Question about GE WSM2700W Unitized Spacemaker Washer and Dryer
Washing machine is leaking!
My washing machine is leaking from one of the water supply connections. I shut off the water supply. The more I look at the connection it looks as though it wasn't screwed on properly, or straight! Why would it start to leak now, I've has this machine for over a year? Should I try to unscrew the hose and screw it on more straight or will this cause a larger problem? It is the connection that is leaking not the hose! HELP!
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 15 Answers
First check your supply hose for cracks or splits. If cracks are apparent the hose must be replaced. If none are apparent I would suggest taking apart the connection and checking the gasket or washer inside the fitting. If it has decayed or cracked this could be the culprit. Replace the gasket or washer with the same size. these are availiable at any hardware or home improvement store.
Posted on Feb 27, 2008
How to remove washing machine from jayco sterling 2013
I PRESUME YOU WAN'T TO REMOVE A OLD WASHING MACHINE,
1. PULL OUT ELECTRICAL SUPPLY PLUG.
2.PULL MACHINE OUT A BIT TO GAIN ACCESS TO BEHIND MACHINE, SOME MACHINES HAVE COLD WATER SUPPLY PIPE ONLY BUT MOST HAVE HOT AND COLD SUPPLY PIPES.
THERE SHOULD BE A SHUT OFF SUPPLY VALVE AT THE SUPPLY SIDE OF THE TWO HOSES, CLOSE THEM BOTH THEN DISCONNECT HOSES, DRAIN HOSE SHOULD JUST LIFT OUT OF PIPE BEHIND MACHINE , NOTE ALL HOSES WILL LEAK SOME WATER ONTO FLOOR IF LAYED DOWN
A SACK TRUCK IS THE BEST WAY TO MOVE MACHINE
Nov 12, 2016 | Washing Machines
Cabrio model WTW824OYWO . is leaking water a from the back at the valves area all hoses and connection ok ..leaks about one to two cups water only sometimes what will cause this ???
If the supply connections are located above the machine inlets, water pressure and gravity may cause leaks, even though all connections are tight. Some manufacturers recommend turning off the supply between washing sessions but I don't think this is practical.
Oct 10, 2016 | Whirlpool Washing Machines
LEAKS WATER INTO THE MACHINE WHEN NOT IN USE
If the water supply lines are located above the input connections at the back of the machine, and if you have good water pressure, the input mixing valve inside the machine may not shut off completely which leads to leakage into the tub. The solution seems to be to shut off the water supply to the hoses when the machine is not in use but then you will have to remember to turn the water supply back on next time.
Sep 08, 2012 | Maytag Washing Machines
Water dripping into washing machine tub
Your water inlet valve where the water supply hoses connect is probably leaking because it's not shutting off completely because of sediment in the water line. Replace it or you can try cleaning it.
Oct 26, 2009 | Maytag Atlantis MAV8551 Top Load Washer
This fill hose is leaking on my maytag a612 washing machine. It is leaking at the little plastic thing that the hose runs through. Is it possible just to bypass whatever that is?
Hi FordMan! The little thing is the water inlet valve and it is not possible to bypass it, since that is what allows the water to flow into the washer and is what also shuts the water off, once the tub is at the level needed or selected.
However, you might discover that if you shut off the main water supply valves at the house connection point, you can just tighten the hose connection at the water valve, as it might just be a little bit loose.
If that's not the problem, remove both the hot and cold water supply hoses from the washer side and replace the rubber washers in the hose ends.
And if that doesn't resolve the leaking problem, you'll have to replace the water inlet valve to stop the leak. But try the first 2 steps before you move onto replacing the valve.
If you discover you need a new valve, you can go to www.searspartsdirect.ocm and with the full model number of your washer, locate the replacement valve and see a line drawing of your washer and get the price for the valve. This is an easy repair for most DIYr's to tackle and you should be able to do it, once you've got the parts, in about 20-30 minutes with just a couple of common hand tools. Just remember to unplug the washer before attempting any repair and turn off the water supply connection at the wall near the washer.
I will suggest, as the manufacturers all do these days, that if your machine is over 8-10 years old, you also replace both the Hot and Cold water supply hoses, as hoses tend to start to break down after 8 years and could rupture causing extensive water damage, etc.
Hope you find this Very Helpful and best regards!
Oct 25, 2009 | Maytag SAV4655A Top Load Washer
After a load is finished and drained properly, several hours later the washing machine has filled with water again. I then have to run a drain cycle to use it.
This sounds like the valves that let the water in are leaking, just a little bit. Over several hours, they leak enough to be noticed.
You can have those valves replaced, or you could shut off the water going into the washer with the valves in your water supply. (the one's that are usually right next to where your hoses connect)
Oct 02, 2009 | Kenmore Elite 45986 Front Load Washer
Machine fills up with water after cycle finished.  After we did a load of wash and removed the clothes we noticed later that there was water in the machine and it was off.  this has happened...
You have a solenoid leaking by. Next time toy finish a load, shut of one of the water supply valves at the wall. If the water does NOT come into the machine after that, you know that you closed the right valve. Once you have determined which side (hot or cold) is leaking, follow that hose to the machine. The hose connects to the solenoid valve, which is just an electrically controlled valve that is either opened or closed. You can try to service the valve, but it is easier to remove and replace it. They don't cost much, and you can get an exact replacement at any appliance parts supply house. Total time to replace...1-1/2 hours.
Best regards, --W/D-- please feel free to rate this solution...thanx!
Aug 01, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool duet washer leaking water into the drum when not used
water leakin in tho the drum is sign of a faulty water inlet valve, not shutting off water supply to machine, it continues to trickle in , in beween washes. you can turn off the water supply between washes see if this helps, and if it does then youll know its the water valve
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
HOTPOINT WD62 FILLS WITH WATER WHEN NOT BEING USED
All washing machines have a solenoid valve for turning on and shutting off the water coming in, one for the hot water and one for cold. It sounds like one of them has a slow leak.
Try shutting off the cold water supply to the machine for a day and see if the tub fills with water. Next try shutting off the hot water supply and leaving the cold supply on. This will tell you which valve is leaking.
This solenoid valve is something you can buy from an appliance parts company. In some cases, someone handy may even be able to disassemble it and replace a washer that is leaking.
Until it is repaired, you can get by with shutting off the water supply when you are not using the machine or shutting off the supply that is leaking. For example, if it's the hot water supply valve that is leaking, just shut off the hot and do only cold water washing.
-Vince
Oct 03, 2008 | Hotpoint Washing Machines
GE WSM2700W Unitized Spacemaker Washer and Dryer Logo
64 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
