Question about Philips Cineos HTS9800W System
Sound and picture
My HTS9800 has strated to sound very echoey and picture has lines in it when playing dvd which get worse when sound volume is increased.
Connection to tv is via component video.
Cheers
Stuart
  • 476 Answers
Check that you have connected the component video lead to the correct sockets in both the TV and the HTS9800W.
There are two sets of Phono (cinch) connectors, which are grouped together.
Red / Green / Blue - Component connectors - video only
Red / White / Yellow - Stereo audio and composite video connectors - audio and vide
If you have inadvertently connected the red audio connector to the red component input on the TV, it would cause similar symptoms as you describe.
Posted on Feb 13, 2008
Why do my cd decks sound echoey
It might still be a installation issue but if you are using a Surround Sound type amp that might be on. If the unit is doing it by itself then there could be an internal problem with a delay line or A/D converter.
In all of my years I have never heard of this symptom though.
Jan 20, 2013 | Audio Players & Recorders
When i plug them into my computer and sound plays, it sounds like its echoey like your playing it in a dance studio. how do i fix this
if you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Mar 25, 2011 | Insignia 2.0 Speaker System (2-Piece)
I'M HAVING TROUBLE WITH THE SOUND ON MY LAPTOP.WHEN I PLAY A DVD THE PICTURE SHOWS BUT NO SOUND.HELP PLEASE!!!!!!!!!
mcdevito75 here, It may be the sound track on the DVD itself, try another DVD and see how the sound is. If the sound is OK without any DVD being played you simply have to adjust the sound while playing DVD"s either at the speakers or with the volume control on your key board.
Oct 11, 2010 | Computers & Internet
Have an acer aspire 5516 and cannot find any sound when playing a dvd
check your sound and audio devices. Or you can see icon tray on the right-bottom. See picture "speaker" on there? Double click it, and please be attention in that check in "Mute All". Don't get that check, if you wanna hear some sound after you are playing some DVD's in PowerDVD software.
Sep 18, 2009 | Acer Aspire 5610-4648 Notebook
WHARFEDALE DVD 750 - N0 SOUND ON PLAYBACK
Clean the player with a disc cleaner with a drop of the solvent on each brush on the surface of cleaner CD and play it in the player. If sound quality improves then keep running the cleaner disc till its sound becomes ok. If this does not work then then there is problem on the output amplifier circuit which can be checked out by a professional technician.........sodeep
Jul 30, 2009 | Televison & Video
Sound on pc ( Vista )echoes and indistinct works on device and other pc's
I think all sounds to be going mute go to control panel - sounds options & go to volume tab - then advanced - then increase all the volume bar.
I think it will be helpful if the problem is this.
May 29, 2009 | Audio Players & Recorders
No Sound when I play a DVD, but I do have sound when I play a Music CD
Open your sound controls to make sure nothing is muted or set on low volume.
If that's not the case, open your audio drivers program and check to see if nothing is muted.
Oct 22, 2008 | Computers & Internet
Sound problem on new Aspire
You can check already the audio setting in your dvd software maybe the volume is low or mute. Click Start, accessories,entertainment and volume control adjust the volume to higher or look if the volume is mute
Apr 14, 2008 | Acer Aspire 3680 Laptop
Echo when playing surround sound
You want to adjust the "DELAY" setting on the receiver. The standard (default) delay setting is 20mS, which may need to be shortened if your speakers are well behind your listening position. In a proper setup, you should not detect a significant echo effect in surround programming (unless it is a purposely "echoey" scene). Also, make sure you don't have any of the "enhanced" DSP modes engaged -- some of these are quite echoey. if it has speaker set up, there should be a setting for distance. You might have it set close, so that by the time you hear the fronts, the rears should go. Try setting it farther each time until it sounds right. good luck
Mar 24, 2006 | Teac AG-D8900 Receiver
Philips Cineos HTS9800W System Logo
117 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
