Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
Magnovox big screen hdtv
I have a blue sagging in the middle of the screen and blue shadowing beside people and words
    President:
  • 4,402 Answers
Http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Jan 15, 2008
SOURCE:
I have small blue dots and a yellow shadow in the middle of my screen
The model indicated uses what is called a Optical Light Engine, it is a very expensive part and likely is your problem---not much else will cause this trouble.
Let me know if you have questions.
Dec 02, 2011 | Sony Grand WEGA KF42WE610 42" Rear...
Our tv has red and green shadows on the picture when words come on at the bottom of screen they look like a shadow double Peoples faces will be outlined with red and green lines
your color engine is failing its also known as the optic block and they are very expensive to replace good luck google the optic block failure in these sets to better educate yourself with what your dealing with ok it most often blue that shows the failure but green and blue to and red
Dec 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Having a big yellow spot background in the middle of the picture.
Hi , it seems you are experimenting a light engine problem.Here's how your tv works: http://www.youtube.com/watch?v=ZLLHnQ4y-wo Basically there's 3 LCD chips that create the colors and image by blending together.When these chips start to melt you will get those blue spots, pixilation even vertical lines.You will need to replace the light engine. Have a blessed one!
Apr 09, 2010 | Hitachi 50VS69 50" Projection HDTV
I have an akai rear projection big screen tv that has blue shadows on everything. When the auto focus turns on, about half way through the process, everything clears up. When the auto focus completes, the...
Replace the Blue convergence IC, But you should consider replacing both of them, because if one has failed then the other is likely to sooner or later. They are large Black IC's mounted on a Metel Heatsink. I believe on this model the board is in the middle of the unit. Before you replace check the solder connection on the Ic's first you might just have a few cold solder joints, if not then replace both IC's
Nov 09, 2009 | Akai PTH5498 54" Rear Projection...
Mitsubishi VS 50802 has blue shadows and I can not reset teh color alignment.
Your set has a convergence problem which is a common issue.
Take a look at this solution posted earlier on Fixya. It worked for me.
http://www.fixya.com/support/t2703612-double_red_image
Aug 30, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Shadow on screen
display screen is having problems so have to go to the service centre
Aug 22, 2009 | Samsung lN-T406F 40 in. LCD HDTV
BOW PICTURE AND HUE GREENS REDS AND BLUES LIKE SHADOWS
the tv had intermittant solder connections already but h\they appeared when the tv was moved to hook up the digi-box. The solution could be as simple as resoldering the power convergence amps.
Aug 06, 2009 | Televison & Video
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Yellow and Blue shadow on left side of screen
Blue convergence off = needs convergence IC's replaced =
Would you like step - by - step how to ??????
Nov 07, 2007 | Toshiba 51H84 51" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
35 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
