Remote control doesn't work. when tv unplugged for a few days, it worked again, then quit. universal remotes don't work either. is it most likely the remote receiver eye? what to check? what to do?
Thanks, Kurt
If u can get to the INSIDE front, clean the window of the receiver eye.(of cause the outside also!) If the wires going to the board can be unpluged, unplug, the push it back in. Possable that the receiver eye circuit is too heated up.Put a small (square boxed computer type fan) in the back of the tv to cool it down some.If u know how to "glue" a HEATSINK to the chip to get rid of the heat, may help.
note: it is possable that BOTH regulor and universal r/c are intermittance (sometimes works, sometimes don't work)
The flashing blue light shows that the TV is receiving I.R. from the remote but doesn't mean that the signal being received is recognized by the Samsung. If you have a "universal" remote then your TV code may need to be re-entered/reprogrammed...changing batteries in a "universal" will usually require it to be reprogrammed. Also...because of the remotes construction (rubber membranes with carbon dots that short across PC traces) I've seen certain buttons stop working altogether.
