Question about Baby & Toddler Car Seats
Swift Island Tiree 2000 main door is sitting slightly out and i can see daylight at the top of the door. can you help?
0 characters
1 Points
How do I know when to buy a bigger seat or which positions?
His legs bending does not mean that he is too big for the seat. He is too big for the seat when his head reaches one inch from the top of the chair while sitting in it.
Please read the information in these links for further information:
Nov 18, 2012 | Cosco Scenera Convertible Baby Toddler Car...
I can't adjust the straps
Hi Selina - Instructions are in your user manual on how to adjust the harness height. When the harness is correctly adjusted for your daughter the harness pads should sit comfortably. If you need to download a replacement user manual select the carseat you have then click "Service" at
Nov 29, 2011 | Maxi-Cosi Axiss Reflection Booster Car...
I took the straps off and can not put them back, can you help?
The Long strap goes under the seat and comes up thru 2 holes (each end goes up thru each side). The holes are on each side of where the child sits. They come up and weave into the latches that snap into the **** clasp. Upward toward where the child's head would be they go thru the chest clasp. Look at the writing on the clasp to make sure it is on right (letters read the name Cosco and arent upside down) and the belts should be behing the clasp (in at the bottom of the clasp and out at the top). Up thru the holes on the back of the chair at the height appropriate for the childs body. Out the back and down to the claw that is on a strap under the front that you can pull to tighten or press to release slack as the child gets bigger. There should be 1 or 2 (usually 2) slots for the ends of the straps to be slid on to. Sit the child in the car seat and adjust the belt system so that a finger can be slid between the belts and the child's shoulders. This should do the trick. Good luck and be safe.
Mar 18, 2011 | Cosco High Back Booster 22-200 /22-207
When installing the forward facing booster seat do you not hook in any of latches to the seat? We have model #22-757-MRC. My children are over 40 inches so I am swithching them to the booster seat. My...
your child's weight and the lap & shoulder belt hold the seat in place.  Run the lap part across your child's lap and the shoulder part should cross your child's chest and not cross his/her neck.  There should be some slots on the side near the top to allow some adjustment of the shoulder strap.
Sep 06, 2009 | Baby & Toddler Car Seats
My rear facing infant car seat tips over. My car is a 2000 Toyota Camry without the lower latch in the seat. The seat belt gives a little but locks in an emergency. The baby is not yet 20 lbs.
if it is an infant seat with a base, and can be used without the base, I suggest using it that way. We had the same problem with our daughter's car seat. sometimes those bases just aren't stable enough. Sits much more secure if you can use it without them.
Jul 16, 2009 | Baby & Toddler Car Seats
Renault clio airbag in seat
i hit the kirb in my clio and the airbag passanger side in the seat went off. also had a bit of trouble with it starting a few wks before. it wouldnt start then 2 -3 hrs later would ??? any simmilaritys scared the living daylights out of me
Jul 01, 2008 | Baby & Toddler Car Seats
Sharp Atomic Clock Daylight Savings
I have misplaced the manual for my sharp Atomic clock, need to reset the time zone and shut off the alarm. How can I obtain a new manual?
Mar 10, 2008 | Baby & Toddler Car Seats
My clock wont find the time.
I had to press receive on the back of mine until the satellite icon appeared on the top right. It's keeping time correctly now.'s the wrong time zone. We tossed the manual the other day so I'm stuck in Pacific Time instead of Eastern. Hope the top part of this helps. Tom Cassidy
Headrest removal
trying to take of the cover of the car set where my baby sits becues it wet for i can wash it do you know how to take it off
Nov 29, 2007 | Baby & Toddler Car Seats
Baby & Toddler Car Seats Logo
16 people viewed this question
Top Baby & Toddler Car Seats Experts
Level 1 Expert
Jennifer Rock
Jennifer Rock
Are you a Baby and Toddler Car Seat Expert? Answer questions, earn points and help others
