Sony KP53XBR300 While watching from hd cable in 1080i mode, the tv losses sync (?) with the signal and shows the input and display mode whenever there are fast cuts in the program, flashing lights, dark to bright scenes and so on. This does not happen in any other format. It seems to be getting worse.
  • daniel6660 Jan 14, 2008
    Thanks but the tv does this through the component cable, as in it,s just a monitor.
    I also have a sony terrestial hd box and it does the same thing. There is no color wheel,
    it,s a crt projector.
  • 2,427 Answers
It can be a problem with the internal tuner or filter... (that will need replacing) Try another mode if it is working..
Posted on Jan 13, 2008
  • 2 more comments
  • Rishi Roshan Ali Jan 14, 2008
    It could also be the color wheel contoll module, the contrast filer, the brighhtness filer, but if it works in other modes then its proberally just the internal tuner. IF you wish you can call the manufactures and ask them for advise , dealers and agents for your brand..
    BTW try a borrowed cable box as well just incase its your box ..
    oh ,,, right ahh sorry ..
    What you should have a look at then is your tuner..
    and your filters especially the capicators..
    If those are fine then its an Ic problem, You can have a look at the master controll ic for voltage issues as well as the decoder ic for the tuner..
    But mostly its one of those problems ... let me know what happens
  • Rishi Roshan Ali Jan 18, 2008
    Hey any luck with my latest suggestion ?
Trying to connect Laptop VGA to TV Component (RGBHV) INPUT
Computer VGA to TV AV RCA S-Video Composite Converter, Costech HD 1080P HDTV Video Cable Converter Adapter Plug and Play for HDTVS, Monitors, Display, Laptop, Desktop, PC
Go to Amazon and for $10 solve the problem
Feb 04, 2018 | Mitsubishi Televison & Video
Screen goes black and resets during HD shows
Have you already tried to power cycle all the devices? Unplug the power cable on all your devices for about 1 hour then plug it back in. Check if that fixes it.
Aug 31, 2008 | Sony KP-53HS10 TV
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
How do i get 1080i, my tv shows im only in 480i. i think i might have it hooked up incorrect. my other tv of another brand is much newer so all i did was connect the hdmi cable from the tv to the cable box...
Hello
Your TV will display all High Definition signals as 1080i True HDTV™ and all standard definition signals will be displayed as 480p.
Component Inputs 1-2
YPbPr(480i/480p/1080i)
These inputs can be used for the connection of A/V equipment with component video outputs, such as a DVD player or external HDTV receiver. Please see Appendix B for signal compatibility.
Input DTV (480i/480p/1080i)
This input is used to connect an external DTV receiver, and can be configured for YPrPb and RGB plus H&V signal types.
As a special feature, you have the ability to adjust the red and blue light beams in reference to the fixed green light beam. This process is called convergence. There are two separate memories for convergence. One, for SD 480i/480p signals; the other for HD 1080i signals. SD convergence should be adjusted while watching an SD source and HD convergence should be adjusted while watching an HD source.
Wide Expand: Enlarges the picture, cropping some of the image on both sides. This Expand format is useful to remove or reduce black side bars on HD broadcasts of 4:3 images with black bars. Available for analog 1080i, digital SD 16:9 and digital HD signals.
InputDTV
This input is compatible with most standard DTV and satellite receivers with component video (YPbPr) outputs. Compatible DTV signals are SDTV 480i/480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Please check the DTV receiver specifications before connecting.
This input is compatible with some DTV receivers using RGB with "separate H and V sync". Compatible DTV signals are SDTV 480i, 480p, and HDTV 1080i. All other DTV signals, such as 720p, need to be converted by the DTV receiver to one of the compatible signal types. Industry standards for DTV RGB signals (systems, synchronization, timing, and signal strengths) are not currently established. These inputs will not be compatible with all DTV receivers that offer RGB, HV outputs. RGB, HV signals with less than 5 cables are not compatible.
If your DTV receiver offers both DTV component video signals and DTV RGB, HV signals, we suggest you use the DTV component video signals. Check the DTV receiver specifications before connecting.
Ok.
Feb 05, 2011 | Mitsubishi WS-73909 73" Rear Projection...
Getting sky and the lady said my TV would be HD but there's no evidence of this - any way to "make" it HD with cables etc? Its a Sony KLV30HR3.
You only can get,what is in air broadcasting shows signals,u can't changes the signal modes format.You getting those shows in modes 1080i or 1080p.The shows have a display said HD logo on right side or left side of the tv.U are getting a HD air broadcasting signal.
Oct 03, 2010 | Sony KLV-30HR3 30 in. LCD Television
RCA D52130 52 in. Won't Display High Def
Hi!
I doubt you'll look at this 2 years later, or even have the T.V.
I have the same TV and was able to view ps3 and xbox 360 games in 1080i, but it's a little tricky. First, let me say that the ps3 is probably not the best system to try using 1080i in unless you have a 360 to help trick the tv into working.
Xbox 360
You need to first set the video to 1080i. This will make the screen display in a bunch of horizontal lines most of the time, but if you keep toggling it on and off, it eventually works. To avoid having to sit and swap between the two modes, it's easier to first set it to 1080i and confirm the setting, then go back into the settings, select 720 (first option above 1080i) and cancel as soon as the video mode changes. 95% of the time this will make it display correctly in 1080i mode. If you turn the tv off and back on, it will sometimes reset to the horizontal lines. If you restart the xbox, it will reset to horizontal lines most of the time. With the ps3, you can set it to 1080i and keep toggling it until it works, but when the game launches it can screw up again, so it's best to have the xbox on and ready with a component switch so you can fix it with the xbox then switch back to the ps3. I think the cable that comes with the tv for HD input (the component plugs don't work, they only support 480, but the vga looking input supports 1080i) - the cable is just poor quality and can barely handle the signal. I've been trying to find a better quality cable with no luck.
Hope this helps other people with this ancient beta HD input canadian tvness.
Dec 30, 2008 | RCA D52130 52" Rear Projection Television
KP-53HS10 Real HD
On this TV there is only one input for any HD resolution. Input # 5 is the component input i.e. red/green/blue cable. Just get the correct cable and match colors from cable box to TV this will allow the TV to display 1080i resolution ( only one this TV supports ). FYI you will also have to connect the red and white cables to the appropriate inputs to get any sound because red/green/blue connectors are just for video display not sound. Once your connected you'll be able to access video # 5 be sure to set your cable box to 1080i resolution also. I hope this helps later J.
Dec 02, 2008 | Sony KP-53HS10 TV
I just posted this to another Sony owner:
Another point; HD Ready does not mean that it is HD compatible without the addition of an optional part.
The title only implies that it can be adapted to HD reception.
If you did not purchase it with the set, check your user guide to see what you need to make it whole.
You may have to seek this add-on on eBay since it is not guaranteed that Sony will still offer it.
You might want to check this:
Technical Details · 53-inch HD-ready rear-projection TV (doesn't include HD receiver); 48 x 57.5 x 25 inches (W x H x D)”
From: http://www.amazon.com/Sony-KP-53HS10-53-Inch-Projection-TV/dp/B000050FGB
1080i HD signal not working through COmpnoent IN
WE NEED TO ALL SEND LETTERS TO SONY ABOUT THIS ISSUE. MY PICTURE TUB WENT OUT 4 YEARS LATER AND I HAVE TO MAKE ADJUSMENT HERE AND THERE FOR THE SCREENS VOLTAGES. CALL SONY AND COMPLAIN. I DID.
PRIDAH
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
