Mitsubishi hdtv projection model WS55311
The local channels on my Mitsubishi are fuzzy, but the other channels look fine, can this be fixed? Also, where can I get an owners manual for this tv?
Thanks. Rod
I have an owners manual. I could send a copy for $10. Deborah
Posted on Jun 11, 2008
What is the wattage for the WS-65411?
AC 120V 60Hz
Only WS73411 takes 275W otherwise, all other model with this series like
WS73411 take 240W as yours.
Hope you are talking about main wattage. Audio wattage is exceptional.
best of luck
Jan 27, 2010 | Mitsubishi WS-65411 65" Rear Projection...
TV will not unlock channels over TV14
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
These steps are actually for the rear projection models, but I hope the work for dlp plasmas as well.
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jan 23, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi HDTV 1080, model WS-55511. Color convergence is off but only on the outsides of the screen; in the center it is fine. Can this be fixed or do I need to replace the television?
Yes, it can be repaired, replace convergence out chips (two ICs) on main board.
If you are not comfortable with TV repair or have no experience, call local tech to fix it. Cost of repair would be $180 or so.
Nov 11, 2009 | Mitsubishi WS-55511 55" Rear Projection...
T.V. Problems
sounds like the capacitors on the FMT or Signal PWB need to be replaced.
Jul 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
TV Color
You need to replace both convergence ICs they are both STK392-120 and you will also need four 6.8 ohm 1 watt metal film resistors. You can get the ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself. Here is the link.
Jul 04, 2008 | Philips 60PP9202 60" Rear Projection...
Scrambled picture
Which caps on which boards as that sounds like a issue with the signal and FMT PCB. The v26 chassis like yours has problems with bad caps on the DM, Signal, FMT and the PWB and terminal
Jun 28, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Tv mitsubishi ws55311
Remove front lower speaker grill,then remove access panel =
unplug white connector ( goes to front controls )......Does the set
work now with remote ?...= bad tactil switch on front panel......T.
Apr 23, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Channels 3,4,5,6 no picture
i have seen this on our cable system at the shop. it could be the system of most likely the tuner in the unit is haveing issuses.
Mar 04, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
