Question about Sanyo DS27510 27" TV
Sanyo stuck on video mode
The tv is stuck on video mode - I bought a universal remote - but it didnt work...please help.
Have a universal remote. Son turned TV on Video1 to play Gamecube. TV is stuck on Video1.
  • 13 more comments
  • shawatson08 Jan 13, 2008
    He changed the mode to Video1 by the remote, not the TV. I tried that and everything else on the TV but nothing works. When I hit the menu button on the TV the only options I have are the picture/sound and language.
  • pasham Jan 24, 2008
    the tv is stuck in video remote. channel button doesnt solve problem and we bought a universal remote and that didnt help either.
  • nikole100 Feb 16, 2008
    Same here, Sanyo DS19500 TV stuck in video mode with only a few options when I push menu button.
  • staceydr200 Mar 01, 2008
    Bought a used TV and tried to turn it on and it is stuck on video2 mode.. tried a couple of universal remotes and none of them work.. I tried using the menu button on the tv and it only changes language and sound.. how do I change it???
  • Kimipoo Apr 12, 2008
    I've asked Stacey about this already and am waiting for her reply, but wanted to run something by you all. My Sanyo just suddenly switched to Video1 mode. I didn't push any button. I was just sitting there, and poof, the screen was blue with Video1 in the upper right-hand corner. Then I pushed "previous channel" on my RCA universal remote, and my air conditioning unit came on. BTW, I have Comcast and the remote that comes with it, and tried pushing the input button as Stacey suggested, but the only thing that happened was that the "bypass" light on the cable box came on. Any comments, ideas? Thanks, ya'll!
  • Anonymous Jun 07, 2008
    why do they make tv's without the video function as one of the menu options.
  • jeffwagner27 Jun 14, 2008
    i bought a television and it is stuck on video mode and the only options i have are clock language and picture HELP ME
  • Anonymous Jun 28, 2008
    Sanyo tv stuck on video mode....hit the input but 2x on the remote...and back to normal. Been trying for 2 days.
  • aysiadls Oct 03, 2008
    I have tried to get my remote to command the tv, does not work. I have tried to do through the menu button on tv and will not allow me to change the channel buttons. My only solution now is to throw out the window.
  • Anonymous Feb 04, 2009
    What if you can't get a Universal Remote? Is there a way to solve this without a remote?
  • Anonymous May 14, 2009
    same thing as everyone
  • Anonymous Mar 25, 2014
    my sanyo is stuck on video i dont have the remote ive tried useing the menu but no luck there
    I can't get my tv out of video1 mode
  • Anonymous Mar 30, 2014
    video mode without remote in videcon bazzon to play tv from dth
  • Lainie Chivers
    Lainie Chivers May 03, 2019
    Trying to set up roku on my 1989 sanyo t.v.. how do I change it to video 1 input? Scrolling past 1 didn't work
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Posted on Mar 01, 2008
Try pressing the Input button on the remote. This is the TV/VCR button. If this doesnt work, go to Walmart and buy a RCA Unversal Remote. Then press the Input button. This fixed mine.
Posted on Nov 22, 2008
  • 3 Answers
I have a Sanyo DS27580 TV that our RCA RCR311w remote had no trouble putting into video mode, but it wouldn't take it out for some reason. I tried all the RCA codes for Sanyo without any help. I tried a GE univ. remote but just got basic functions, then just before buying another I found an old Philips PHDVR8L universal remote and code 506 allowed toggling the video/tv mode. I've tried all the RCA codes for Sanyo I can find but can't repeat the problem so there must have been some other code in the remote that worked.
Posted on Jun 07, 2012
I also had this problem. Tried a universal remote and it did not work....then I tried my JVC RM-SVS701U DVD remote and I was able to switch out of Video mode. Just try different Universal remotes you might have...I used 13 as the TV code.
Posted on Feb 19, 2008
This totally worked; I bought a GE Universal remote at Walmart and it also has an input button so I hit that and TV and it worked! Thanks Alot Staceydr200!
Posted on Mar 05, 2008
Okay, I had the Exact same problem, I bought a Philips universal remore and it worked great when my tv was stuck on normal channels. But when it was on Video1 and I dropped the remot by accident, the remote reseted. So I was stuck on video 1 for awhile, but I started to mess with the menu, and of course there was nothing there that changed it from video 1 to normal channels...until...I hit the Channel Set button, and it gave me the options add/delete. Well I hit that and Boom! it brought me back to normal channels again, so it was easy sealing from there to get my control working. Hope this helps!
Posted on Sep 10, 2008
We had a sanyo tv that was stuck on video mode and we did not have the original remote. I bought an AVEX R6 universal remote for $20 from walmart and it worked. use the auto search method. We were very suprised that it worked because everything we read and even the customer service dept at sanyo said No universal remote can take it off video mode.
Posted on Jan 09, 2009
Stacy you are a life saver. I tried it and it worked!! Thank you
Posted on Aug 30, 2008
Staceydr200 you just made my day. I was really pissed off trying to get the video screen off my tv. I went to about a 100 websites and no ones reponse help. THANKS ALOT......
Posted on Mar 14, 2008
    Habit-Forming:
    New Friend:
  • 50 Answers
You may want to try a manual button or buttons that are located on the rear or even on the side of the TV if not you possibly need to get the original OEM remote. Thanks
Posted on May 03, 2019
I have had the same problem for days on my tv, and was very frustrated! I pulled some of the info from different sources here and wound up flipping through the channels using the up and down buttons on my 'clicker' that works with my dish network device. Went up to 10, then back to 03, and there it was! It worked! You all rock, big time!
Posted on Jul 13, 2008
Anyone have any other ideas on how to fix the stuck on video?. nothing worked so far!
Posted on May 29, 2008
    Novelist:
  • 192 Answers
Have you tried hitting the channel up button on the television?
It seems that if you can change to video 1 then changing back would be an option.
If there is a menu button on the television, then locating the antenna source could be in there.
Posted on Jan 13, 2008
2 Suggested Answers
SOURCE:
SOURCE: sanyo stuck on video mode
ok i have a sanyo tv that was set to imput my remote messed up but now it is fixed i cant figure out how to get it off. in order for me to reprogram my Universal remote i have it has to scan channles right wut do i do??? plzzz help me!
Posted on Sep 04, 2008
Stuck in video1 and video 6 mode. Can't get to tv
ok, all sony sets for the last 20 years or so have had a reset feature that ought to clear this up:
Set turned off and using Sony original remote:
Display, 5, volume up, power-----listen carefully this should take you to the tech menu.
hit 8 and reset should appear on the screen in red
hit enter and the reset should turn to green and set shut off.
Turn back on and see if it cured the issue or not.
Dec 22, 2012 | Sony Grand Wega Kds-60a2000 60-inch Sxrd...
Sanyo TV 27 inch stuck on Video mode. It reached this mode by me pressing the input button on my (GE) Universal remote, not knowing it would put it in Video mode and then accidentally pressing enter to...
Universal remote alway work only the basic for the tv.Beyond that will have problems or stuck in some input or modes.Sorry i can't help u, because i don't know what is the reaction to ur tv by the universal remote,must use the universal remote again tries all the buttons like video modes or input botton.Or take the battery out like 20 mins of the universal remote to erase ur tv codes enter it again.Tries those buttons u pushes before,see if u can get out the video mode.All else fail.Try website like Remotes.com to buy the tv original remote to use.
Jan 20, 2011 | Sanyo DS31520 31" TV
Cannot get the tv into 'video1' (or ' video2') mode
Unfortunately you need the original remote. There is still a good chance you can find a Sanyo universal remote. Check your local Circuit city or Super K mart or Walmart and look inthe electronics sections. I have often seen the Sanyo universal remote! And yes it will have the options you are looking for. Good Luck!
Apr 19, 2010 | Sanyo DS27820 27" TV
Sylvania 6420FF TV - SELECTING AUDIO/VIDEO INPUT w/o remote
During a recent move the remote was lost. I have the 6420FF in my son's room and trying to set up dvd and wi console set up, but cannot adjust tv via menu button on tv. Is there any way to set-up game system and/or dvd without remote?
Jun 13, 2009 | Sylvania 6420FB 20" TV
Tv stuck on video
most universal remotes will not operate menu fuctions or allow input selections. try using channel down buttton on tv . go all the way down to channel two then go down again to see if video1 or 2 comes up. if not access menu functions on front panel go to input select enter in manually mch
Jan 17, 2009 | Sanyo DS32224 TV
Dvd hookup
  • First make sure the audio (red &black) and video (yellow) are plugged into their respective color matching inputs on the TV monitor.
  • Second either using the TV remote contol or TV's builtin control panel set the tuner mode to video. Depends on which TV's input terminal you connect the DVD player; that's where the Video mode has to be assigned.
  • For example: if you connect them to video1, set the tuner to video1. changing the channels up or down will never set it to video mode. You must press video button to change the tuner from regular channel mode to video mode.
Feb 16, 2008 | Televison & Video
Sanyo TV stuck on video channel
sanyo ds35590 no remote, tried universial remote still cannot select menu on uvm. What remote do I need? Or can I get into the menu without remote. I am trying to watch a dvd.
Jan 17, 2008 | Televison & Video
Dec 30, 2007 | Sanyo AVM-3259S TV
AUX mode
Try to disconnect power for at least one day.
good luck---------tomtaso
Nov 04, 2007 | Zenith B32A24Z 32" TV
Tv is stuck in video mode
The best thing to do is get an original replacement remote and then you will absolutely be able to enter the menu and perform the autoprogram.
Aug 23, 2007 | Sanyo DS27820 27" TV
Sanyo DS27510 27" TV Logo
11,226 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
