Question about Canon S900 InkJet Printer
Waste ink absorber almost full-Canon S900 inkjet
Like many others I have just received an error message telling me that my waste ink absorber is almost full on my Canon S900 inkjet printer. I found the suggestion from DaWeed B very useful but I wondered how difficult it is to clean the sponge pad. I can see this pad under the printer head. Do you need to remove it and wash it out? I have changed the printer head in the past which is very simple but imagine that removing the pad will be a very messy job. How easy is this? Is there much dismantling to be done? I am fairly good with with DIY jobs. I tested this pad using a cotton bud but it did not seem to be that full although the cotton bud did soak up some of the ink. It is suggested to remove the print head before resetting the printer code and I have read the suggested series of actions but when do you replace the print head, is it after action (6) Press power to set data. I did not need to reset the code after changing the Print Head but assume that I need to reset it after cleaning the sponge pad? Would appreciate any help you can give. Thank you.
  • 6 more comments
  • WindySteve Jan 22, 2008
    Had the ink absorber problem on my S820. Tried to fix it by not actually cleaning the absorber, just going through the reset procedure (I guess this may have been a bad idea?). Now, when I turn the printer on it makes all the moving around noise and then turns itself off. I can't go into service mode as it just makes the noises and turns off when I release the power button at the end of the sequence. Any ideas how I can get out of this one???
  • Beflat Mar 11, 2008
    Same problem with Canon iP2000 printer. Need advice.
  • Anonymous Jun 16, 2008
    it say waste ink absorber full how do we fix or clean
  • Michael Cullis Jul 05, 2008
    My Canon ip3000 is telling me that the waste ink pads are nearly full. I have advice on how to reset the printer so that this warning does not appear but would appreciate instructions on how to reach the pads so that I can clean them (I have also read advice on how to go about cleaning them).
  • Anonymous Jul 20, 2008
    my message is waste ink absorber is full contact the service center for the
    replacement of the waste ink absorber for my pixma ip 1500 canon printer
  • Anonymous Mar 22, 2009
    Ugh, I had the same problem. I called a Canon authorized repair center and was told because the pads are at the bottom, it takes longer to repair and I'm better off just buying a new one for the same price. It is unfortunate because this printer is fine as long as those pads are replaced. I tried rinsing them and they fell apart. Does anyone know if I can get the replacement pads somewhere?
  • c_vaquera Mar 22, 2009
    I had the same problem. I tried fixing it myself but the pads fell apart while I was rinsing them (nearly 6 years of printing). Does anyone know where I can order the replacement pads? Otherwise, Canon authorized repair is telling me it's going to cost $85/hr and they estimate it's $130 to repair. That's the cost of a new printer. I'd rather not replace since the printer is fine otherwise.
  • tomstr248 Apr 29, 2009
    Same problem. Cleaned the pads (rinsed them with lots of water,
    dried them for 2 days in the sun) and reset the counter. Printer is
    functioning since then.
    The S900 printer is high quality and fast. With the cross subsidy by
    ink businessmodel makes it very difficult to purchase a decent
    I also had the problem of crossflow between different colors and
    this is definitely a damage in the print head. Needed a printhead
    replacement to fix.
  • 60 Answers
It doesn't matter if you change (wash) the waste ink pad absorber or not, if you reset the error code il will work ok. The waste ink sponge can be full if you had a lot of cleaning done since using the printer, fact is that latest after the error appears the second time, you had to clean it.
  • 1) Figure out how to open the printer by removing the side and inside top plastic panels. Just look at the thing and use your brain. Its all pressure clipped in place, no screws (at least on the S900 and similar models, probably still the same on this years models.) Look for slots and triangles on the 960.
  • On the i960 you'll have to remove the power buttons assembly on the front- take out the two screws, unplug the internal white electro connector plug CAREFULLY, then you can undo the last clip that holds the top in place.
  • 2) No need to remove the ink cartridges in this process- so don't. The mechanism is held down in place in the case by two screws at the very bottom on the outside bottom of the metal chassis inside. Remove these screws then lift up the mechanism. It should lift out fairly easily, but remain attached by wires-- just place it on the top edge of the case.
  • 3) You'll see the blackened (from waste ink) felt pads on the bottom. WEAR GLOVES-- this is skin indelible ink, the only thing that will get it off your hands is CLOROX. Period. There are two skinny pads that sit on top of a larger pad. Note how they fit together.
  • 4) Lift the pads out and rinse out thorough in a sink until very little or no ink comes out. There's no need to use chemical or soap cleaners, just use plain water from the tap and the spray nozzle. Keep rinsing and squeezing the pads, but don't twist them like a towel, squeeze and fold in half however to really get the ink out.
  • Lay flat in the sun for a few hours to dry. Use a hairdryer to get the last bit of moisture out then replace in the printer, and put everything back together.
  • 5) RESET the printer electronics, so you won't get the stupid "waste ink tank full" message any more.
    Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520
    Turn off the printer.
    Press and hold the RESUME button, then press and hold the POWER button.
    Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
    You are now in Service mode.
    Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
    1. service/factory test printout, including ink sensor check
    2. EEPROM info printout
    3. EEPROM initialization
    4. Clear the waste-ink counter
    5. Printer model setting. (more selections beyond this- leave this alone)
    After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
    Posted on Jan 14, 2008
    The reset fixed a problem I had after cleaning the print head. A great tip for cleaning what appears to be a dead or clogged head (especially after using 'lookalike' cartidges) is to use a short piece of plastic drinking straw, a syringe, and hot water. Remove the printhead, then find a straw which will fit tightly over the ink pads inside the printhead, fill the syringe with warm water then place into the straw. Gently depress the syringe until clear water flows out of the head in several fine jets. Repeat for all 6 of the colours. Dry the the head and replace. One problem I had was that the yellow was pink/orange. What I hadn't noticed straight away was that due to a blocked head or maybe bad compatible cartridges, the red had actually syphoned back into the yellow, so no amount of cleaning would fix the problem. If you have bad colouration, might be worth checking each tank hasn't had it's colour contaminated.
    Posted on Mar 06, 2008
    Yes the pads can be taken out and be replaced or simply be rinsed and dried. They are a felt like fabric and need to be handled carefully or they will disintegrate. However there is no direct technical need to do this. If they become really oversaturated the printer will simply start to leak surplus ink out of the casing and make a mess on the surface it stands. Happened to me with an older HP ink jet before they even had counters.
    You need to disassemble the casing and take out the block with the printing mechanism. It is a medium grade DYF job, well doable for a person with average technical intelligence. I did not have a service manual - well it would be helpful if one did one and post it on the net. Next time my printer is full I will shoot a few pictures during disassembly. I have seen easier things to do and but also more difficult disassembly/reassembly jobs.
    Posted on May 06, 2009
    Hello Mediatecar I took apart my printer just on the sides and took the top off.  Im having trouble getting the mechanism for the ink cartridges out.  Im not sure what screws your talking about.  Are they on either side of the machine or on one side near the ink cartridges?  I took out one screw on the very bottom on the outside bottom, the only one I could get to and now I cant get it back and and it wasn't that one.  The ink cartridges sit on one side of the printer and I cant get to any screws near it.  Do I have to take the plastic bottom off of the printer so I can get to things?   I see a clip holding a metal dowel that the cartridges moves on.  Is this the area with the screws?  I've been looking at the thing for at least an hour and can't figure out what screws are on the very bottom of the outside bottom.  Im sorry It's not that easy for me.  I see the pads but of course I can't get to them.  Do I remove the entire plastic cover top and bottom so I just have the guts alone?  It almost looks like the bottom is screwed on the guts?
    Posted on Sep 19, 2008
    First don't bother trying to clean the old pads, I tried and they just fell apart. New ones can be purchased from Canon. It cost me $11.63 for the 3 piece set delivered. Part Numbers QA4-0901-000 replaces QA4-0705-000 (1 piece) and QA4-0902-000 replaces QA4-0705-000 (2 pieces)
    According to my email response from Canon you can call 1-800-828-4040 and ask to speak with a Jamesburg Parts Representative, or call them direct at 866-481-2569.
    (Note: I did this on 04/20/2009 and received the pads a couple of days later)
    It's pretty easy to get the printer apart by removing the smoke colored plastic from the sides/front, then 4 slots to insert a flat blade screw driver to release tabs so the top can be removed, once that's off, remove 2 screws (on each side near the rear) to be able to lift the entire print mechanism out of the way, take out the old pads, put in the new, reassemble, then search the net for how to reset the error message.
    Posted on May 05, 2009
    I have another problem! My S900 wont go into service mode so i cant reset the counter.. I followed the steps exactly and repeatedly, but I keep getting that dam flashing orange light that wont let me print. what can I do?
    Posted on Feb 24, 2010
    Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
    the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
    Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
    How to solve the problem of "Waste ink absorber is full", then show "check printer" & "5800" after continuing to use it for Canon MP150 Printer?
    Use this method with your own risk!!
    E2-2 = No paper (ASF)
    E3-3 = Paper jam
    E4 = No ink
    E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
    E8 = Waste ink absorber full, or platen waste ink absorber full
    E9 The connected digital camera / video camera does not support Camera
    Direct Printing
    E14 The Ink cartridges whose destination are wrong
    E15 Ink cartridge is not installed E16 - Ink remaining is unknown
    E16 -E19 Failed to scan head alignment sheet
    E22 Carriage error
    E23 Paper feed error
    E24 Purge unit error
    E25 ASF(cam) sensor error
    E26 Internal temperature rise error
    E27 Waste ink absorber full or platen waste ink absorber full
    E28 Ink cartridge temperature rise error -
    E29 EEPROM error
    E33 Paper feed position error
    E35 15 USB Host VBUD overcurrent error - USB
    E37 17 Abnormal motor driver error
    E40 20 Other hardware error
    E42 22 Scanner error
    Reset E27 Waste ink absorber full or platen waste ink absorber full for Mp170
    firstly download MPTOOL
    Download here
    Download manual guide how to use MPtool
    download here
    OK hope this can help
    Jul 12, 2010 | Canon PIXMA MP170 All-In-One InkJet...
    My canon MP160 error 27. I've tried the trick in service mode.. But still can't reset it.. please help me..
    E27 is the WASTE INK ABSORBER FULL error message. Try send it to service centre to do the WASTE INK ABSORBER replacementjob & waste ink counter reset job.
    May 19, 2010 | Canon PIXMA MP160 All-In-One InkJet...
    I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
    1.Waste ink absorber
    Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
    absorber. Replace if the waste ink level is near the limit (14400).
    After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
    Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
    Message" waste ink absorber"
    There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
    Check your user's manual about the procedure for changing the absorber and where to buy new ones.
    Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Absober waste ink is full. Pls help. error code
    you need to replace the absorber waste ink pad and service the printer
    Nov 17, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    Our Canon Pixma MP150 is showing an error message E5 and previously E3. Can you tell me what these mean please.
    here are the error codes for your printer
    E2 - No paper (ASF)
    E3 - Paper jam
    E4 - No ink
    E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
    E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
    E9 - The connected digital camera / video camera does not support Camera Direct Printing
    E14 - The Ink cartridges whose destination are wrong
    E15 - Ink cartridge is not installed
    E19 - Failed to scan head alignment sheet
    E22 - Carriage error
    E23 - Paper feed error
    E24 - Purge unit error
    E25 - ASF(cam) sensor error
    E26 - Internal temperature rise error
    E27 - Waste ink absorber full or platen waste ink absorber full
    E28 - Ink cartridge temperature rise error -
    E29 - EEPROM error
    E33 - Paper feed position error
    E35 - USB Host VBUD over current error - USB
    E37 - Abnormal motor driver error
    E40 - Other hardware error
    E42 - Scanner error
    Oct 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
    I am getting an on screen message
    The waste ink absorber covers the whole bottom of the machine, under the printer. It is difficult to change, and you have to get into the diagnostic mode to reset the error. A shop repair...
    Jul 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
    Waste Ink Absorber full - Canon Pixma
    Reporting solution by daweed:
    This is true with many Canon Ink Jet Printers: Eventually, you'll get an error message "Waste Ink Tank Almost Full, Contact Your Canon Repair Center". Canon is totally sly about this, and is actually a pretty ridiculous design flaw that they should be ashamed of- planned obsolescence. Anyway, don't let this problem discourage buying an otherwise fantastic Canon printer.
    This problem will also be indicated by flashing orange lights on your printer. Different flashes for different models.
    LOOK IN YOUR PRINTER MANUAL TO KNOW WHAT NUMBER OF FLASHES INDICATE. In any case, your computer printer software will also tell you exactly what is going on.
    You need to do this after you get the WASTE TANK ALMOST FULL message and the printer continues to work, but BEFORE the WASTE TANK FULL message and the printer completely stops. I think. ;-)
    Here's the fix:
    The waste ink take is actually just a felt pad that sits under the printer mechanism inside the case and absorbs the ink from your cleanings. From what I gather, its both a time consuming and expensive proposition to take to Canon to fix. And they won't tell people how to do it themselves. Well, I WILL. And this works.
    Remember of course, you've got to cycle the cleaning process a huge amount of times to get this to occur.
    But when it does, there is a fix-it-yourself solution that is both safe and effective for the printer, and free. You have to be slightly mechanical to do this. If you get this message and you've never used a screwdriver and are all thumbs, well, Canon gotcha. But give it a shot even then, or give it to someone halfway coordinated to do this for you.
    You may RESET the printer code first if you like or do it after you clean the pad
    In some cases you may need to REMOVE THE PRINT HEAD FIRST or the reset code will not work. This was true of the S900 and i960 so, remove the print head first before doing this reset.
    This is the correct code for the S and I (like i960) series of printers. (M series below this)
    1) Power off printer
    2) Hold RESUME button then press and hold POWER. (The beeper MAY sound once, or may not depending on your model.)
    3) Hold POWER and Release RESUME.
    4) Press RESUME twice then release both POWER and RESUME buttons.
    5) When the indicator lights steady, press RESUME 4 times (for the S900, 3 times for the 8200 apparently).
    7) Print away!
    For other codes for other printers and more info go here to this big forum (but try the above first) Fix Your Own Printer Generally many of Canon's models use exactly this same code, the i models use the same code, all the s models use the same code.
    I did this and it works fine! No more error messages and so..."
    Mar 13, 2008 | Canon PIXMA iP90 Mobile Printer
    Canon S900 InkJet Printer Logo
    5,594 people viewed this question
    old marine
    old marine
