Question about Dryers
Insert a new belt into dryer - Dryers
  • 5 more comments
  • toffa Jan 17, 2008
    have taken machine to pieces and have sourced correct replacement belt but now need to know how to position and fit this properly
  • sorin777 Feb 11, 2008
    how to replace the belt in a electric portable dryer older? How to remove the front door?
  • Anonymous May 16, 2008
    How do I change the belt for my Kenmore gas dryer
  • Anonymous Aug 22, 2008
    the belt came off my dryer how do i replace it
  • Anonymous Sep 23, 2008
    replacing belt on dryer.  Pully fell off.
  • benched Oct 03, 2008
    belt came off dryer drum along with tension wheel. how do I replace them ?
  • Anonymous Jan 08, 2009
    belt replacement
I have many cuts and wounds from attempting to replace mine - I suggest breaking it down and weighing it in for scrap. This is my resoloution to my machine for sure.
Posted on Jul 08, 2008
How do i replace a broken dryer belt?
Unplug the dryer and remove it to the outside (if possible). Pop the top. Remove the front, then the shroud (if applicable to your model). Get the drum out and give it a good vacuum. Place the new belt around the drum making sure it is not twisted. 99% of all dryers the ribbed side goes down on the drum. If the belt is twisted it will be destroyed the minute you start the dryer. Not sure what brand you have so I inserted some links above. Good luck on your dryer repair. Get your belt here, here or here.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 25, 2011 | Dryers
Dryer stopped working?
  1. From the top of the dryer, remove the lint trap. Using your screwdriver, unscrew the assembly that houses the lint screen and remove it from the dryer, setting it aside.
  2. Using your screwdriver as a lever, insert it under the front right side of the dryer, between the top and the body. Press down to force the top slightly up from the body. Repeat this process on the left side, and lift the top off the dryer.
  3. Remove the lower panel from the dryer by inserting the screwdriver into each side and rotating to release the clips that hold it in place. Slide your phone book under the now-exposed dryer drum so that the drum will be supported.
  4. Loosen the screws at the bottom of the front cover, but do not remove them (this allows access to the belt without requiring you to remove and replace the entire front cover). Move to the top of the dryer, and remove the screws holding the front of the dryer in place. (These will be located at the top, behind the front.) Tip the cover toward you, exposing the drum, and slip the broken belt off the drum without fully removing. Slip the new belt over the drum, and lift up on the drum while returning the cover to the closed position. Replace the screws to the front cover and tighten the lower screws. Remove your phone book from its position under the drum.
  5. Check the rear drum seal to the back of the dryer, and position the new belt identical to the old, with the textured side facing down.
  6. Directing your attention to the motor area, remove the old belt and feed the new belt through, passing the entire belt, doubled over, under the idler pulley. Push the belt toward the motor pulley, placing the belt around it, and allow the tension to release on the idler pulley.
  7. With your hand inside the dryer drum, rotate the drum counterclockwise to ensure that the belt has been properly installed. Replace the top of the dryer, exerting downward pressure for a snug fit, followed by replacing the lint screen assembly, and the lint trap, and then replacing the lower front cover.
  8. Run the dryer for several minutes to ensure that the dryer is operational and that you have installed your belt correctly.
  9. please comment on there by rating or voting,saying how helpful
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Dec 23, 2010 | Maytag Neptune MDE5500AY Electric Dryer
What is the routing of a dryer belt? It's a Roper dryer model GL6050VLO
To install a new belt and re-install the pulley, follow these steps:
1. Loop the drive belt around the dryer drum with the groove side facing the drum. (Try to line the belt up with the wear marks already on the drum from the previous belt).
2. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
3. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
You can also refer to pcappliancerepair.com for some excellent exploded view diagrams of your dryer. Just type in your model number as "GL6050VL0" (the last digit is a zero, not the letter O), and go to the "Bulkhead" section.
NOTE: Roper is manufactured by Whirlpool, so these instructions will apply.
If you have questions, or require additional assistance please let me know. I hope you find this information helpful.
Oct 17, 2009 | Dryers
I need to change the belt for my Kehmore Series 80 dryer
HI. this guide will help you replace this worn belt. make sure you have safely unplugged this unit before initiating this procedure.
1 From the top of the dryer, remove the lint trap. Using your screwdriver, unscrew the assembly that houses the lint screen and remove it from the dryer, setting it aside.
2 Using your screwdriver as a lever, insert it under the front right side of the dryer, between the top and the body. Press down to force the top slightly up from the body. Repeat this process on the left side, and lift the top off the dryer.
3 Remove the lower panel from the dryer by inserting the screwdriver into each side and rotating to release the clips that hold it in place. Slide your phone book under the now-exposed dryer drum so that the drum will be supported.
4 Loosen the screws at the bottom of the front cover, but do not remove them (this allows access to the belt without requiring you to remove and replace the entire front cover). Move to the top of the dryer, and remove the screws holding the front of the dryer in place. (These will be located at the top, behind the front.) Tip the cover toward you, exposing the drum, and slip the broken belt off the drum without fully removing. Slip the new belt over the drum, and lift up on the drum while returning the cover to the closed position. Replace the screws to the front cover and tighten the lower screws. Remove your phone book from its position under the drum.
5 Check the rear drum seal to the back of the dryer, and position the new belt identical to the old, with the textured side facing down.
6 Directing your attention to the motor area, remove the old belt and feed the new belt through, passing the entire belt, doubled over, under the idler pulley. Push the belt toward the motor pulley, placing the belt around it, and allow the tension to release on the idler pulley.
7 With your hand inside the dryer drum, rotate the drum counterclockwise to ensure that the belt has been properly installed. Replace the top of the dryer, exerting downward pressure for a snug fit, followed by replacing the lint screen assembly, and the lint trap, and then replacing the lower front cover.
8 Run the dryer for several minutes to ensure that the dryer is operational and that you have installed your belt correctly.
Aug 13, 2009 | Kenmore 64852 Electric Dryer
Putting the belt back on this dryer
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Jun 26, 2009 | Hotpoint Dryers
The belt broke drum won't turn
Jun 25, 2009 | Roper REX3614KW Electric Dryer
Belt on my Whirlpool dryer brokeModel # LE 5780XKNO.
Remove the back cover.
Remove the belt and drum.
Place the new belt around the drum and sticky tape it to the position of where the old belt was seated.
Insert the drum back into the cabinet of the dryer and reconnect it to the electric motor.
After connected to the motor, remove the sticky tap and reassemble.
Job done.
Jun 17, 2009 | Dryers
How do i?
Apr 05, 2009 | Kenmore 63942 Dryer
Dryer heat but what turn
Mar 28, 2009 | AEG T57800 Electric Dryer
Belt broke
Buy a new belt. Insert the idler pulley into the slots under the motor pulley. The wheel should be on the left side of the motor as you face it.
Put the belt around the drum, then through the idler roller. Then over the motor pulley.
Mar 11, 2009 | Kenmore 63942 Dryer
Dryers Logo
266 people viewed this question
Top Dryers Experts
Marvin
Marvin
