Question about Panasonic TH-42PD50U 42 in. Plasma EDTV
Power related There is a small problem when you turn it on it starts to power up and then a few seconds later it clicks and turns itself off
  • Anonymous Apr 01, 2008
    I power on tv. It will turn itself off instantly. Red light stays on until i unplug tv. Still no picture.
  • yankeedo Apr 23, 2008
    hello my plasma same model does the same thing only the red light blinks 7 times,already changed the power board same results help me watch tv again please
Was told by service it could be the power board
Posted on Jan 28, 2008
Tv no picture
It sounds like it's developed a serious fault, is it still under warranty or manufacturer return?
Jun 25, 2015 | Televison & Video
No Picture
since how long are you facing the problem
Oct 29, 2008 | Vizio P42HD Television
If the TV works fine till the time it shuts off, then check if this is thermal related or if with a tap the TV shuts off. If so check for poor soldering joints in the power or relative sections. Use a good soldering iron to touch up all these circuits.
If not there could a component malfunction with thermal action. If so seek technical help if you are not familiar.
Feb 03, 2011 | Polaroid TLA-04011C 40 in. LCD TV
E machine monitor turns itself off and on
The same thing happened to me today. I was just sitting in my room then i hear a click and the cpu is on it stays on for a while then cuts off. It then cuts on and off with few seconds in between. It then stays in that way cutting and off for about a minite or two and then cuts off completely. A few minutes later it starts again. Also in the time it its off it will not turn on by pressing the power button. Sometimes it completly boots up by itself and then shuts itself down. If I shut it down manually while its on it'll turn itself on immeditaly after. What's going on! Will the warranty cover it? Do I need a new computer?
Feb 01, 2010 | E-Machines eMachines Monitor E15T4
Power turning off itself when i turn power on
It sounds like it's possibly over heating but as you say it's only turning on for afew seconds it could be hardware related, what lights show up when you turn it on ? i would if you have the knowledge to take the back off and clean out the fan or fans as laptops will get hot pretty dam quickly anyways and a blocked or non functional fan will cause the laptop to turn off. it could also be a faulty battery, i've had one laptop from a customre in the past where by unless the battery was taken out or replaced with a new battery it would not stay on also, so try it without the battery installed with the power lead plugged in and let me know what happends. but dont forget the check the fans for blockage or dust and things.
Feb 23, 2009 | ASUS A6U Notebook
HP-R5052 reboot
It's definitely an overheating problem if your plasma turns off by itself after a while. I would suggest to place a cooling fan near the back of it as a temporary fix.
There could be a power supply issue along with a Ysustainer board but in order to know that for sure, you should use a hair drier and blow hot air to the power supply and see if the TV turns off, if the time that the tv turns off is shorter when blowing hot air to the power supply; then is the power supply issue.
Good Luck.
Jan 31, 2009 | Samsung HP-R5052 50 in. Plasma HDTV
Samsung HP-R5052 Plasma TV
It related with Power Board(50%) or Y-Main(50%).
But, if you use the power bar with surge protacton, need to check
the power bar's lamp when the TV is turning on & off.
No picture
My parents bought the same tv, TV ran fine for 2 years then started giving them problems. Blue light comes on then few seconds later turns to yellow. Turn tv off then back on it worked, until last week it would not turn on.
Took it to a repair shop they said it was a bad power supply and it will cost 50$ for this check up, as it turns out the total bill would be $650 minus the original $50 it would only cost you $600.
Needles to say i took the tv home with me. Since they were not going to use it i started looking at it took the back off, removed all heat shiels ect. Took my magnifing glass out and started looking at the power supply come to find out the part was made in China, it was missing a solder joint, pulled my old soldering gun out, five minutes later the tv came back to life.
i hope this helps.
Oct 23, 2008 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Receiver makes clicking sound when I push power, but does not turn on.
Sounds like a fualty push button - try connecting/soldering on a new one of a different type!
Jul 04, 2008 | Audio Players & Recorders
Panasonic TH-42PD50U 42 in. Plasma EDTV Logo
67 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
