The codes depend on which device your are trying to program your remote to. you can get this list at www.dishnetwork.com/tech. when you get your 3 digit code. For instance you have a sony Tv, the code is 500, Press an hold the clear tv button at the top of the remote till all mode buttons light up, then release, then enter 500 then the # key and your remote will now work your Sony tv. If you still cant find the codes repost with brand of equipment you want top program
Hi friend,
follow the instructions given below
Instructions
instructions:
jQuery('.article ol .image').each(function(i,e){
var $this = jQuery(this);
$this.find('img').error(function(){
jQuery(this).remove();
$this.remove();
Tips & Warnings
hope this help u
please rate me..................
thank u for using fixya
regards
sivaranjini
10812, 10060, 10702, 10178, 10030, 11959, 11632, 11575, 11060, 10814, 10766, 10587, 10482, 10427, 10408, 10329, 10217, 10056, 10032, 10019
Four digit codes are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Three digit codes are:
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172
1. Turn on the TV
NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2.
2. Press and hold SETuntil the Red Light blinks twice, then release SET.
3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first.
4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice
NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code.
5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
6. For future reference, write your code below.
