Question about Creative Labs Sound Blaster Audigy LS Sound Card
Vista 64 microphone not working
Brand New computer ---Computer - Intel Quad Core CPU Q6600 2.0 GHz
2046 MB
64 bit VISTA Home Premium
I spent 6 hours yesterday attempting to use microphone. I have tried all of the usual suggestions -- making sure mic is not muted, making sure it is default, increase sound levels -- Microphone does not work.
I listed Sound card below -- but actual one is SB Audigy SE
  • 49 more comments
  • lilbitter Jan 13, 2008
    Not a good plan --There is no entertainment section under accessories (this is Vista)-- I could not do any of that work
    On the speech recognition tab -- it does not record my voice at all.
    Problem still exists
    I get sound from media player etc. The sound card is working.All of the links in the post were dead. I have configured the microphone but the lines remain gray not Green to indicate working. Still no sound
    No GO
    YES -- although the original one worked with my old computer. I tried a headset version -- still no go
    Went to devices --found sound card -- no yellow anywhere -- states all is OK. Still no sound- Mic is in correct slot etc.
    THERE
    I see Mic, Line-In, Auxiliary, S/PDIF In and What U Hear -- Tried speaking --lines stayed Gray
    Ok Set to correct card but JACK says no information available. It is enabled
    THere is no 44100 cd level -- it is set to 48000 DVD quality -- Both options are on
    It was set to 100 -- i had moved it but I put it back at 45
    Ok -- Did it -- Nothing
    When I read the statement nothing happens -- it does Not recognize my voice
    It takes 2 seconds -- I get to the second page -- i slection microphone -- moves to the page to read line -- and then nothing
    I'm there
    YES
    two choices mine says use preferred audio input
    Nothing is highlighted -- I clicked on other choice and it goes to my sound card
    Did IT
    No nothing Happened -- I was Very hopeful
    Lists all the input options Mic Line-In Auxiliary S/PDIF In and What u Hear
    None of them worked
    That is what I just Did no activity anywhere
    None of them light up the properties or volume buttons
    I did that 3 of the devices state no volume meter for them -- Line-In , What U hear and S/pDIF
    The volume meter never lights up
    Microphone(SB Audigy)
    Line-In (SB Audigy)
    Auxiliary (SB Audigy)
    S/PDIF-In (SB Audigy)
    What U hear (SB Audigy)
    orange green blue are connected to my sound card
    Yes Microphone (SB Audigy)
    Did that
    To the Top? Confused
    Ok only default speech is there under profiles -- I clicked configure
    THERE
    I'm ok -- ready to go
    Tried both -- nothing
    Next Page tells you to place it a nice distance from mouth
    Next page asks you to read a line -- nothing happens -- so it goes no where from there
    stereo -- may have one
    NO mic jack in stereo or boom box -- but this was working 3 days ago in my old system. I also had tried my headset version that also was working in old system -- both can't be broken
    Done
    I shut them off
    On record side -- all 3 are a go (auxiliary, line-in , mic)
    on playback side only mic is on)(others are off - Line-in, Auxiliary, S/PdIF)
    Yes in mixer listed in both record and playback
    It has a red + sign --- How check if muted? When click on red + see (Do Not Monitor)
    How set it up here?
    Saw that in other set up page -- under microphone properties -- custom -- Do not Monitor is not checked
    The do not monitor is NOT checked anywhere
    Yes Green circle checked
    there is a blank square that is not checked -- next to it is the statement Do Not Monitor
    You want me to check it?
    Configuring nothing happened
    tried both ways no success
    Are you running out of ideas -- Man it is so frustrating
    HIT WRONG BUTTON Please Continue Helping
  • Anonymous Mar 12, 2009
    I have vista 64 sytem with brand new pc & microphone. Micro phone doesnot work. Tried all the thing the previos person
  • 2,427 Answers
Hmmm did you try a different mic, and exure its jacked into the mic in of your sound card.. If you have dual sound devices, ensure its in the correct selected device...
1.)To see which device you have as the selected device, Click Start, All programs / accessories / entertainment, volume controll..
2.)Choose Options and then properties
3.)In the mixer device drop down list, ensure that the correct device is selected. Click on the drop down list to see all aviable devices..
4.) Now under the Adjust Volume For selection select recording
5.) In the Show Following Volume Controll Box, select Mic,(make sure its ticked)
6.) Click Ok
7.) The mic and aother controlls will show up, under mic ensure select is checked..
NOW TEST YOUR MIC..
1.)Start, All programs / accessories / entertainment / Sound Recorder
2.) Click Edit then Audio Properties
3.) Under Sound Recording Select the Appiorate device..
4.) Click Record and try it..
5.) Stop it and play it back..
IF THAT DONT WORK REPLY HERE AND WE WILL HAVE A LOOK AT THE DRIVERS..
Posted on Jan 13, 2008
  • 57 more comments
  • Rishi Roshan Ali Jan 13, 2008
    WAIT I JUST REALISED ITS VISTA YOU ARE USING sorry
    1;) Click On The Speaker icon to bottom left of your screen
    2.) Then choose mixer
    3.) Click Device and ensure you have the correct device selected
    4.) Slick Start And control Panel
    5.) Click Recording
    6.) Click Microphone and click onfigure
    7.) Click Set Up a Microphone
    8.) Follow the on screen instructions to completion..
    LET ME KNOW IF IT FAILS
    This Is the same method for vista
    5.) Click Recording
    BTW did you try a differnt microphone...
    Ok .. Lets repair all the necessary drivers,,
    1.) Reinstall the drivers that came with the Sound card.
    2.) restart the system
    3.) Click Start, Right click on computer
    4.) Choose properties
    5.) click Device manager
    6.) In the tree view click the + next to Sound video and game controllers
    7.) If anything has a yellow symnoy or is highlited yellow, it means that driver has a problem , right click and click update driver..
    If all is fine, by all means it should be working..
    except
    1.) if the microphone is bad or not connected correctly
    2.) if it is set up wrong
    3.) if the card has a problem
    Try setting up the mike as the process i described above
    Ensure it is connected and the correct sound device is selected as above ...
    If Its still no go let me know and we will walk through it step by step and solve any problems as we come across them...
    I am leaving this page open and will refresh it every 1 minute so we cant interact as a real time chat :)
    Ok click Start then control Panel
    Click Classic View then the sound icon let me know when you are there
    Click on the recording tab
    you should see 2 devices
    a Mic
    and A Line In
    There should be some bars next to the mic do you see them,,
    speak and see if it changes,,, Most likel not but still try it, Let me know when thats done and the results
    Ok Click The Mic and then Click Properties..
    In the general tab you should see Controller Information
    ensure it is set to your sound card
    And you should see jacj information , Ensure it is correct
    And under that is device usage, Ensure it is set to enable..
    Let me know when your are done and the results
    BTW YOU CAN JUST CLICK THE REFRESH BUTTON EVER 10 - 30 seconds I will be right here
    You said you are certin the microphone is working and is connected propperly !!!! ok
    Click Advance and under default format ensure it is set to 2 channel 16bit 44100 Cd quality
    And under exclusive mode turn on both options
    ok well we could work with that, i wanted a lower quality to take less resources but thats fine...
    next click Levels and ensure its set to 45 and it aint muted
    Ok now close that off and then click mic and then configure
    In the configure box click set up microphone
    What you mean nothing ??
    You went throught the entire process already ??
    Ok well close that off and go back to properties
    Actually close of the properties as well Lets do this manually
    Click bac on configure and then choose Advanced speech options
    U there yet ??
    Ok to the buttom of the Dialoge box there is MICROPHONE
    with 3 buttons
    Audio Input
    Advanced
    Configure Microphone
    Click Advanced and tell me what yours say
    and what device is it set to ?
    Ok click use this audio device, set it to your sound card mic(or what ever card you got the mic connected too) and click ok
    there is a level bar next to the microphone ,, speak and see if it moves
    yeah me tooo....
    ok we aint giving up yet...
    was there ainy other devics in the Advanced options ?
    when you clicked advanced and use this audio input device was there any other devices in the list
    if there was try of them and let me know what happens
    Ok the level bar has not moved and we tried all the devices
    Click Back on advanced and then select Use this audio input device,,
    Select 1 by and until you see properties or uolume active and tell me which one does that
    you might need to click ok and then click advanced again to see if any changes were made
    Ok list all the Devices for me, FULL NAME ...
    Well the problem we are having currently is that we cant find an appiorate device for the mic....
    How many jacks you git in the back of your system 3.5 mm and color
    specify on board and sound card seperately
    and there was no microphone listed in the devics input list ?
    Ok select that
    as the Use this Audio Device and click ok
    To the top how many Reognition Profiles you got.. Delet all And just leave Defaut Speech profile
    Now click Configure microphone and wait for my instructions do run through it wait and lets do it in detail
    Let me know when you are the first step
    NO :)
    beneath where youe see Microphone there are 3 buttons
    Audio input, Advanced and Configure .......
    above that is User settings
    and above that is Recgonition Profile :) do you see them
    Ok
    What type of microphone you have,,, ??? i am sure u tried that already, but try it again and if that dont work the next time select OTHER
    Fullow the rest of the instructions and let me know what heppens
    Do u have a radio with a microphone input ??
    Jack the microphone in it and see if it works,,,
    I just want to be certin of something
    Ok to the buttom right of your screen is a speaker icon
    right click on it and choose recording devices
    Click Mic, Click Properties,
    Click the advanced tab
    and turn off all Exclusive Options
    Close that off,,
    Click the speaker again, (left click)
    choose mixer
    does it show up there (the mic)
    Dies your microphone show up in the Devices
    On the recording side, ensure mic is selected (activated) and it isnt muted and selected as the input device
    Ok try setting it up there nnow
    Set up the microphone
    Let me know if it works..
    Hmm thats strange...
    see if there is an option to turn on monitor,,, Thats what we need to get it to run cocurrently..
    You can try right clicking as well...
    To set up, go back into control panel, click sound , click recordings, click Mic and then click Configure..
    DOES MIC have a green circle with a white arrow tick to the lower right corner of the icon
    Ok go back to it and turn on monitor
    WHEN YOU CLICK ON sound and then recording, is there a green circle wth a white check on the lower right corner of the mic icon ??
    Ok click configuer and set up the microphone
    no leave it this time be, if it dont work go back again and check it.. and then repeat the setup
    Ok go back and check the box and try again
    Well based on what we have dialouged your softwre settings is accurate
    there could only be 2 other problems
    1.) windows vista is corrupted and your system needs to be formatted and everything reinstalled
    or 2
    hardware failure
    eighter from both microphones or your sound card..
    What you can do is jack the microphone into another device or system and ensure it is working,,
    Try the sound card in another system and ensure it is working
    and if both are working it means windows needs to be formatted and replaced...
    you can try jacking your microphone into a Headphone jack like an mp3 player and see if you hear anything (some microphoes this works with not all )
    Actually everything that could have possibly gone wrong with your setting we have checked and verified.. based upon our dialogies its more acurate then all other systems...
    Do you have another pc you can try the sound card on..
    Or a way to test the Microphones
    I am :)
    did you read the last 2 comments ?about hardware ??
    ARE YOU THERE ????????????????????
    Refresh page in half and hour,, i am going to make a few phone calls in case i missed anything
    WELL FRFOM THE Dilogue we had iand information i was given, its safe to say that all your settings are correct amd we tried everyting we could at the time.. It is hardware eighter your microphone or your sound card..Verify that they are working in another system , if they are then its your windows vista instillation. you will need to format and reinstall..
    personally i believe its with your microphone. please verify that they are working.. post back here after you have tried that above and let me know whats happening....
  • 170 Answers
ASSUMING THAT YOU HAVE INSTALLED ALL THE AUDIO DRIVERS & data provided by you
if you can hear the audio from any other files i mean mp3 files then the sound card is perfect.
-ensure that the microphone is properly connected into the right port.
-check the microphone you can check it in windows movie maker while recording audio.
Possible speech recognition problems
If no sound is detected after testing the system (see Troubleshooting Speech Systems), consider the following:
  1. The microphone is muted. Some microphones have an external control for muting. Make sure the mute is turned off.
  2. The microphone input level is set too low. On the Speech Recognition tab, select Configure Microphone. Follow the directions in the subsequent Microphone Wizard to set the input level.
  3. The microphone may not be selected as the current input device. On the Speech Recognition tab, click Audio Input to make sure that the microphone is selected.
  4. It is possible that the microphone connections are not properly secured. Make sure the microphone wires are intact and unbroken. The connections to the computer may be loose; unplug the wires and reconnect them making sure they fit snugly. See Set Up a Microphone for additional connection information.
  5. Check the documentation for the microphone's hardware for information specific to the manufacturer. This may include making certain the sound card for the computer is also properly seated, installed and that the correct drivers are available.
  6. The SR engine may be corrupted. To test for corruption, switch to another engine if you have one. See Changing the SR engine. If the other engine is working properly, reinstall the specific engine from the original source. If no engine is working properly, reinstall the SAPI component from the original source or CD.
  • bharath m
    bharath m Jan 17, 2008
    hey i think there is some problem with the micro phone
2 Suggested Answers
  • 2427 Answers
SOURCE: Microphone trouble VISTA
CLICK REPORT ABUSE ON YOUR OTHER POST AND TELL THEM THAT YOU MADE A MISTAKE...
THEY WILL REFUND THE MONEY :)
hold one sec let me copy and past the last 3 post so we can continue..
Contact form
i want the password to be dominic20
Sep 18, 2013 | Acer Extensa Computers & Internet
Why does my Dell Inspiron 530 freezes up after being on for a few hours?
Check your battery status. It is possibly overheating whitin time and causing malfunction.
Oct 25, 2012 | Dell Inspiron 530 Desktop Computer
C language for 64-bit operating system for windows vista ultimate
just type this line in google there are many option download it
Jan 13, 2010 | Microsoft Windows Vista Ultimate Edition
System requirements of vista
For Vista Home Basic >>>
  • 1 GHz 32-bit (x86) or 64-bit (x64) processor
  • 512 MB of system memory
  • 20 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics and 32 MB of graphics memory
  • DVD-ROM drive
  • Audio Output
  • Internet access (fees may apply)
Additional requirements Actual requirements and product functionality may vary based on your system configuration. Windows Vista Upgrade Advisor can help you determine which features and edition of Windows Vista will run on your computer.
While all editions of Windows Vista can support multiple core CPUs, only Windows Vista Business, Ultimate, and Enterprise can support dual processors.
For Vista Home Premium, Business and Ultimate >>>>>>
  • 1 GB of system memory
  • 40 GB hard drive with at least 15 GB of available space
  • Support for DirectX 9 graphics with:
    • WDDM Driver
    • 128 MB of graphics memory (minimum)
    • Pixel Shader 2.0 in hardware
    • 32 bits per pixel
  • DVD-ROM drive
  • Audio Output
Home Premium / UltimateTV tuner card required for TV functionality (compatible remote control optional).
Home Premium / Business / UltimateWindows Tablet and Touch Technology requires a Tablet PC or a touch screen.
UltimateWindows BitLocker Drive Encryption requires a USB Flash Drive and a system with a TPM 1.2 chip.
Windows Vista minimum supported system requirements Home Basic / Home Premium / Business / Ultimate
  • 800 MHz processor and 512 MB of system memory
  • Support for Super VGA graphics
  • CD-ROM drive
Regards.
Sep 21, 2009 | Microsoft Windows Vista Ultimate Edition
I want an upgrade on my video card...
more cpu and a better graphics card, id say get a amd athlon x2 dual core [Cpu]
And a Nvidia Gefore 8800GT
May 28, 2009 | Computers & Internet
Vista HELP
with the 64 mb graphics card i dont think that u can run VISTA if u want to run Premium version u need to get a higher graphics card atleast 128 Mb or above and for 1 gb graphics card pls check the manual of ur card first b4 buying it bcoz ur mother board may not support it but its a rare case when this happens but pls check b4 buying or let me know with the exact brand and model u r going to buy i will check it for u
pls rate me fixya if i have answered ur question
Mar 03, 2009 | Intel Celeron D 325 2.53GHz 533MHz 256KB...
32 bit program to 64 bit opperating system
From the Autocad webiste:
System Requirements AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements Recommended configuration (excluding server components used with project management capabilities):
  • Intel® Pentium® 4 (3 GHz or higher); AMD Athlon™; multiple processors supported, dual-core supported
  • 32-bit only: Microsoft® Windows Vista® Ultimate/Business/Enterprise, Microsoft® Windows XP (SP2)
Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Here's how you should be able to run it in compatibility mode:
1. Right click on the Autocad Icon in your start menu
2. click on Properties
3. click on the Compatibility tab at the top
4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
Feb 07, 2009 | Microsoft Windows Vista Home Premium with...
Adobe cs3 installation in vista 64bit
I am sure but I think it isn't compatiable with vista home ..
Jun 07, 2008 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Jan 13, 2008 | Creative Labs Sound Blaster Audigy LS...
Creative Labs Sound Blaster Audigy LS Sound Card Logo
1,314 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
