Question about HP iPAQ HX2490 Pocket PC
NO SOUND AFTER TOMTOM 6
AFTER INSTALLING TT 6 TO WM5 IPAQ 2490b I HAVE NO SOUND
PLEASE ADVISE OF CORRECTION or PATCH
  • 4 more comments
  • cablemanone Jan 28, 2008
    USED TOTAL COMMAND TO REMOVE BTcoreif.dll.
    REBOOTED IPAQ 2490. WORKS WELL..
    WITHOUT REMOVING TT6
  • marksw Jan 30, 2008
    i have the same problem please help
  • Anonymous Feb 26, 2008
    nach der istallation von tt 6 in mein hx2490b ich habe kein ton ?
    bitte helfen
  • thisisshit Apr 10, 2008
    I have the same problem but I can't delete BTcoreif.dll is it claims to be in use.
  • john hercock Apr 24, 2008
    just got a HP 214 same problem no sound on tomtom - bleeps work - how do i delete file Bt Core1f it cant be changed - deleted or replaced in file explorer - help please - upgraded to TT 6.03 screen light noe says on but no voice sounds - voices show up in picker
  • jakeg Aug 26, 2008
    i had a tomtom one xl sound gone off how do i get it bk on
I had the same issues as mentioned installing TomTom Navigator version 7 onto a HP IPAQ 2415 running Windows Mobile 5. As soon as TomTom was installed the sound stopped working.
I did a Hard Reset to restore the IPAQ which got the sound back. I then downloaded the trial version of WinCE Cab Manager http://www.ocpsoftware.com/products.php?nm=cecabmgr and used this to remove the files Btcoreif.dll and Btsdkce30.dll from the TomTom installation CAB. I saved the cab and then ran this again and it installed perfectly and I still had sound. Hope this offers a solution for anyone still having a problem.
Posted on Aug 25, 2008
Guest, do you have mental retardation or a learning disorder? The posters have already stated that they cannot delete the file due to it being in use.
Perhaps you should pay more attention to what has been said
Posted on May 16, 2008
  • Jaye28 May 16, 2008
    You can rename the file to something like: Btcoreif.old instead of attempting to delete it, this should avoid the 'file is in use message'. Now restart your device.
Goto window directory, delete Btcoreif.dll and Btsdkce30.dll files
reset your PDA, it will work
Posted on Feb 14, 2008
I had the same problem with my new 2490b and removed tt6 and then did a hard reset which then got my sound back. I am trying to get a copy of BTcoreif.dll and btsdkce30.dll so that can then reinstall tt6 as it appears that tt6 overwrites/deletes these two files and they need to be reinstalled in the windows directory after tt6 is installed, anyone got this files as have tried to download from various sites but without success. my address is confused@as-ltd.com - thanks in anticipation
Posted on Jan 28, 2008
SOURCE:
I just installed my copy of music creator 4 onto my 64-bit windows 7 computer, but I cannot get the audio to play although I've set up speakers which work fine for all other programs.
This link should be helpful they have an update for the audio. It's a patch that corrected the no sound.
http://forum.cakewalk.com/tt.aspx?forumid=18
Jul 21, 2011 | Cakewalk Music Creator 4
My tomtom is free it turn off by itself and screen goes up and down showing to choose language only. can't go to the navigation applicatio ? Help please
1. open your tomtom as a folder 2. copy all info from tt to a new folder on your computer 3. format tt in fat32 4. download tomtom home and run it 5. make all upgrades that the tthome sais 6. copy the folders with maps and voices from saved ones 7. if restarts or freeze on logo, open tt as folder and delete the file MapSettings.cfg from map folder 8. say thank you
Apr 26, 2011 | Tomtom One XL GPS Receiver
Problem with map. You can't use this map on this device TOMTOM
It sounds like you are trying to use cracked maps and have not patched the .dll file for your TomTom in TomTom Home. Use yDGpatch to patch the .dlls in TomTom Home
May 03, 2009 | Tomtom ONE XL GPS
HP iPAQ 2490B can not be hard reset
remember that you must hold down the two buttoms at the same time then push in the reset for 2 sec (holding it in). release the 2 buttoms then remove the stylus for the reset port. after about 4 sec press & release the reset buttom again, sytem will pwr up. If this doesn't resolve the issue then try the clean reset but bear in mind u will loss any thing u installed on the ipaq as system go to default setting and u will be required to align the screen. good luck
Mar 07, 2009 | HP iPAQ HX2490 Pocket PC
Cannot make TomTom HOME recognize my device
Sounds like you are trying to install tt home from your tt device. Go to the tt website and download from there.
Mar 01, 2009 | Tomtom One XL GPS Receiver
HP 2490B SD CARD
check if your SD is SD HC because it cant read HC
Nov 04, 2008 | HP iPAQ HX2490 Pocket PC
How to hard reset hx2490b
Recovery Procedure for HP iPAQ hx2750, hx2490, and hx2790 Pocket PC Series:
To perform a Hard Reset on the iPAQ Pocket PC by pressing and holding the Calendar and iTask buttons (1 and 4).
2. While holding down the Calendar and iTask buttons, use the stylus to lightly press and hold the Reset button, which is located at the bottom of the iPAQ Pocket PC, for approximately two seconds.
3.. Release all buttons.
4.. Connect AC power to the iPAQ Pocket PC. The handheld Powers On,
performs the normal boot sequence, and automatically restarts system.
Oct 30, 2008 | HP iPAQ HX2490 Pocket PC
Btavui - Error 0x37 opening WAV driver What does this mean? How can I get sound back on my hp ipaq hx2490?
Solution (on my hx2490 wm5): go into file explorer, and enable view all file in the menu tab, then go into windows directory and find btcoreif file, rename it or delete it, then reboot your pda. and voila! problem solved, sound works fine
Oct 02, 2008 | HP Computers & Internet
Upgrade to windows mobile 5.0
1 answer - 2 links:
http://blogs.msdn.com/windowsmobile/archive/2005/10/06/477999.aspx
http://handhelds.org/moin/moin.cgi/HpIpaqRX3715
Aug 04, 2008 | HP iPAQ RX3715 Pocket PC
HP iPaq 3715
is this windows compliant and if it is in the control panel check to make sure that your sound that you use is default set some times this can lead to a no sound usuage
May 28, 2008 | HP iPAQ RX3715 Pocket PC
HP iPAQ HX2490 Pocket PC Logo
4,105 people viewed this question
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
