Question about GPS
Garmin nuvi 360 went goofy
My garmin was working great and then i download off their site and now it is goofy. nothing works.
HOW CAN I GET IT BACK TO FACTORY SETTINGS WHICH WORKED WONDERFULLY?
  • 6 more comments
  • BOB TOPPER Jan 13, 2008
    so what do i do with the reset button and then after that?
    i want to get my nuvi 360 back to factory settings since i downloaded updates from the garmin site it does not function
    trying to reset my garmin 360 to factory or default setting. got as far as main screen with question 'do you really want to start maintenance mode" but when i said yes, nothing happend.
    help
    still having the problem nothing has worked yet any body any help?
    when i do the 'do you really? yes? nothing happens but i can hit and accept no - problem. then when the enter your pin comes up it will not accept my code,,,actually, when i press one number, another number all together lgits up. when i hit #3, it actually erases the last digit.
  • BOB TOPPER Jan 14, 2008
    you seem to know what you are talking about. garmin said i cant log in bec it is out of calibration. told me to go to my security location, open the antena at a 90 degrees, turn on the unit. it will reset itself and when the screen with tools comes on go to recalibration. i am concerned 1. there is more to it than that since all of this started after downloading crap from their website (tech said "coincidental") and 2. when i touch tools (if it gets that far) that it wont take the touch.
    firmware, heck, i cant even get into unit to accept anything. their is no 'firmware' to download via computer.
    just want to recalibrate (how can i if every prompt i touch enters a different command and to go back to factory settings. i would gladly start all over again with my personal info if it would work right
    President:
  • 317 Answers
Holding the mark key down while powering up will totally reset unit. You will lose all user supplied data and preferences. The machine will be set back to factory defaults. Be careful, there is no warning message. All data will be lost!
After you perform a full reset you will need to allow the unit to collect a full almanac before normal can be resumed. First a fix will need to be obtained which can take from 5 to 10 minutes of leaving your unit outdoors, stationary, with a good sky view. After the first lock you will need another 12.5 to 15 minutes to get the almanac reloaded. Check the date to insure that the information was reloaded properly. Time will be shown as UTC time since your local time offset was lost in the reset.
Posted on Jan 13, 2008
  • Peter Burns Jan 13, 2008
    "mark" is the second key down on the right hand side of the unit. It could also be called the "option" key.
    President:
  • 1,944 Answers
What do you mean when you say goofy? How is it functioning? Did you use webupdater to update your firmware?
http://www8.garmin.com/products/webupdater/
Or did you download the firmware?
http://www8.garmin.com/support/download_details.jsp?id=1847
After you reset by the reset button on the back of unit, under the flip out antenna, what happens? Is the unit still "goofy"?
You can also try to hard reset the unit.
Here is how you can perform a hard reset to clear all your waypoint memory:
MAINTENANCE MODE:
Step 1. Turn your Nuvi unit off, remove any SD cards from the SD card slot and make sure that the unit is not plugged into any computer.
Step 2. Place a fingertip on the upper left hand corner of the touch screen and keep it there while turning the unit on, a prompt should read " Do you really want to start in maintenance mode?"
Step 3. Select the yes button.
Step 4. Enter your PIN if enabled.
Step 5. Main Maintenance Mode screen should have 4 selections:
System information
View Diagnostics
Clear User data
Clear Waypoints
Step 6. Choose "Clear Waypoints". After some time the unit should reboot.
Let me know what happens.
  • 1 more comment
  • Damen Wong
    Damen Wong Jan 13, 2008
    In step number two, if upper left corner doesn't work, try the lower left corner.
  • Damen Wong
    The code youa re entering...is it the code you set in the unit?
  • Damen Wong
    Damen Wong Jan 14, 2008
    What happens when you try to run this update?
  • 2,427 Answers
Ok you need to get back the firmware you originally had ,,
then reinstall it,,
However in the event it wont downgrade it self you can use the hpformat utility to remove it..
to regain the oldfirmware contact the manufacture and ask for the firmware, It might also be aviable on their web page..
  • 1 more comment
  • Rishi Roshan Ali Jan 13, 2008
    Hey .. I believe that your firmware is corrupted thgats why you can reset it and the numbers are all mixed up :) to solve this we need to get this firware out of it and put back in another one..
    Download the firmware and update it,,
    If you cant update it or it can revert back to your old fimwarem you can get the original firmware at the manufactures download page or you can request it from them..
    If you cant get the firware in download hpformat utility and format your SYSTEM ... WARNING THIS WILL RENDER IT USELESS until you reinstall another firmware..
    i see otacon gave you specifics on where to get it, and there is information there on how to use it,, TRY AND AND LET ME KNOW WHATS HAPPENING..
  • Rishi Roshan Ali Jan 14, 2008
    Did you try my last post COMMENT 2 ,, with the firmware suggestion ??
    Scholar:
  • 128 Answers
Here is the owners manual. This is in a pdf form so you have to have adobe reader for this. Click Here
  • Omair Chughtai
    Omair Chughtai Jan 13, 2008
    Alright, to reset your GPS, you have to raise your antenna, and there will be a reset button on the back. :)
My garmin 1300 went completly dead while on a route with the power cord attached. Unpluged tried again . Now its working. Is this normal?
A Garmin Nuvi 1300 that won't start, freezes on 'loading maps,' or is acting erratically is symptomatic of having corrupt firmware.
To correct this, I recommend backing up your favorites, clearing all user data, and if it still is stuck, then updating your Nuvi firmware.
Follow these three steps to take to get your Garmin Nuvi 1300 running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
_______________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Hard Reset
Garmin Nuvi 1300 Webupdate
May 15, 2010 | Garmin nuvi 1300 Car GPS Receiver
THE UNIT WILL NOT TURN ON
A Garmin Nuvi 1300 that won't start, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
My garmin 1300 went completly dead while on a route with the power cord attached. unpluged tried again . now its working. is this normal?
A Garmin Nuvi 1300 that won't start, freezes, or is acting erratically is symptomatic of having corrupt firmware.
I hope that helps.
Mar 27, 2010 | Garmin nuvi 1300 Car GPS Receiver
Nuvi 1300 squeal
I hope that helps.
Jan 06, 2010 | Garmin nuvi 1300 Car GPS Receiver
My Nuvi 200 screen went black. I've tried turning
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Oct 28, 2009 | Garmin nuvi 200W GPS Receiver
Need to update my garmin Nuvi
I went to the web site. For a update there wasnt much of one. Its a firmware update. And you need to have the unit hooked to the computer. Mine automatally went to the site and got a list of things you could update, but in my case there was nothing to download. But the web site for the GPS has all of the answers
Jun 19, 2009 | Garmin nuvi 200W GPS Receiver
Can not install Gamin USBdrivers_221
Download a tool from the Garmin website call Garmin Express, all will work then.
Jul 06, 2017 | Garmin Nuvi 360 Bilingual GPS Navigator...
Nuvi 360 Stuck on loading maps
Have you reset the unit yet (little pusbutton behind the aerial)
Jul 30, 2008 | Garmin nuvi 350 GPS Receiver
GArmin Nuvi 360 - bluetooth not working right
Wow, as soon as I got my nuvi 360 I turned the Bluetooth off. I then updated to 4.40 and the bluetooth SW version is now 0.00 and i cant even enable the bluetooth again. I think we have the same problem. I wish I could help but I am in the same boat.
Dec 24, 2007 | Garmin Nuvi 360 Bilingual GPS Navigator...
GPS Logo
123 people viewed this question
Top GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
