. Let me know it comes through ok.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Jan 14, 2008
    The manual is a large file. Took over 2 hrs to send. I will try sending it again when I get in from work tonight.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Jan 15, 2008
    I sent the manual again last night.
    I think your problem is in the control panel. The moisture sensor should not keep the machine from starting or cause dashes to appear in the display, and any problem with the moisture sensor should have affected the delicate cycle as well.
    If you have read and went over the tech sheet diagnostics, you see that your symptoms don't lead to a clear cut diagnosis.
    If I were working on one doing the same thing, I would reccommend replacing the control panel first. Mainly because I have had more failures with control panels than I have with main boards on these dryers.
    Let me know the manual comes through. I sent it to kfrossiter@comcast.net in a .zip file.
    Thanks/Mike
  • Michael  Lindley
    Michael Lindley Jan 21, 2008
    Ken,
    just wanted to follow up and see if you have dryer fixed.
    Thanks/Mike
Samsung dryer DV210AEWXAA
Kenmore Whirlpool Dryer Won't Start - Easy Fix - YouTube
? 3:52
www.youtube.com/watch?v=MhVUEhngZMg
Jul 21, 2012 - Uploaded by Bill Newberry This video will show you what you need to check if you press thestart button on your Kenmore or Whirlpool ...
Sep 18, 2015 | Dryers
How can I fix my HE4 Gas dyer it will not start
Kenmore Whirlpool Dryer Won Start Easy Fix What to Test When Whirlpool or Kenmore Dryer Won Start or Run Kenmore Whirlpool Dryer Won Start Easy Fix
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Jun 21, 2014 | Kenmore 659 Electric Dryer
I have a whirlpool duet gas dryer model ggw9200lw1. when i press the start button it clicks once but wont run.
First, check the door switch. Push and release it by hand and you should hear a click. If no sound, replace the door switch with this part.
If the switch is ok, press the cancel button on the machine. Then do this. press and hold the start button for 2 seconds then release wait 2 seconds and press and hold again for 2 seconds continue this pattern until the dryer goes into test mode. You will see all the lights on the control light up. press each button on the control one at a time 3 times each. (Do not press the cancel button) until the dryer begins to run. When the dryer starts to run then press the cancel button. Then your machine should function properly.
Oct 19, 2012 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
The dryer will not operate. you can press the buttons , all the lights come on, but as soon as you press start you hear a clicking sound and then nothing happens. I seems the dryer is on but nothing is...
go to the back of dryer,remove the back panel,look at blower housing and you see a white thermostat like part with 2 cables. that's the thermofuse. use a multimeter on continuity(beep sound) and disconnect one wire and put leads at the 2 connector of fuse. if no sound then replace it. this is the most common problem. after replacing part check vent at wall that is clean of obstructions.
Feb 12, 2011 | Whirlpool GGX9868J Gas Dryer
unplug dryer, remove back panel, look for a white part with 2 connectors on the blower housing and remove one, using a continuity or ohm meter put across the leads and if you hear no sound or see no reading in meter replace that part. is the thermal fuse. this is the most common problem for that failure.
GW9200L Keypad / Diagnostic test shows code 06
troubleshoot whirlpool duet dryer GW9200 Press the start button and the beeper sounds once and you hear a relay trip but nothing happens. Did a diagnostic / keypad tes and the code was 06
Feb 07, 2009 | Whirlpool GGW9200L Gas Dryer
"control on" button doesn't come on
could be a bad capacitor inside the dryer
Jan 10, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool LER5644EQ2 Electric Dryer that won't start
Regarding model LER5644EQ2, here is a link to a parts website complete with an assembly drawing and parts list. In all probability,you have a blown thermal fuse and that will need replacing http://www.pcappliancerepair.com/model-display.php
Item #23 on the drawing .. a quick test would be to ( with power removed or disabled) measure the resistance across the two terminals and it should not be an open circuit or it is blown. The drawing shows exactly where it is and the parts list shows the item number/ cost and where to buy a replacement. Hope this helps..
Regarding model number is YLEQ5000PW1, you may have the same problem with your thermal fuse.. the parts website does not show a detailed darwing of your model but it should be similar to the other one I've cited in the location and thermal fuse.. The link I am sending is for the parts list for your washer and the thermal fuse.. http://www.pcappliancerepair.com/model-display.php
Let me know if that isn't the problem and we can look at other ways to zero in on a solution..
Hope this helps...
Regards...
Sep 07, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool GGW9200L Gas Dryer Logo
165 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
