Question about Sony Cyber-Shot DSC-S40 Digital Camera
Sony digital camera dsc s40
On switch on screen displays ..access...on an otherwise blank lcd..if switch is moved from camera to playback position several times the view through the lens is displayed with the flashing error code e61:00.the camera will take perfect pictures in this condition but the zoom does not work
  • cathy00900
    cathy00900 Sep 30, 2008
    in capturing mode i can't zoom it in or out. whenever i'm trying to turn it off the lens does not go back to its original mode..and if turned it on it dislpays in the lcd to try turn it off and then on again. pls help me!!
  • 104 Answers
Code error 61 related to internal lens problum.i think lens movement moter stuckup this is reparable
Posted on Feb 07, 2008
No image when power is on
Find this button...... '[]' . Each time you press this (Display/LCD
on/off). Your LCD display in in off mode. Press the button until the screen is on.
Hope this helps
Sep 24, 2014 | Sony Cyber-Shot DSC-S40 Digital Camera
My sony camera has a white screen when i turn it on can't see anything camera less than a year old
Hi your camera has LCD defective. it just need change. you can get the part at http://cgi.ebay.com/Sony-Cyber-shot-DSC-S40-LCD-DISPLAY-SCREEN-MONITOR-NEW-/330487896926?pt=Digital_Camera_Accessories&hash=item4cf29d1b5e#ht_4881wt_961 Installing matter, you can bring to your local repair shop or just bring your camera itself. If the repair shop is decent then, they would charge $10 or 15 for labor. But it is your unlucky, then they would try to charge whatever they want. Thanks and kindly regard!
Jun 02, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
I have a blank screen so can not use it to take a picture
Are you able to see old pictures and menu?I mean when the camera is in non-shooting mode .If so then blank screen generally appears due to the problem in CCD which is the general technology used in imaging devices.
If it is blank all the time and there is no display then the problem is with your LCD screen .You should change that.Please get back to me in case you need any other clarification
Mar 07, 2011 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony cybershot dsc-s40 lcd screen is all white
okay the lcd being white means its replacment of lcd time and not the camersa itself. But to rule that out try taking a pic if you cannot you might got a shutter issue as well.
Thanks hope the information helped
Sep 17, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
White LCD is displayed on my DSC-40?
turn off camera tap camera a few times on the palm of your hand .this should work
hope this helps you . jada
Jun 15, 2009 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank screen Sony dsc s40
I have sent the solution to you. But take care of your camera if you are going to open yourself. I am not responsible for any damage.
Dec 04, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Blank Screen
I have been facing the same problem with same model and this is permanent problem it seems with this model (Sony Cybershot DSC S40). It causes because of the following:
SYMPTOMS
LCD display is either blank or WHITE. When the cabinet is opened or LCD flexible cable is
touched, the symptom disappears. This is caused by connection defect or poor contact between connector and LCD flex cable due to the pressure or stress created by the rib in the front cabinet
to the connector.
Send me a email and I shall send you the solution (two files) received from Sony authorized person. You have to open the camera to solve this. Do not open the camera . Just get the idea about where the problem is. I never opened the camera even after seeing this solution 2 yrs back. However, I have a plan for going to service centre with this solution. I hope they can open the camera and solve this. But not getting time to go there in service centre.
I used the following temporary solution and it works to get LCD in its normal condition:
LCD looks like a rectangle is not it? Hold the camera in its normal position as you are going to take a picture (camera is switched on and you are not seeing anything in the LCD, which looks white or dull). Now GENTLY PRESS by the thumb of your right hand at a place near to LCD at the BOTTOM RIGHT CORNER of the rectangle (remember not on the LCD (rectangle) but just outside of it) until you see the normal colour of your LCD. Do few times starting with less pressure and then slightly increase it untill you see a normal LCD. I have been following this procedure for the last 2 yrs and not feeling to go for serving. (This solution I found in a forum only).
(mondal_ashok (at) rediffmail.com
Nov 16, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Screen is white and doesn't display area being photographed. Can take pictures.
From camerahacker.com:
1. Hold camera firmly in left hand.
2. Smartly rap front of camera with knuckles of right hand on the "Cyber-shot" logo.
Worked for me :)
// Maxim
May 29, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Same thing here Tankengine. My problem started when my camera took a spill of about 4 feet. After that I've been getting the same message you have been. I've sent a message to Sony so hopefully they will have an answer. Something tells me it's going to involve sending the camera away, and spending money on an old camera.
Aug 21, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Lcd screen
My Sony DSC-S40 camera went from working fine to having a snowy white display screen and no shown images or data without anything to cause it happening. It was in a good safe location at my PC desk no humidity or high temperatures etc etc. It still took photos and I could still connect to my PC and download and view photos but the camera LCD display screen showed nothing but white.
I have just spent an hour on the internet and located the website below with link attached and I have also posted the comment there in quotes.
I tried pushing on the screen in all corners but no change.
I then did as suggested and gave the front of the camera a firm tap on the Cyber-shot logo with my index finger knuckle and hey presto the display is working 100% AOK now.
http://www.digiforumz.com/DSC-S40-White-LCD-Fault-Problem-ftopict10806.html
Post subject: Sony DSC-S40 White LCD Fault Problem
Archived from groups: rec>photo>digital (more info?)
From Davy
"After 18 months of use, and 6 months beyond the warrantee period, my DSC-S40
screen showed just plain white. I contacted Sony and was quoted 115 UK
pounds ($230) fixed charge to repair it.
Before sending it off I did a quick search of the internet and was amazed to
find that this is a common fault - the flexible cable to the LCD screen has
a design problem and tends to come loose. I was even more amazed to read
that the owner can easily fix it by rapping with a knuckle on the
'cybershot' logo on the front of the camera or pressing ******* the lower
right of the screen surround.
You would think that Sony would come clean on this and own up to its design
fault. I wonder how many owners have actually sent off for repair? -
probably not many cos the repair cost is priced to be just slightly higher
than the original price of the camera - clever! Its a bit ironic really cos,
although the camera had a lesser spec than competing cameras at the price, I
chose it because it was Sony and therefore I believed would be more reliable
and better supported. Seems those days are long gone!
Anyway if anyone else is having the same problem then that's the fix - but I
don't know how long for. A longer term fix is to remove the back of the
camera and push the flexible cable plug hard into the socket of the LCD.
But I can't find how to get the back off! "
May 03, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
106 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
