Question about Optoma MovieTime DV10 Multimedia Projector
White Vertical Stripe down screen
When I use my projector, I get a white stripe down the entire length of the screen. It ised to be intermittent, but now it is always there. I can't find a shopt to look at it in Richmond VA.
  • puuherman Apr 12, 2008
    I have a verticle white stripe down the screen as well. The manual suggests adjusting the Tracking, but I can't find Tracking on any menu.
  • pinball7 Oct 12, 2008
    Exactly, I have the DV 10 and it says to adjust the tracking or frequency, but those functions are non-existent on this model. Total bumer
How about sending it back to the company? Since you are in the US (unlike me), they should be able to fix it.
Posted on Feb 25, 2008
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
Black Vertical Stripe Our Hitachi plasma TV has just started displaying a vertical black stripe about three inches wide right down the middle of the screen. This stripe comes and goes every hour or so,...
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Feb 03, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
HP Laserjet P1006 prints with blank white stripe down left side
Clean the Corona Wire carefully to remove any residue. As the charge on the wire is effectivley masked it cannot deposit any toner to the page and will result in a consistent white vertical stripe.
Aug 29, 2009 | HP LaserJet 1022 Printer
Right half of screen is Black with a White vertical stripe
Yeah, I have this exact same problem, except my mom slammed my laptop shut in frustration around half an hour ago, so that's why it's like this. The right half of my screen is black with two colorful stripes (mostly white), but the left half is visible. I've researched a bit and found out that this is because the LCD in your monitor has burnt out, and since you don't have a monitor to attach, the only thing you can do is to go to where you bought the laptop and either get it fixed for free or return it for a brand new one (if your warranty still stands). If not, you might as well get a new laptop. I think my warranty has expired, so I'll get a new laptop, hopefully.
Hope this helps!
~Sam.
Jun 08, 2009 | HP Compaq FP 7317 17" Flat Panel LCD...
Quarter inch vertical white stripe down length of copy
Make sure that the corona wire is clean (use a dry bristle haired artists paint brush or use the cleaning pad supplied with the printer) and making sure that the toner cart cleaner / scraper is not clogged or has some paper jammed on it. Also you can vacuum the Corona Wire with a domestic vac and the nozzle tool or a clean soft brush tool but make sure the printer is turned off before doing it.
Mar 22, 2009 | HP LaserJet 3050 All-In-One Printer
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
Hitachi 60v500 tv has split screen with white vertical stripe down side
Good Day, poandflo;
After removing the power from TV remove the back of the TV (bottom only): Repair: Re-insert PDM connector on both Main Digital module and Drive PWB.
Good Luck, big IRISH. ps. remove cables one at a time and plug back in ensuring that they are seat properly.
Aug 08, 2008 | Hitachi 50V500 50 in. HD-Ready LCD...
Sharp XR-1S White vertical stripe
HI there
This could be a costly exercice as this is a common Projector Mainboard failure.
You can either replace the board or have it repaired.
Apr 10, 2008 | Sharp XR-1S Multimedia Projector
Hp r4252 white vertical stripe on left side, 5 in wide
Well sound as if a segment or Ic driver has failed on the panel. And a 42 inch replacment panel can run you $1250.00
Jan 30, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
ViewSonic N1700w with Black stripe on right side of display
Sounds to me that you have a bad connection/wire to the CCFL bulb on that side of the display. Should be an easy fix, do it your selfer thing.
Dec 27, 2007 | ViewSonic NextVision N1700w (Black,...
Optoma MovieTime DV10 Multimedia Projector Logo
544 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
