Question about RCA 20F512T 20" TV
Tv turns on and off all on its own sometimes it even acts like it totally loses power and starts doing a channel search
  • 2 more comments
  • Anonymous Apr 18, 2008
    tv turns on and off all on its own sometimes it even acts like it totally loses power and starts doing a channel search...I,ve removed remote, removed cover, heated and tapped components and cannot make it fail consistently.
    Any Ideas
    Wildman
  • banetto55 Sep 30, 2008
    same problem as above. turns itself on and off...scans looking for a signal when on.
  • Anonymous Dec 12, 2008
    mine just turns on and off no channel seching
  • Mlievore Mar 09, 2009
    The TV will randomly turn on and turn back off again as described above. After upon further inspection I have found an component that looks bad on the circuit board . It has a black/brown spot on the board. So I'm thinking this part is the problem. To be it looks like it could be a on-board relay. I found a part # on the top of it (MZ73LG9RM) After trying to google it and going to various on-line electronics stores searching for the part and having no luck. If anyone can find the part please post something.
Your tv is shot
Posted on Oct 19, 2008
My model 22729 GE Smart Digital Converter Box is starting to lose channels even after a re-scan. Is there a master reset button for it?
The instructions for digital converter boxes recommend periodic rescanning because, in practice, channels tend to come and go depending upon signal strength, weather conditions, etc. The only way to accomplish a "reset" would be to turn off the power and start all over again but you would end up doing a complete channel scan anyway. Oh, and yes, I have had channels disappear even after a rescan has indicated they have been saved
Dec 26, 2012 | Audio Players & Recorders
My sanyo 42in lcd has just started acting up. I changed the batteries in my remote and now my tv turns on and off on its own and will not show a picture or sound. I cannot even change the channels. The...
Remove the batteries from the remote then see if the set returns to normal and you can use the buttons on the tv. If after the batteries are out and the set is still acting upreturns back to normal then the remote is bad, I have seen cases where something has been spilled on the remote and no one was told.
Dec 10, 2010 | Sanyo 42 in. LCD TV
Unable to operate recorder at all.
When you are turning the recorder on it is blocking the signal for cable going to the TV. Your TV will need to be on channel 3 or 4 depending on what the dvd/vcr player channel output is set to. This is why your tv is asking you to re-scan. It is losing the video signal because the dvd/vcr is taking over. The reason why the vcr with the button on the remote is because the vcr button is changing the function of the buttons on the remote to vcr. Even though the dvd/vcr is one unit they still will act like two seperate components independent of each other. They have seperate power buttons and the dvd player part may need to be hooked up seperately with rca cables to work.
Sep 26, 2009 | Daewoo DVRS05 DVD Recorder/VCR
The digital tuner on my Olevia LT37HVS LCD TV freezes sometimes. When it does, you can't change channels, adjust the volume or even shut it off short of unplugging it. All of the other A/V inputs work just...
Tune the tv to a channel that is just blue screen. Then turn the tv off and unplug for at least 30 sec. Then plug the tv back in and turn it on. Then leave the tv on the blank screen channel go into the menu and do auto cable channel search. After the search is complete try all channels. This worked for me. My tv will not scan if the tv is on a channel that comes in. GOOD LUCK these tv's are junk .
Sep 21, 2009 | Televison & Video
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
AKAI PDP4249G Losing Picture and Sound
Sounds like The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 15, 2017 | Televison & Video
Off air digital signal
What brand of tv is it ? You could have a bad tuner or a change in the voltage supply line feeding the tuner . What type of antenna do you have ? outdoor or rabbit ears ? Also does it retain the channel line up or does it clear them as well ?
Feb 27, 2008 | RCA HD52W66 Projection Television
RCA 20F512T 20" TV Logo
87 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
