Question about Kitchen Ranges
The grease drain line is clogged on my Jenn Air Range/Oven somewhere between the grease storage bin and the bottom of the grill area in the area that is not visible. Is it possible to clean this?
  • Wuwu Jun 11, 2008
    How do you clean a clogged grease drain on a Jenn Aire slide-in kitchen range?
Both grease drain lines on my Jenn Aire SVE 47600 are blocked - I have tried liquid plumber, but it hasn't cleared things up. Has anyone had this problem and figured out a solution?
Posted on Aug 11, 2008
If the pipe is clogged, I recommend a long flexible wire brush. This one worked great for me:
http://www.amazon.com/Platypus-08831-Pla...
It's not sold for stove cleaning but it's perfect for the task.
Posted on Apr 14, 2012
HEAT SOME WATER TO BOILING AND POOR IN. IT MAY TAKE SEVERAL TIMES OF POORING IT, LETTING IT SIT AND MAYBE EVEN MOPING IT UP WITH A PAPER TOWEL IF THE WATER GETS COLD BEFORE IT DRAINS, BUT EVENTUALLY THE HOT WATER WILL MELT THE GREASE AND ALLOW IT TO DRAIN. I TRY TO PERIODICALLY KEEP IT CLEANED OUT WITH BOILING WATER SO IT DOESENT CLOG
Posted on Jan 04, 2009
Jenn-Air Microwave vent grill opens and closes
I have this same problem occasionally. Pull the vent grill open and look for a white cam that rotates when the microwave is on. To the right of that cam, there are two gray switches. The bottom switch should have a red tab that pops out. When the vent grill opens and closes continuously, the red tab is stuck in. Take a flat screwdriver or tooth pick and push gently in on the red tab to release it. It must get stuck due to grease or dirt accumulation. Good luck.
Apr 20, 2010 | Jenn-Air JMV8166B 950 Watts Convection /...
I have a jenn-air dishwasher, at least 11 years old, that suddenly doesnt drain. any do it yourself suggestions to try?
make sure the drain line is clear all the way through. also check the drain itself at the bottom of the wash area. They can get clogged there if large amounts of food or other objects get stuck on the grate. If it is not a clog issue, it is probably the pump. After 11 years I would not be surprised to see a pump let go. A pump replacement may or may not be worth doing. With the machines I work with it is more cost effective to replace the entire machine. I hope that isn't the case with you.
Dec 16, 2009 | Jenn-Air Dishwashers
Water under the crisper bins on the bottom.
Likely clogged drain line somewhere between the freezer section and the drain pan on the bottom of the appliance. The drain line should beon plain view on the back wall of the fridge. Disconnect and clean.
Oct 13, 2009 | Refrigerators
I need to clean the bottom tray of my range, it is the kind built in, the grid grill tops were easy to remove and clean, but below the burner part, congealed grease has caught there
Use some Simple Green full strength, as it will cut the grease and make it easy to wipe away. It may take a few times to get all the gunk that's built up since last being cleaned, but the cleaner will really make it easy to attack the grease and goo without all the nasty fumes of regular stove and oven cleaners.
Hope you found this very helpful and best regards!
Aug 07, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Clogged grease tube
this part is labled drain cleanout 71002402, however the actual draintube part number is 74005855, retails for about $20 probably easier to replace the entire tube, and although its not real clear on the part break down id imagine its simply slid along the side of unit
Dec 04, 2008 | Jenn-Air SVE47100 Slide-In Electric...
How do I get to the grease containers?
The grease container is at the bottom of the range. If you remove the front panel there is a little plastic cup that holds the grease. Hope this helps!!
Oct 10, 2008 | Jenn-Air JDS9865BDP Stainless Steel Dual...
Oven element
bad relay on erc(electronic range control), or and open thermaostat wired in line with element you would need to pull unit and check wiring
Feb 07, 2008 | Jenn-Air SCE30600 Slide-In Electric...
Jenn-air gas electric grill range
This is not a problem. The cleaning cycle goes on for approximately 4 hours as I recall. it will unlock by itself when done. Read your user guide for troubleshooting tips. if you can't locate your copy, one is available on line at the Jenn-Air site
Nov 24, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
683 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
