Question about Mitsubishi WS-55807 TV
Black diamond 32ws
My tv set just went off and will not come back on - no power. i have just ordered a new one but would like to try and fix it myself rather than throw it away.. any suggestions would be much appreciated. thanks
  • Vista Electronics May 11, 2010
    Please provide model number off back of set ........T.
    Sergeant:
  • 261 Answers
Probably it has a power supply issue. It would make a great gaming set if nothing else. I am located in Louisville Kentucky if you are local, i can take a look at it. Let me know your location and if your too far, i would refer you to someone local in your area. Let me know. Thank you and have a good night. Jay
Posted on Jan 31, 2008
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
I have a Mitsubishi diamond WD-62725 the lamp light was on so i ordered a new replacement for it I installed the new lamp and the picture looks brighter than ever remember seeing it but the lamp light is...
we have the same brand tv but the 65" model. had a 4 year warranty just in case the lamps went out. the lamp went out and we called conn's to come out and fix the tv. the repairman replaced the lamp, and then he said to unplug the tv from the wall or the strip it is plugged into and wait 5 minutes and then plug it back in. he left and said to call him back if that did not work. did what he said and it fixed the problem. try unplugging the tv for 5 minutes and plug it back in and see if that might take care of your problem.
Jun 22, 2010 | Mitsubishi WD-62725 62" Rear Projection...
VIZIO TV Black screen. Cannot turn off TV without unplugging.
I had a similar problem after having a Vizio for 2 and a half years. I left the room for a minute, i came back and the screen went black. I didnt hear an arcing sound though. There was still power to the unit and you could see that the back light was working, just no picture, no sound, and you couldn't use any of the buttons. The only way to turn it off was to unplug it. It would then start up, with the Vizio logo going from orange to white, and then do the same thing all over, no pic or sound. I would check the ceramic fuse first on the board that gets power from the plug.
HOW I FIXED MINE: I ordered a new "main PCB" from tigerdirectparts.com (you can also use searspartsdirect.com). This is the circuit board with all of the inputs on it (hdmi, cable, etc.) I opened it up, disconnected the old one, put in a new one and now it works fine.I used both serial numbers on the board to search for it online. It cost me $144 to do it, but that's better than $450 for a new TV. My tv is the vx32l hdtv10a. I hope that helps.
Jan 13, 2010 | Vizio VW42LF 42 in. LCD HDTV
I have sound, but no picture
I am finding a lot of people's lamps are going out. This maybe your problem too judging from what I have read above.
There are replacement lamps. They used to be pretty expensive but they are somewhat reasonable now. Below is a site you can order a new lamp this should fix the problem.
But before you order make sure that all the cables in the back of the television are in the right order. Red and White are audio while Yellow is video. A lot of people are unable to distinguish the yellow from the white.
If you have the other cables such as the blue and the black make sure the blue is with blue and black is with black. They are hard to see sometimes in a poorly lit area like behind a TV.
If everything is hooked up correctly.
Your next bet is the lamp replacement. Replacing the lamp its quite easy to do. Just remember to reset the TV lamp timer. Consulting your owners manual should help.
Here is the site for lamp replacements. You also can do your own search for lamp replacement.
http://www.purelandsupply.com/GeneralSearch.aspx?search=Samsung%20HLN617W
Jul 13, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Strange colors and shadowing and then went black.
something on the mainboard went bad and shut the tv down and whatever part it is will be on the new mainboard.by replacing the board you are replacing the problem
Jan 17, 2009 | Televison & Video
No picture, just went off while watching tv
The pink lines in the set happened when the first time it blew out. It is called a burn in on the inside surface of the picture tubes. Not the fault of the TV repair guy. This is the fault of Toshiba. This set has known to have this happen and you should contact toshiba and request that they replace all three tubes for you at no cost. You should also stop using these repair guys who cannot fix a simple vertical problem. Find out who is authorized for Toshiba in your area and call them. They will know, or should know the problems that happens with this model number and take care of them once and for all. Good Luck
Nov 06, 2007 | Toshiba 51H84 51" Rear Projection...
Mitsubishi 65 inch rear projection diamond
its the circut board that leads into tv from power cord , i had bought mitsubishi65819 black diamond gray 65inch for $54 ,is under the warranty the board cost $350 , labor $200 but this depends on where u live ,either way it was a steal for me ,but yea i had same problem when u turn tv on it shuts down like not even 2seconds i had tech come out and he had to take the board to get it repaired ,its not available he said but its repairable , was a sears tech so sears can repair it
Oct 29, 2007 | Mitsubishi WS-65869 65" Rear Projection...
Mitsubishi WS-55807 TV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
