Question about Graco Quattro Tour Kentshire Stroller
Pakc & play set up
I can't get my pack & play to set up. Each side is suppossed to lock when you pull it up, but I can't get the sides to lock in place.
  • 17 Answers
I had the same problem with the pack & play that I used for my youngest. It turns out that the centerpiece (looks like an extra leg for support of the pad) needed to be pushed all way down, where the leg was resting firmly on the ground, before you lock the sides. When it was time to fold the pack & play back up, you have to pull the middle up first for it to unlock properly.
I hope this helped!
Posted on Jan 14, 2008
Cannot get the grayco pack and play sides and ends to raese back up
did you read the directions? the bottom part needs to not be all the way down when the sides lock open try and pull the sides up with the bottom not locked down then after the sides are up the bottom can be pushed down.
Mar 12, 2011 | Graco - Pack N Play with Newborn Napper -...
I cannnot get the gRECO PACK N play sides to stay up
I have the same one, its quite difficult.
It needs to click & lock in on both sides of the release buttons. Sometimes having somebody put their foot in the bottom of the play yard while you pull up on the release button will help lock it in.
You also need to have the shorter sides lock in first before trying to lock the longer sides in.
Oct 18, 2010 | Graco Pack 'N Play® Playard 9447mch
I can not get the sides to lock-in. What is your suggestion? My play pen is Century Fold-n-go TM Deluxe Care Center.
I think I may know how to solve your problem. I had a similar issue with the pack and play my mother-in-law gave me.
It seems to never work if you set the play pin up right and try to lock the sides up. Tug and pull all you like it just wont do it. I would suggest that you collapse it completely, then try to lock the sides, short first, while the system is either upside down or on its side. Then lock the longer sides.
This is what worked for me at least. I hope this helps. :)
Sep 27, 2010 | Toys
How do you put up a graco pack play
Hi, to set up the pack and play, first latch each of the four sides together. (Each side rail latches together in the middle -- just straighten the rail.) Once all four sides are locked and straight, push down on the center of the pack and play bottom (it's probably red) until it snaps into place.
To fold the pack and play up, just follow these instructions in reverse -- pull the bottom up first, then press in the button on each side rail to fold up each side.
Always make sure the pack and play is completely set up and locked before putting a child in it!
Aug 02, 2010 | Graco 9445DOH Crib
pull and turn the center of it then try to open the side lock. they have to be horisontal from both side of each
Good luck
Sep 09, 2009 | Graco Pack 'n Play
I'm trying to set up a pack and play for my grand daughter.
pull the middle up about halfway. then pull up on the sides.
Jul 15, 2009 | Baby Gear
Problems re opening the Graco Pack N Play - one side won't lock
if so try always from turnig and pulling up the center and then with some help squeeze pulling up the side of each pack. then try to push everything down.
it's treaky and coming back blocked very fast. you have to manage all of them at the same time
Good luck
Pls let me know if I helped
May 26, 2009 | Graco Pack 'n Play
Directions to set up a pack n play crib
you have to pull the sides up and lock them before you push the bottom down
Dec 27, 2008 | Baby Gear
Cosco Playpen
My wife and I have the same model for visits by our granddaughter. She was having the same trouble as were you and, like you, we did not have instructions.
I'm happy to share with you what I found to close the model up for storage. It may not be the same as what the manufacturer envisioned but it worked for us.
-- With the pad removed from the inside of the Pack n Play, pull up on the red handle so as to loosen the legs;
-- Next, you will find there is a big button in the middle of each of the long sides of the Pack n Play. Start with either long side. You will have to press very hard on either side of that button; I found it helpful to use both hands, one pressing on the outside of the playpen, the other hand pressing on the inside of the playpen. Pressing these together will loosen the long support arm at the open top of the Pack n Play.
-- Do the same for the opposite long side.
-- You will also do the same, one button, one side at a time, for each of the two short sides of the Pack n Play.
-- Now pull up on the red handle in the middle, and guide the four corners so they meet and close.
-- Cover.
I found the buttons may not have fully allowed the support arms to collapse, thus blocking the Pack n Play from folding down completely. If so, try pressing the button again (both the outside and the inside at the same time).
By the way, I've found it to be an exercise in frustration in trying to obtain an instruction manual from the manufacturer. I'm very disapopinted with this purchase and in particular this company.
Hope this helps!
Jul 01, 2008 | Cosco Beatrix Potter Playard Crib
Graco pack and play sport
I saw the solution on the Graco site. I was putting the bottom of the Pack and Play down first, I found out you need the do the sides firstl
Apr 27, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Graco Quattro Tour Kentshire Stroller Logo
125 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
