Question about Krups 203-42 Electric Blades Grinder
Krups 203-42 Electric Blades coffee grinder
How can I open the base to access the motor ?
  • 2 more comments
  • Anonymous Mar 09, 2008
    motor is wobbling when grinding.  blades now strike metal sidewall of grinder.
  • Anonymous Aug 24, 2008
    how do i get it apart?
  • J.A. Sosa Dec 20, 2008
    Need open the unit to look at the motor as it is not turning.
  • Anonymous Mar 18, 2014
    replace electrical cord krups 203
In my above solution there is a segment that reads "of the back of the E" which should be "at the back of the "E"".
Posted on Jan 31, 2011
  • Dan40 Apr 27, 2011
    I took the base off a 203. Turns out you have to simultaneously push back four little plastic tabs. They look like little rakes with 4 prongs. If the base were a clock the tabs would be located adjacent to the edge at the 2, 4, 8 and 10 o'clock positions. Insert thin blades on the smooth side of the tabs, opposite the rake prongs. Do not shove anything in the other holes on the base (which also have tabs... they secure little assemblies internally attached to the base). Once the correct tabs are pushed back you should be able to get the base off. Be careful, or you'll never get it back together! But once you get the base off, what next ??!! My conclusion: you may succeed in repairing it if you're an watchmaker! I failed. After that experience, a new unit seems like the better way to go.
Per company spokeman, unit is unrepairable, if under warranty, they will send a new one, if not, will have to buy another.
Posted on Jun 01, 2009
  • Mark Hennessy Oct 30, 2011
    Pretty typical company answer. Liability and the desire to sell new machines discourages any other answer.
I HAVE THE SAME QUESTION.
Posted on Feb 07, 2008
Motor turns but rotating knife remains stationary
It appears that the top portion of the blade needs to be tightened to the motor shaft. You could easily do it yourself, but a shop would probably, and more safely, do it for free, as it would take less than 15 seconds to do that. Call around and see if any shop will do it for you, and ak if they will charge.......they shouldn't.
Feb 06, 2014 | Krups 408-75 Electric Blades Grinder
Tip
Krups 203 Blade Replacement Procedure
<span>Krups is among one of the foremost names in coffeemakers, espresso machines, blenders and toaster ovens. Krups also makes coffee bean grinders, such as the Krups 203a. This portable, plug-in grinder has a removable lid and bean grinder chamber. The blade on the Krups bean grinder is fastened to the bottom of the grinder chamber. You may need to replace the blade on your Krups 203. The Krups 203 comes with a limited 1-year warranty, but the company recommends you send your grinder to the company to make repairs. Order replacement parts for your grinder by calling the Krups customer service department at 1-800-526-5377.<br /><br />Unplug your Krups grinder from the wall.<br /><br />Remove the grinder's lid, and use a cloth to wipe out the inside of the grinder chamber.<br /><br />Put your safety gloves on and then grasp the blade of the grinder with your channel locks.<br /><br />Use the pliers to turn the plastic fastening nut to the left as you continue to hold the blade with the channel locks. Once the plastic nut comes loose, twist it off by hand and remove it, along with the plastic washer beneath it and the old blade.<br /><br />Set the new blade in place, and replace the washer and nut. You will have to hold the new blade in place with the channel locks as you tighten the securing nut. <br /><br />Things You'll Need<br /><br /> Cloth<br /> Safety gloves<br /> Channel locks<br /> Pliers<br /></span>
on Jun 02, 2011 | Krups 203-42 Electric Blades Grinder
Spice grinder blades won't turn
You just need to turn blade with some tool which has a good grip ..I just did it with "Pincers"and now its working..Hope this help.
May 05, 2013 | Krups 203-42 Electric Blades Grinder
Krups grinder 223
what problem do you have?
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Krups Coffee Makers & Espresso Machines
Krups grinder mod 233
see this causes and proceed .God bless you
How to remove blade 0f krupps 203 coffee grinder and clean the motor
On the bottom of the Grinder, You will find several Rectangular holes. With a flat screwdriver push tangs to release bottom. In main shaft, there is a small slot for a flat screw driver. Inseret proper dcrewdriver in slot and turn blades counter clockwise. This should remove blades..
Jan 25, 2011 | Krups Burr Coffee Grinder
When i turn it on motor doesn't turn just hear the hum like it is trying to turn but can't
It probably cooked the motor. You need to assess the cost of repair against a new unit and if your coffee will have a smokey taste if repaired also It would be easier to just buy a new one. Not worth the time or effort to repair.thanks
Jan 16, 2011 | Krups 203-42 Electric Blades Grinder
Hi, i have the krups 203 coffee grinder mill. i have misplaced the lid. where can i buy a new one? thanks
Here is the link
http://www.krupsonlinestore.com/product_list.asp?MENU=parts&SELECT=grinders&SKW=acccoffgrind
Jan 13, 2011 | Krups 203-42 Electric Blades Grinder
MOTOR HUMS. BUT BLADE NOT SPINNING.
See if you can turn the blades or reach a knife balde in to turn the blades....if something has jammed them.... get it removed... if they spin feely, then the motor is bad and replacement will probably cost more then a new one...
heatman101
Nov 30, 2010 | Krups 203-42 Electric Blades Grinder
Krups 203-42 Electric Blades Grinder Logo
1,183 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
