Question about Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard
No signal on monitor
Hello
have a problem , i get no signal when i try the built in VGA , i get one long beep and then two short ones , when i install another AGP VGA ATI Radeon 7000 , i get no beeps , and no signal.
Can anyone help ?
  • mshow Mar 12, 2008
    i use vga billtin
  • dinasoor Apr 02, 2008
    when I clean my mother board by air after I tested it dead
    President:
  • 2,351 Answers
The beeps you heard, 1 long two short is the bios telling you that there is a problem with your video card. Normally you would remove & reseat it. Not the case with the intergrated video. When you added an AGP card you should have been able to get video. All video is controlled by the intergrated video controller. If your sure the radeon works than all that is left is the mb controller which can't be fixed. There is a slim chance you might get a PCI video card to work. Link to your board:
http://www.gigabyte.com.tw/Support/Motherboard/CPUSupport_Model.aspx?ProductID=1766
Posted on Jan 16, 2008
Packard bell imedia d3318 no vga signal
It is the video graphics card, or the motherboard, but you can sub out the ram memory one at a time as you test. It might be a bad stick of ram which would rule out the above mentioned
Apr 10, 2012 | Packard Bell iMedia Computers & Internet
No signal on monitor, vga tested and ok
Did you check your monitor with other system or individually. If it works fine in these conditions then the issue belongs to your pc.
First of all, you have to confirm that is it the problem of VGA itself or the motherboard. For this, you have to see that does system beep when you start it because system with beeps having the error and the beep sound with continuous or 2-3 beeps relate with different issues. I am going to write down the beep conditions.
1 short beep Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Mar 11, 2012 | Computers & Internet
I have recently built a new PC with an Asus P8H61-M and upon turning the PC on I am recieving no Visual on either of my monitors
Hello
If this is the first time to turn you on your computer check first the power supply of your computer if connected to their proper connector. Check your memory if clip properly in there memory slot. If you are using Video Card check it if it is properly connected to the connector. Then connect your VGA connector at the back of your computer when you have video card connect the VGA Cable of you monitor to the video card VGA output if does not have connect it with the onboard VGA output. Then press the power switch if the unit is still no visual in monitor try to search or hear a beeping sound in your computer by its on board buzzer. Find which beep you hear from your computer.
No Beep- No Power, Loose Card, or Short.
One Short Beep- Normal Post,, Computer is OK.
2 Short Beep- POST error, review screen for error code
Continues Beep- No power, Loose Card, or Short
Repeating Short Beep- No Power Loose Card or Short
One Long And Short Beep- Motherboard Issue
One Long and Two Short Beep- Video (mono/CGA Display Circuitry) Issue.
One long and three short beep- Video (EGA) Display Circuitry
Three Long Beep- Keyboard/ Keyboard Card Error
One Beep, Blank or Incorrect Display -Video Display Circuitry
Hope this help with your problem. Keep on touch in fixya
Jul 19, 2011 | ASUS P8H61M Intel H61 TX Motherboard
The PC powers up, then starts beeping, one long beep and one short beep. The monitor tries to come on but shows the DVI with no signal; and the HDMI with no signal and the VGA with no signal and then the...
the beeps codes means there is a problem with a piece of hardware (RAM, or graphics card ,etc)
I need to know the BIOS manufacturer to interpret the code (phoenix or award or AMI)
for COMPAQ it means BIOS error --and will have to reload it from a recovery cd.
for IBM it means system board failure-- need new mobo--for a beep code of 1 long and 2 short most all mean graphics card problem.
If this was helpful, please indicate so, if not , comment back so we can resolve this issue
Dec 27, 2010 | HP Computers & Internet
I just got a used syncmaster 203b monitor. I hooked it up and all I get is a black screen. I downloaded Driver whiz and hooked it up again. Still a black screen. Still get a black screen the blue light is...
Make sure that your computer unit is working. Sometimes we suspect that it is a monitor problem but usually, it is a frozen CPU set.
When you turn on the monitor, it should light the blue led and after a while, when it does not receive signal from the CPU, it will turn orange. If that is the case, the monitor is functioning well.
So what could be the problem?
Make sure that you hooked the monitor to the right VGA port. If you have an internal VGA port (built in with the motherboard) and you also have an external Video Card, you should hook it to the external VGA port and not the internal one since it is overridden by default.
Do you hear the "short beep" sound when you boot your PC? That signals a good video system. If you don't hear that beep sound (provided your PC's speakers are okay), you should open your CPU case and try to remove your memory modules (RAM). Clean the pins with an eraser and put it on.
Now, your computer should work fine and so with your monitor.
Aug 14, 2010 | Samsung SyncMaster 203B LCD Monitor
NO SIGNAL IN MONITOR
If other than the monitor signal everything else works, i.e. he disk activitiy light flickers while loading the OS or thekeyboard lights come on and then off during power on reset and no beeps other than a short one, a far fetched possibility for this error would be that the on board VGA is confused for any reason. Use the jumper 2 to reset the BIOS to factory default and try again. If the problem persist the best solution will be adding a VGA card to the AGP slot. You can find the motherboard manual on this address = http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=4&DetailID=283&DetailName=Feature&MenuID=7&LanID=0
Feb 23, 2010 | PC Chips M825G Motherboard
Blank display, machine seems to boot ok but display is blank.
If you hear your computer beep once then your system has no problem. If it does'nt show a display, try to check the power of your monitor, if it has power. Check the power cords and also the vga connection.
Nov 10, 2009 | HP Pavilion dv9000 Motherboard
When i turn on my windows '95, it runs but I hear 11 beeps. Now I've been told to only hear one. Where do I put my motherboards serial code so ican fix this? The monitor receives a signal but windows...
This beeps occur when some parts inside the CPU are not connected properly. 11 Beeps is VGA Card not properly connected or bad. Try to use another VGA Card.
And remove any PCI Cards that are connected inside and see to it only VGA Card is in to make sure the beeps or the Computer is going to run normally.
Please rate me.
Sep 02, 2009 | Microsoft Windows 95 for PC
EMachine stopped displaying video (card not working, just mobo)
Hi there
I would say it's the graphics card that's failed. You might get the same beeps for faulty card as removed card....
Take it to a shop where they can test a compatible card, before they sell you one or install one for you.
Jan 09, 2009 | E-Machines eMachines Desktop PC
Tower Beeping
As I can see the problem is not monitor but your PC if computer chasis beeping, depends on number of beeps the problem can be VGA card one long beep and 3 short or RAM if it beeping one by one short beep and finaly CPU if it continuosly beeps like police sirene. If beeps are pointing to VGA or RAM you must open computer chasis and plug out VGA and RAM and clean dust out of slots and of VGA card and RAM as well with painbrush and vacum cleaner and plug them back.
Dec 12, 2007 | Samsung SyncMaster 152N 15" LCD Monitor
Gigabyte 8VM533M-RZ (GA-8VM533M-RZ) Motherboard Logo
247 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Gbenga
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
