Question about Sony PlayStation Portable (PSP) Console
Sony Playstation 2
I've purchased a new Dell XPS420 workstatiom and with it came a Dell TFT monitor with XGA and VGA interfaces. Can you tell me where I can purchase an adaptor/convertor so that I can play the PS2 via this monitor?
    Problem Solver:
  • 5 Answers
I would go to geeksqaud and ask about your type of computer and they would tell you what type and how much it would cost
Posted on Jan 13, 2008
I need to connect a VGA dell monitor my Toshiba Laptop
HDMI is digital
VGA (the 15 pin connector) is analog.
If your connector has the digital to analog interface it should work, but likely it does not have that chip and thus will not work.
Your description of the problem tells me it may never work as you have it connected. Possibly it might be that the monitor is required to be powered on before the laptop is booted, but that only works in some cases.
I have also seen some work if a 2-step connector is used.
VGA to DVI connector, followed by DVI to HDMI connector.
DVI was the step toward digital that came before the HDMI standard was implemented and was only partially digital. DVI and VGA do not carry control signals nor audio. HDMI carries both those as well as the video.
YMMV but I think it would be cheaper and more efficient to actually purchase a monitor with a digital input (HDMI or DVI).
Without the digital/analog converter interface a digital output device (your laptop with HDMI out) can never operate an analog device (your Dell monitor with VGA input).
Mar 12, 2017 | Dell E193FPp 19" TFT LCD Flat Panel...
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
Only till recovery page then boom-blank
Try attaching the external monitor to VGA port to see if you get the same problem and then post back.
Mar 04, 2010 | Sharp 12.1 in. XGA TFT Active Matrix...
I need to find the VGA controller for the Dell 2005FPW monitor
you can use on all vga cards(you dont need any special controler), this monitor has a USB hub
and its is detected normaly on winxp or above, and the vga cards detect the monitor auto.
i give you the monitor specs, take form website
Display Type LCD display / TFT active matrix
  • Built-in Devices USB hub
  • Width 18.6 in
  • Depth 9 in
  • Height 15.3 in
  • Weight 17.6 lbs
  • Enclosure Color Midnight gray
  • Image
    • Display (projector) image aspect ratio 16:10
    • Image brightness 300 cd/m2
    • Image Contrast Ratio 600:1
    • Max horizontal view angle +88 / -88
    • Max vertical view angle +88 / -88
    • Diagonal Size 20.1 in
    • Viewable Size 20.1 in
    • Dot Pitch / Pixel Pitch 0.258 mm
    • Max Resolution 1680 x 1050 / 60 Hz
    • Color Support 24-bit (16.7 million colors)
    • Max Sync Rate (V x H) 75 Hz x 83 KHz
    • Video Bandwidth 146 MHz
    • Response Time 12 ms
    • Controls / Adjustments Zoom , Clock , Phase , Contrast , Sharpness , Brightness , Saturation , H/V position , Color balance
    • Display Positions Adjustments Height
    • OSD Languages French , German , English , Spanish , Japanese
    • Display Screen Coating Anti-glare , Hard coating
    • Video Output None
    • Signal Input DVI-D, VGA
    • Features Picture by picture , Picture in picture
    Video Input
    • Analog Video Signal RGB , S-Video , Composite video
    • Digital Video Standard Digital Visual Interface (DVI)
    Audio Output
    • Type None
    Input Device
    • Type None
    Expansion / Connectivity
    • Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15) , 1 x DVI-D - 24 pin digital DVI , 1 x Composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 4 x Hi-Speed USB downstream - 4 pin USB Type A , 1 x Hi-Speed USB upstream - 4 pin USB Type B
    • Flat Panel Mount Interface 100 x 100 mm
    • Features Security lock slot (cable lock sold separately)
    • Compliant Standards CE , CCC , MIC , NOM , PSB , BSMI , GOST , SASO , NEMKO , TUV S , C-Tick , TUV GS , EN55022 , TCO '99 , EN 60950 , ICES-003 , TUV Ergo , UL 60950 , IEC 60950 , EN 61000-3-2 , EN 61000-3-3 , FCC Part 15 B , VCCI Class B ITE
    • Form Factor External
    • Voltage Required AC 120/230 V
    • Power Consumption Operational 55 Watt
    • Power Consumption Stand by / Sleep 3 Watt
    Environmental Parameters
    • Min operating temperature 41 °F
    • Max operating temperature 95 °F
    • Operating humidity range 10 - 80%
    • EPA Energy Star Compliant Yes
    Feb 13, 2010 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
    I want to use the Dell E171FPb 17" Monitor as a TV. How do I do it. It does not have RCA, or S-video jacks.
    Hi friend,
    You can purchase TV tuner card then you can use as TV. There is not other option for you....
    Jan 05, 2010 | Dell E171FPb 17" TFT LCD Flat Panel...
    Hi,how do I know wheather I need DVI or VGA cables to connect CPU to a Monitor.I sold monitor when I got laptop now I want set up the Dell Dimension 3100 as aback up,so I'm looking at wide sreen monitors...
    Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
    VGA connector has 15 pins and DVI has 24 +1 pin
    Sep 02, 2009 | Dell Dimension 3100 PC Desktop
    Vga componet keeps showing up on the screen.
    Assuming safely that you have a Dell E173 monitor, i would suggest the following steps to fix this...
    1. Press the (+) button on your monitor to make it do an auto-adjust of the display.
    2. On the on screen display (OSD) which can be evoked by using the menu button on your monitor - use the +/- key to get the factory reset option high lighted and press on the menu button to execute it.
    This should take care of your problem, let me know how it goes!
    Jan 12, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
    Dell E173FPc
    VGA turns on after a few seconds turns off
    Jun 29, 2008 | Dell E173FPc 17" TFT LCD Flat Panel...
    TFT screen not working
    clean your vga ,fix it in your agp slot also remove dust from it .
    reconnect all cable to board.also clen processor case.
    clear your bios.
    take away cmos cell for 15 minutes.
    Mar 24, 2008 | MSI FX5200-T128 (128 MB) Graphic Card
    Dell Trinitron Ultra Scan Monitors
    Yes as long as your monitors have the standard 15 pin Mini D-sub connector (which they do) then you should have no problems viewing a composite input through your converters.
    Jan 04, 2008 | Dell Ultra Scan 17TX - 17" SVGA Color...
    Sony PlayStation Portable (PSP) Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
