Question about Xerox WorkCentre XE90FX Laser Printer
Machine stops and F6 appears
How do I solve an F6 problem
  • frankbigg Jan 14, 2008
    Thanks for the prompt reply. frankbigg
  • 2,072 Answers
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Machine stops and F6 appears - elem_1_spacer.gifGive this a try, the code is a fuser not warming code. This could resolve it.
Posted on Jan 14, 2008
My kenmore washing machine is stopping mid-cycle and reading f6 on the panel
The F/06 error according to the official repair manual is a Motor Tachometer error . . the error is triggered because the main control board loses communication with the tachometer either a short in the wiring or a short in one of several other places. . The tachometer sits on the spindle of the motor and has two wires from the spindle to a wiring hub on the left side of the motor . . . two of the black wires are for the tach then feed to the MCU (Motor Control Unit) in the bottom left facing the washer which then feeds the info into the main control board which is at the top on the machine under the top cover. Some find that checking the connections with a volt meter is a starting point however in most cases you will not find issues with electrical continuity, the manual has the expected readings. The MCU is known to go bad in these machines so that would be the first suspect in resolving the error, however it could be the wiring, the motor or the main control board. The MCU costs around $200 so consider the possibility that it may not solve your issue. The error may even be sporadic only happening on heavier loads in the tub.
Nov 18, 2013 | Kenmore Washing Machines
F6 error! Machine stops working. Flashes F6 and beeps.
The F6 error means Drive motor tachometer error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU) • Check the Drive Motor • Check the MCU • Check the Wire Harness
Replace failed component.
Good Luck! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa!!
Feb 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Have compaq cq40-327tu laptop. i need to install windows xp sp2 but i am not able to do this because of sata driver problem. Help me to overcome this issue. Also i need xp drivers for the same.
Hello, if you want to install window xp sp2 on a sata hard drive,then when you install your operating system CD,a section will appear under your screen, where it will ask you if you want to install on a SATA drivers and that you should press F6. What out for this and press F6, and i believe the problem should be solved. Cheers.
Dec 08, 2010 | Computers & Internet
HI, the reason for the non responsive control is being caused by a major fault within the control circuits. the entire control board will need to be replaced. it has failed at this point.
Replacing the Oven control board will solve this issue.
Jul 19, 2009 | Ovens
when you see this message: Press F6 if you have to install a third-party SCSI or RAID driver. during XP setup, press F7.
if it doewsnt help..... check out the microsoft link.... where they ve specified how u wud need to solve this issue...
thank you good luck
Jun 02, 2009 | Toshiba Portege 3110CT Notebook
F6 Code
f6 communication error in ht emotor controll board, located in the lower left front of machine
Nov 07, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore microwave
i fixed by unplugging the microwave with the door open. I plugged it back in and the F6 was gone. I was then able to set the clock and turn the light on/off . When I closed the microwave door, the F6 came back on and the microwave was making a humming noise. I slapped the side of the microwave near the keypad, and the F6 cleared from the readout and the humming stopped. The microwave is working fine now. Don't know why, except maybe slap on the side reset a relay or something. Anyway, I will never by a Sears Kenmore appliance for the rest of my life. The door rattles when you open a close it (like a part inside the door is broken) and this is the second time a fault code has appeared during use. I had GE Profile appliances at my last house, which are more $$ initial cost, but who wants to screw around buying a new microwave every four or five years. I'll happily spend a couple hundred more for the peace of mind and knowing that it will work during Thanksgiving dinner with the family over.
Sep 09, 2008 | Microwave Ovens
press and hold paper tray,zoom down,1 simultaniously you will enter in programe.F will come on display press 6 it will appear F6 press stark key change the value and then start key to exit the program press and hold these keys paper tray,zoom down stop key
Aug 27, 2007 | Panasonic FP-7735 Black and White Copier
Xerox WorkCentre XE90FX Laser Printer Logo
138 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
