Ip adress config/dns server
I had once change my computers ip addresses from automatic detect to manual input so i have entered my own ip address. but when i open my computer for internet it wouldnt connrct. where did i get wrong? may be i did not undrstand well the uses of dns server? could you help me with this?
  • Anonymous May 11, 2010
    What IP address did you set? You can't just randomly pick an IP address for use on your computer and you can't pick an IP address that was automatically assigned to you. Once you tell me what IP address you selected, I can explain further.
    Problem Solver:
  • 14 Answers
When using a static IP you must also get the DNS server addresses from your router's manufacturer. the primary/secondary DNS for D-Link routers are 4.2.2.2/4.2.2.3 respectively. contact the customer support line of your product or do a Google search for"_______ dns" (____ being your product name)
Posted on Jan 14, 2008
6ya staff
SOURCE:
I have been having issues with my internet connectivity for a while - its been fix after fix and i feel like im slowly fixing the problem but adding more onto it. The exact problem from the top - Spee
Problem is that ipv4 config.
For any computer on a home network an automatic IP-address is handy. So the ipv4 config should be set to DHCP.
But then there should be a router that hands out IP-addresses and the IP adress of this router should be given in the ipv4 config as Standard gateway.
That is for home, but to resolve internet adresses your computer needs DNS, you can use common dns servers, or the ones given by your internet provider.
Fill these in under DNS in the config.
Aug 23, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
Ip address dynamic
Dynamic and Static addressing are the two main methods used for IP address assignments. Dynamic IP addresses are automatically obtained and nothing needs to be done on the user end. However, Static IP address information must be configured manually. If you do not have a router, you need to input your static IP information directly into your Apple Macintosh.
Click "Apple > System Preferences." Click the "Network" icon. Click the "TCP/IP" tab. Choose "Manually" in the Configure drop-down menu. Click in "Show" and choose your Ethernet device. This is usually called Built-in Ethernet. Enter your IP address into the IP Address field. Enter the Subnet Mask into the Subnet Mask field. If your service provider did not provide you with one, use the default of "255.255.255.0". Enter the Gateway address into the Router field. Enter the DNS Server into the DNS Servers field. Two should have been provided to you. Push the "Apply Now" button to confirm changes.
Apr 07, 2013 | Belkin Ethernet Adapter F5D5050 Network...
Hp laserjet P2055dn - print config report indicates IPv6 Address, will not network print. How can I clear this?
IPv6 is upgraded from IPv4 (Internet protocol).. Its implemented in 1994 this adres is stored in DNS, it is no way connection with the printer, when the printer is connected through lan net work, auto IP adress will assign by the DNS server depend up on the settings.. you can change the desire IP adress with the family range. If the printer is not showing IPv6 adress, system administrator can help you in this regards depens upon their permissions. Selected printer IP adress ahould be with in the family range and no IP conflict definately printer will work..
Nov 19, 2011 | HP Office Equipment & Supplies
How do I configure my laptops IP address to my router to get online? I'm using windows vista. I tried a few times and I can't find the window to type in the laptops IP address. How?
Follow the following steps to change your TCP and IP Settings on Windows Vista
1. Go to the Control Panel from the Start menu.
2. Click "Network and Internet" and then "Network and Sharing Center."
3. Click "Manage network connections."
4. Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
5. Click the "Networking" tab.
6. Choose Internet Protocol Version 4 (TCP/IPv4)
(Note that "Obtain an IP Address Automatically" works fine generally)
7. Click "Use the following IP Address" to enter your own IP settings.
- Enter IP address (eg. 192.168.1.125) into the box marked "IP Address, press tab "Subnet Mask" would appear automatically (255.255.255.0) and in "Default gateway." type 192.168.0.1.
- To obtain a DNS server address automatically, click Obtain DNS server address automatically, and then click OK.
- To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.(which can be obtained from your internet service provider (ISP).
For visual help, check out step by step guide here
Hopr it Helps!
CreativeTECH
Nov 25, 2010 | Linksys Wireless-G Broadband Router
How do I change the ip address from the lcd display?
hi
  • Go to the Control Panel from the Start menu.
  • Step 2 Click "Network and Internet" and then "Network and Sharing Center."
  • Step 3 Click "Manage network connections."
  • Step 4 Choose which Internet connection you would like to change if you have more than one. Right click on it and select "Properties."
  • Step 5 Click the "Networking" tab.
  • Step 6 Choose either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6).
  • Step 7 Click "Obtain an IP Address Automatically" to reset your IP address automatically, then click OK.
  • Step 8 Click "Use the following IP Address" to enter your own IP settings.
  • Step 9 Enter your IP address into the boxes marked "IP Address," "Subnet Mask" (or "Subnet prefix length for IP/TCPv6) and "Default gateway."
    Change your DNS Server Settings
  • Step 1 Click "Obtain DNS Server Address Automatically" and then click "OK."
  • Step 2 Click "Use the following DNS Server addresses" to change your DNS Server settings manually.
  • Step 3 Type your primary DNS Server address into the box that says "Preferred DNS Server."
  • Step 4 Type your secondary DNS Server address into the box that says "Alternate DNS Server."
    Add a New Network Protocol
  • Step 1 Click "Properties" and then "Install" from "Manage network connections."
  • Step 2 Click "Client," "Service" or "Protocol," depending on which you wish to add. Then click "Add."
  • Step 3 Select the item you want to add from the dialogue box and click OK.
  • Jul 02, 2010 | Zebra Printer 140-751-00000
    Need ip address for syrens, not sure if i remember right: 192.168.1.1???
    Hi Stephan,
    the ip address of your router by default should be "192.168.1.1". to check if the ip adress of your router here's the solution :
    1. go to control panel > network and sharing/networking >change adapter settings
    2. then you'll see your local area connection
    3. right click on it>properties
    4. double click on (internet protocol tcp/ip) "tcp/ipv4 in windows vista/7
    5. the select "obtain ip address automatically" & "obtain dns server464142c.jpg automatically" click ok and click ok for the other window
    7. the dns server ip show should be your router ip adress
    8. open your web explorer and type in your router ip an press "enter" you'll get your router configuration where you'll be able to change the default ip.
    I hope that it will help & don't forget to rate
    Kind regards
    Feb 14, 2010 | Sea and Sea Syrens OnBoard WiFi...
    DPR-1260 ... prints but cannot access web config page
    To get into the web configuration you need to know your firmware on the DPR-1260. If it is 1.12, us http://dlinkps-xxxxxx where the X's are the last 6 number of the mac address. If it is 1.20 and up, use http://dlink-xxxxxx, where the x's are the last 6 number of the mac address. If you do set it up as DHCP or static and know the ip address of the print server just type in the ip address of the print server on the address bar.
    Oct 21, 2007 | D-Link RangeBooster G DPR-1260 (DPR1260)...
    How to set a static IP address in Windows behind a Linksys Router
    Windows 2000/XP 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window appears, input control ncpa.cpl into the ?Open? field. 3. After the ?Network and Dial up Connections? or ?Network Connections? window opens, right click on the Local Area Connection or Wireless Network Connection which controls the connection to the router. 4. After the ?Local Area Connection Properties? or the ?Windows Network Connection Properties? window appears, click on Internet Protocol (TCP/IP) then click on the Properties button. 5. Once the ?Internet Protocol (TCP/IP) Properties? window opens, change the option from ?Obtain an IP address automatically? to Use the following IP address. Set the options under ?Use the following IP address? and ?Use the following DNS server addresses? to the following: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 * Default Gateway: 192.168.1.1 * Preferred DNS server: 192.168.1.1 6. Click OK then OK or Close. Windows 98/ME 1. Click on the Start menu, and then click on the Run option. 2. When the ?Run? window opens, input control netcpl.cpl into the ?Open? field, then click on the OK button. 3. When the ?Network? window opens, locate the TCP/IP for the Wireless or Ethernet adapter in the PC, and click on it. Once it?s highlighted, click on the Properties button. 4. Change option from Obtain Automatically to Specify and input: * IP: 192.168.1.20 (If there are multiple computers being setup with static IP's, then the next computer would be .25, and next would be .30, etc) * Subnet Mask: 255.255.255.0 5. Click on the Gateway tab, and input 192.168.1.1 into the ?Default Gateway? field and click the Add button. 6. Click on the DNS Configuration tab, then go to the ?Host Name? field and input Computer, then go to the ?DNS Server Search Order? field and input 192.168.1.1 then click the Add button. 7. Click OK then OK once more, then windows will prompt for a restart.
    Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
    How to set a static IP address in Windows behind a WRT55AG Router
    Feb 16, 2006 | Linksys WRT55AG Router
    Open Questions:
    Computers & Internet Logo
    181 people viewed this question
    Ekse
    Marvin
    Marvin
