Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Epson RX520 feed problem when using glossy photo paper
When I use either A4 or 6" by 4" glossy paper on my RX 520 I get feed problems. The paper is drawn into the printer, but only marginally. A paper jam is then reported. I have tried the envelope adjust lever but that didn't work so I have left that lever in the standard position. It seems that the mechamism that is supposed to cath the paper and feed it through is just missing somehow, bit only with photo paper. Standard paper is fine.
Hope you can help,
Colin Griffin
Stirling, Scotland
    Problem Solver:
  • 5 Answers
I have just had a similar problem with my RX600. I had to use the option LAYOUT and select 'with border' otherwise I got a paper jam. Hope this helps.
Posted on Jan 25, 2011
    Problem Solver:
  • 16 Answers
Clean the rubber rollers that pull the paper. hoping it 2 work fine....
Posted on Jan 15, 2008
Paper not feeding for epson nx400
Check the following:
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right side, behind the tab, then press in the tab on the edge guide and slide it against the paper. Make sure the paper is not above the arrow mark inside the edge guide.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • If the paper doesn't eject fully, you may have set the wrong paper size. Press the c:\users\home\appdata\local\temp\msohtmlclip1\01\clip_image001.gif Stop button, then open the scanner and remove the paper. Select the correct paper size when you reprint.
  • If it's wrinkled when it ejects, the paper may be damp or too thin. Load new paper.
  • Make sure you use new, smooth, high-quality paper, that is not curled, creased, old, or too thin. Make sure to load it printable side up.
  • Do not load paper with holes punched in it for insertion in a binder.
  • Make sure you load only up to the recommended number of sheets. If you're printing on both sides of the paper, try loading fewer sheets.
Paper type
Load up to
this many sheets
Plain paper
Approximately 120
Epson Bright White Paper
Epson Presentation Paper Matte
Epson Photo Paper Glossy
Epson Premium Photo Paper Glossy
Epson Ultra Premium Photo Paper Glossy
Epson Premium Photo Paper Semi-gloss
Epson Premium Presentation Paper Matte
Epson Premium Presentation Paper Matte Double-Sided
Epson Photo Quality Self-Adhesive Sheets
Epson Iron-On Cool Peel Transfer Paper
If the paper jams, do the following:
1. Gently pull any jammed paper out from the output tray or sheet feeder.
2. To eject the jammed paper, try turning the Epson Stylus NX400 off and then back on.
If that doesn't work and paper is stuck inside, turn off the Epson Stylus NX400. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus NX400 back on.
Aug 17, 2012 | Epson Stylus NX400 InkJet Printer
Plain paper feeds no problem but photo glossy paper wont feed! (epson 830)
This looks to be a problem with the paper pickup roller. Hence use a little thin Photo paper or replace the Pickup roller and also the Paper feed toller (Long black roller )
Jul 15, 2011 | Epson Stylus Photo 830 InkJet Printer
SX400 printer will not print on epson glossy photo paper, will not feed through rollers
Just put first not glossy paper at the top of glossy paper to start printing.
Feb 20, 2011 | Epson NX400/SX400/TX400
When printing photos on glossy Kodak paper the error message " paper jam reload" appears.
Some printers are not able to or having difficulty feeding glossy photo papers at 230 gsm and above, try using photo papers below 230 gsm.
Jan 13, 2010 | Epson Stylus Multifunction Printer/...
Glossy A4 paper will not feed. Is it too heavy?
Actually, if printer is new, printer can feed up to 350 grm. But if pick up rubber at paper feeder mechanics had distort/loose thickness, it can't. Try to use 210 gsm glossy paper. Or, if you wish to use 280 gsm, pull down paper while printer grab paper.
Aug 20, 2009 | Epson Stylus Photo 2100 InkJet Printer
EPSON 1280 SILVER INK JET PRINTER, Stopped printing on glossy
Problem with paper feeder. Replace paper feeder or replace just pick up rubber at paper feeder mechanics. You can add thickness of rubber by adding black double tape (flexible) (about 1mm).
Jun 15, 2009 | Epson Stylus 2200 InkJet Photo Printer
Epson r350 printer does not print thick paper or inkjet paper
Hi, this printer is "clever" in that you don't adjust the thickness setting it does it itself.
It does this based on the paper type you set in the printer properties, see the table below for the different types of paper it will accept & the setting you need to use.
For this paper Select this paper type setting Plain paper, sheets Epson Premium Ink Jet Plain Paper Epson Bright White Ink Jet Paper plain papers Epson Ultra Glossy Photo Paper Epson Ultra Glossy Epson Premium Glossy Photo Paper Epson Premium Glossy Epson Premium Semigloss Photo Paper Epson Premium Semigloss Epson Glossy Photo Paper Epson Glossy Epson Matte Paper - Heavyweight Epson Double-Sided Matte Paper Epson Matte Epson Photo Quality Ink Jet Cards Epson Photo Quality Ink Jet Epson Photo Stickers Epson Photo Stickers Envelopes Envelope
Hope this is of help.
Jun 01, 2009 | Epson STYLUS R350 Photo Printer
Will not accept glossy paper why
The glossy paper is much harder to grab with the feed rollers, try one sheet at a time and nudge it in while it is starting to feed. It doesn't look like the printer is very old so I don't think your feed tires have any appreciable wear. Good luck, Dale
Apr 21, 2009 | Epson Stylus Photo 2100 InkJet Printer
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson RX520 dont print the full picture
It's a problem with the paper not feeding straight. The printer will make a pass & sense the width of the paper & print accordingly. If it feeds in crooked then it sees it as being narrow & only prints to that width. Happens more easily with heavy photo paper.
Apply a bit of pressure to the paper as it feeds & it's happy days.
Feb 20, 2008 | Epson Stylus RX500 All-In-One InkJet...
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
266 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
