Question about Frigidaire GLMV168K Microwave Oven
Interior Scratch There are 2 small interior scratches on the back wall of our microwave.  Is this bad or is it still ok to use?  I've tried calling the 24/7 customer service number only they aren't 24/7!  UGH!
    Scholar:
  • 150 Answers
Scratches can cause arcing but they are easy to deal with.
touch up paint is available from any appliance parts supplier check your phone book or order online
Posted on Apr 24, 2008
6ya staff
SOURCE:
Microwave Cavity Paint
I would let it dry for a good 24 hours, if you still have a problem with smell use a mixure of water and vinegar in a small container, set for 60 seconds and run microwave when until it steams, it will bond to the interior wall creating a barrier.
May 17, 2012 | Microwave Ovens
Ss25 microwave no power fuse in plug ok, where is internal fuse.
Hello
Fuses can be located behind the microwave door or behind a panel either on the interior wall or an exterior panel. Often the fuse will be behind a panel located under the louver vents on top of the microwave
Oct 04, 2011 | Microwave Ovens
The ceramic fuse has expired in my microwave (Emerson MW8991SB). Will you tell me where the fuse is located?
On my own microwave I have noticed there is a panel on the interior wall with removable screws...I'd suggest UNPLUGGING it first (of course!) then checking out the interior of that.
May 18, 2011 | Emerson Microwave Ovens
I have a brand new Bosch microwave model HMV8051U It was installed for 1 day and the interior glass on the door shattered. What would cause this to happen?
It could be door alignment, damaged or chipped when installed, scratched and moisture got in the scratch and turned to steam under pressure or hit with something spinning around in the machine.
Almost anything.
Take it back and get it replaced.
Jan 03, 2011 | Bosch 800 HMB80 1000 Watts Microwave Oven
A piece of tin foil got to close to the interior wall of the microwave; there was a small arc that caused a small scoring. Can or should this scoring be painted over? The microwave has since been used and...
Sorry to read about your problem, I hope this helps you out.
You can paint, but you have to purchase special microwave paint.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Dec 30, 2010 | Microwave Ovens
The top plate inside the microwave sparks while cooking. We checked the dish we were cooking with, the papertowel that covered the dish. What could be causing this?
The wave guide could be dirty or damaged. Dirty oven interior can also cause sparking. The wave guide is probably not dirty if it's not on the interior of the oven . Some are behind the interior wall .
Mar 28, 2010 | Whirlpool MH7140XF Microwave Oven
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Microwave oven door - interior scratch
inside the microwaveoven shouldnot put tape or other adhesive materials, replace the door immidiatly..
Sep 24, 2007 | Microwave Ovens
Replacing the interior lamp inside the microwave on the top.
Yes, Bobby, it can be done. Before you begin, though, go to Home Depot and look in the tool department. There, ask for a "Husky Pro #66604". It's a 1/4" and 5/16" drive 90 degree ratchet that's about 4 inches long. While you're there, pick up a #2 1/4" drive phillips screwdriver bit. You'll use both of these to do the light. Both for about $12. UNPLUG YOUR MICROWAVE! Stand on a small ladder in front of the Microwave (MW), remove the 2 screws that hold the vent louver in place and remove the louver. You'll now see a black plastic grill (just above the door handle)remove the 2 screws with your new tools and remove the grill and the metal box that covers the relay. Now remove the 2 screws holding the horizontal metal panel that the box was sitting on. Now gently lift that panel up, (don't try to remove it) and you'll see the lamp. It's the one with 2 white wires going to it and a shiny metal cover over it. Place your index finger on the back of the cover of the lamp and gently pull toward you and lift at the same time. This will release the catch and allow you to pull it all the way out to get to the lamp. There ya go! Simple!
Jul 29, 2007 | GE Advantium SCA1000H Convection /...
Frigidaire GLMV168K Microwave Oven Logo
132 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Ekse
Marvin
Marvin
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
