Question about Biostar K8VGA-M Motherboard
Problem with DDR
I also have a K8VGA-M. I can't upgrade with 2 x 1GB DDR400 (PC3200). It support 2 GB but seems don't work in reality with more than 1GB.
  • 31 Answers
There might be another problem, different rams have different Hz configuration, u'll find a sticker on the ram module with it's Hz, just make sure that both rams have the same Hz, otherwise they won't work together.
Posted on Jan 23, 2008
    President:
  • 2,351 Answers
Got to the web site below it will take you to your board. Scroll down to the bottom. Listed there is the memory that has been tested to work on your board. If you think your memory might be bad download this memory tester. Use one dimm at a time when testing. The program is called CrystalMark 2004R2 (0.9.123.404b). Download at: http://www.warp2search.net/crystalmark-2004r2-0-9-123-404b-s36517.html
Biostar K8VGA-M web site:
http://www.biostar-usa.com/mbdetails.asp?model=K8VGA-M
Please vote.....
Posted on Jan 16, 2008
    Scholar:
  • 176 Answers
If the memory is good (test it on another comp. ) it may be possible that the motherboard does not support that type of memory (happens !! ), or it supports that quantity of memory only on one slot . U must get the motherboard;s manual and read there if they are any particularities..... (sometimes , very rarely, there are BIOS settings ...that may interfere ... )
Does D915GLVG support DDR2 ram
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Anish Nitin.
Unfortunately your Intel D915GLVG only supports DDR memory up to a maximum frequency of 400MHz. It also supports 333MHz frequency as well.
Therefore the maximum/fastest is DDR400 also called PC3200. In those days when the memory was manufactured they made 1GB modules.
If you would like to upgrade this computer install 2X DDR400/PC3200 1GB memory modules.
Take care!
Dec 16, 2011 | Intel D915GLVG Motherboard
Memory upgarade
Yes, it will work. Remember that all memory will operate at the speed of the slowest memory though so unless you're completely replacing the memory it won't increase the speed of the memory.
Jul 21, 2009 | ASUS A7V400-MX Motherboard
PC2700 or PC3200 DDR memory in this mobo ?
MEMORY ecs_buttom_03.gif 2 x 184-pin DDR DIMM socket support up to 2 GB ecs_buttom_03.gif Support DDR400/333/266 DDR SDRAM
Copied above from ECS website so the answer would yes as it supports up to 3.2GB/s transfer rates at DDR400
May 14, 2009 | VIA ECS PM800-M2 PM800 P4FSB 800 Supports...
Upgrade ram
hiya
this board is ddr so you will need ddr400 or pc3200 and a maximum capacity of 2gb so be carefull with 1 gb sticks as sometimes this causes system crashes
hope this helps
Regard Rik
Feb 26, 2009 | Intel D101GGC Motherboard
Try to install 2gb ddr memory on MS-6741 motherboard
pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
Jan 08, 2009 | MSI K8MM-ILSR Motherboard
GA-8S648FX-L MOTHERBOARD
Was your 1gb stick DDR PC2700? Most likely that is why. Although the pin set are both 184 pin, you will be downgraded to the lowest speed available, meaning PC3200 (DDR400) will downgrade to PC2700 (because PC2700 can't be upgraded to PC3200).
May 08, 2008 | Intel Motherboard
Its about the memory card
The board supports upto 4 GB RAM. PC3200 RAM is supported.
1. Reset CMOS settings by CMOS jumper.
2. Try updating BIOS of your motherboard from :
http://support.asus.com/download/download_item.aspx?product=1&model=P5GL-MX
Best of Luck,
rajesh_im
Feb 13, 2008 | ASUS P5GL-MX Motherboard
High density memory
need low densisty on ebay 35 buck eash 1 gb ok works on picky mobos way better
Feb 07, 2008 | Dell (E210882) Motherboard
Type of memory for e210882 motherboard
the memory you're about to purchase will not work. the maximum gig that the computer can handle per stick is only 1 gig. this system is not designed for 4 gig barrier.
hope this helps.
thanks.
Feb 05, 2008 | Dell (E210882) Motherboard
Biostar K8VGA-M Motherboard Logo
116 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
