Question about Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Machine doesn't work: power ok. Inlet water ok. Filter outlet ok. Connections ok. Program starts, flushes powder in, then program stops. You can hear a buzzing slight electricity sound in the machine, but program doesn't progress. If I manually forward the program it doesn't spin nor let's a good amount of water come in. When I take clothes out they are slightly wet. Please advice.
  • chunky117a Jan 14, 2008
    machine does do something, so definately not fuse in plug I'd say.
    I've tried the banging but it didn't help.
    Thank You very much anyways!!
Try fuse on plug this may be gone, also the door interlock switch, try a light bang with fist near door catch see if this will do it, what i do suspect is the door inerlock is faulty, this is a safety device which locks the door when machine is in washig/spinning mode it aso stops machine working when you open the door, this is also a safety device, good luck al. xxxx
Posted on Jan 13, 2008
Water pump not working hoover 2305l
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
http://www.espares.co.uk/advice/washing-machines/a/7/1373/how-to-replace-the-pump-on-a-washing-machine-.html
Jan 25, 2013 | Hotpoint WD62 Front Load Washer / Dryer
My hotpoint wf541 shows the on/off switch as on but machine will not start. i have cleaned the filter, tried cancel switch and unplugged at the mains
Please check the power to the mains controller unit and if present please check if the door switch is contacting to give the OK signal for the controller to start the function . So if the inlet does not open and allow water into then is seems that the program controller unit is a suspect.
recheck once again to confirm, try to swap a similar board to confirm and then replace.
Sep 13, 2011 | Hotpoint Aquarius WF220 Front Load Washer
I select a programme and then press the start button, the door locks but the start light flashes, and nothing happens
When the program is pressed to start then the inlet valve must open and allow the water to come to the drum. if this is not happening then check the voltage to the inlet valve, if there is no voltage then the program controller is not outputting and so defective.
If not the inlet filter/valve is clogged and will need a back flush .
Apr 11, 2011 | Washing Machines
Hi I have a hotpoint WD62 washer dryer. when I'm using the dryer the clothes still come out wet like the steam is not going out of the machine. Any tips on what to check for? Could something be...
I had the problem. I replaced the water inlet valve, and that fixed it. It seems no cold water was coming in on the drying cycle to condense the steam.
Sep 24, 2010 | Hotpoint WD62 Front Load Washer / Dryer
Water coming out of the powder draw when the draw is closed
Hi
The hose from the drawer into the tub is blocked or kinked, not allowing the water down quickly enough
Feb 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Hotpoint WF250 - clothes largely dry and covered in powder
check to make sure the water inlet filter is not clogged with debris.
turn off water and disconnect at washer , look in opening is filter screen clear, some are removable to clean others you have to brush etc....
there are two more places to check but they are inside the washer at the water control solenoid and the inlet , the water pressure sensor may have something to do with this issue.
best to open the top and listen and watch. (3 screws in rear top)
Apr 06, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wd62 leaking from the drawer
Hi, check the electrict valve winding busted hot and cold.
Jan 27, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint W/D valve problem
yes change inserts around leave top off test and watch. red is for hot water black for cold
Nov 20, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint Aquarius 1200 WD62 (Tumble drying issue).
no the steam from the dryer part comes out of outlet tube the same tube were the water comes out hotpoint washer/dryers use a condensing chamber which allows the steam to cool down a pass through it as water does and through the outlet pipe
Aug 14, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Hotpoint WD62 Front Load Washer / Dryer Logo
197 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
