Question about Standard (CRT) Televisions
No sound This Tv has no sound. The output amplfiers are operating but there seems to be no input to the TDA1013Bs. This is an AIM AFG 72 TV. The chassis number is 60-L0749620-01B and/or SH-22 92V0.
5 Suggested Answers
  • 1694 Answers
SOURCE: Sony KV-27FV310
Component In is not converted to composite out (yellow)
TV monitor out normally goes to A / V receiver in......T.
Posted on Nov 18, 2007
SOURCE: lost remote to 27in rca tv, how can i switch my tv to input/output mode so i can watch movies on my dvd playter?
channel 91 was my av channel mad random but whatever it works heh
Posted on Jun 26, 2008
  • 5 Answers
i need change my tv to input or output vidio.
no sound, no picture but tv is on
Posted on Feb 07, 2009
  • 255 Answers
SOURCE: Yellow input/output cable broken off in TV
you can use a screw small enough to fit in the middle of the tip of the cord.the tip is hollow so just remove any plastic or hard rubber that is clinging on the said tip.(use a big needle for this.)be careful when doing this.make sure that the unit is turned off and unplugged.after inserting the small screw,slowly twist and try to pull it gently until the screw is tight enough but not breaking, to pull the tip.
Posted on May 13, 2009
  • 26 Answers
SOURCE: Orion tv without input/output plugs
from the looks of the picture you have one audio video input port on the front of the tv. The connectors are yellow and red or yellow and white. Yellow is video and red or white are audio. Find those same connectors on the back or your dvd player, hook it up to the tv and there you go. You'll have to go to game mode or input 2 on the tv to see the dvd player.
Posted on Jul 01, 2009
0 characters
1 Points
I have Daewoo tv model # DTQ-20U6SC. The sound is just low. I'd like to know what the problem is.
Any sound problem can be confirmed only if the signal is traced and identified so as to confirm the section. You will need an AF- audio frequency - generator to inject and confirm the section where the amplification is low .
Also a check on the pre-amp output and a signal to the INPUT can confirm the output amplfier.
Finally check the speakers, test with a working speaker.
Sep 25, 2011 | Daewoo DTQ-20U9SC TV
I am attaching a digital set top box to this TV Model C21F200 and have a video/dvd player to attach as well. I can't seem to get both working. Can I tune the video to the TV with the set top box attached?
If your TV has AV inputs available, you can connect the video player there and switch to that input to watch it. I don't think your model does, though; I think it has only an antenna input connector. This means your set-top box will connect there but you have no place to connect the video player. In fact, most new video players only have AV outputs, and don't have an RF (radio frequency - a channel 3 or 4 TV signal) output connector, and you'd have problems connecting it anyway.
All is not lost, although you'll need some extra parts to hook everything up. I'm assuming the set-top box (STB) is going to your TV on channel 3 or 4, using a cable from the box to the TV antenna connector. If your video player does indeed have an RF output, the simple thing to do is get a splitter. They look like this:
Normally, a splitter is used to break one input signal (into the single connector) into two outputs (the connectors on the other side). But you can also use one backwards to combine two sources. So you can connect the RF cable from the STB to one output jack, connect the video player RF cable to the other, and connect the "input" side of the splitter to your TV antenna jack. If your STB is set for channel 3 output, set the video player for channel 4 so they won't interfere. Then you can tune the TV to channel 3 for TV signals from your STB, and to channel 4 for videos. I know, it sounds confusing.
If your video player doesn't have RF output, but just video and audio outputs, you need an RF converter. This device takes the AV output from the player and generates a channel 3 or 4 RF signal the TV can tune in. A typical converter looks like this:
Connect the AV outputs from the player to the jacks on the converter. The output cable from the STB will go to one of the round antenna connectors on the right, and the cable from the other one goes to your TV. When you aren't playing a DVD or tape, the converter passes the signal from the STB through to the TV. When you turn on the video player, the converter switches and you'll see the picture from the player. Most converters switch automatically, but on some you might have to flip a switch. RF converters are available from retailers who sell TVs or online.
I'm sorry if this seems unnecessarily complicated, but most TV sets today have plenty of inputs for all these things, and usually you just plug in the connecting cables and go. But with older sets or sets that don't offer the inputs, you need to go through these shenanigans. But once you have the parts hooked up, it's not too bad.
Hope this helps, and thanks for using Fixya!
Jan 01, 2011 | Hitachi C21-F200 21" TV
No audio
First check tv menu and make sure tv speaker option is On.
If tv does not give sound in any input like cable channels, dvd playback etc then sound output chip seems defective and need to be replaced by tv repairman.
Hope these info will help you.
Let me know if you have additonal question.
Nov 03, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Audio output on TV
Sounds like you have it hooked up properly. Be aware that if there is not a digitally encoded signal for surround sound [they don't always do that] you simply won't have surround sound. Usually there is a mode in your receiver/amplifier that will allow you to simulate surround sound. An example of that would be "theater" or "hall" sound. Try it with a DVD known to have surround sound encoding [most of them do] and see if it works that way. If it doesn't then check your owners manual for information about how to make sure that feature is actually turned "on".
Apr 16, 2010 | iLO Standard (CRT) Televisions
Toshiba CN36X81 television.. NO Sound... Great Picture. Using the TV2 output of a DISH Network HD receiver... TV2 output is std def, coax output. Using a different TV I get picture and sound... but not...
IF coming in via, the "Dish" networked receiver, please check that this volume is turned way up, on the TV. and then control the the Volume, with the Dish Remote, often this is a problem, as one is turned down, and the other cannot turn that up, simply try syncing the Volume controls, UP on TV, control the Audio with dish remote. thats all i can think of. Check by feeding a signal IN from an AV, source, ie: Yellow, Video, & Red& White, Audio. Turn TV UP and check, IF it responds to this all is well. If NOT then you do indeed have a fault, with the TV.
Mar 27, 2010 | Toshiba CN36X81 TV
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Standard (CRT) Televisions
Unusable signal prompt on video input
be sure to cycle thru the input selections-- either w/Remote (input button), or channel +/- on the panel. my truflat 26" hd set has side/front/video1 video2 inputs, yours may have more or less. also, be sure you've plugged into an INPUT set, not an OUTPUT set. Does sound work otherwise on this set? If not, maybe interal speakers (menu setting) is set to off/not checked.
And on your PS3--goto the settings menu, sound outputs, make sure you select A/V connector and analog sound. The ps3 cable can become sloppy too, wiggle/check/reseat or try another cabe (usually video is touchy more than the sound though)
If you KNOW you've got the right input selected and the PS3 is setup properly, do you have another device with audio output to test on the TV? a notebook computer, walkman, cd player--anything that has rca outputs for sound--quick swap the cables to the new 'test' device-- if sound is OK with test device, either PS3 setting or cable is bad/wrong. if no sound from test device on TV either the tv is not using proper inputs, or is damaged, or the test device is not properly configured. If you have another input receiving device to test the ps3 output sound, like the LINE INPUT on a notebook computer, or a boombox with Aux inputs, test the PS3 sound output too.
Jun 08, 2008 | RCA TruFlat 27F520T 27" TV
No sound on my toshiba television
just be basic....dvd is ouput goto tv the color yellow to yellow ,red to red etc, got tv ,look for audio output to anything input to home theatter etc.if u hook in to aux set home theater to aux etc, input to output and output to input ok? hope i help u..
May 08, 2007 | Toshiba CN32G90 TV
Tv sound
input try connecting a adio Y adapter to the audio output connection in the back if there is only 1 audio output but other wise the answer to your question is no
Dec 08, 2006 | Philips Magnavox 20MS233S 20" TV
Standard (CRT) Televisions Logo
21 people viewed this question
Top Standard (CRT) Televisions Experts
matt martin
matt martin
Are you a Standard (CRT) Television Expert? Answer questions, earn points and help others
