Question about HP LaserJet 3055 All-In-One Printer
Scan To Button is not working over Network PCs
My 3055 is working fine. but only problem is net work users can not scan using scan to Button.even the Destination is shown on the AIO display.but after some time it display error msg "Unable to connect pc"...i ve also disable windows firewall.and we r not using any other firewal software,.using USB port..its ok..but that is useless for me....cuz i need it over network for my office usage,,,,pleas tell me if this devices is capable for this thing.cuz i ve tried 2 different devices...thanx.
  • Rizwan Ullah Jan Jan 25, 2008
    My 3055 was working fine over the network for about 8 months while using the same scan button. But some how it has started to give the same error. I have trid different things but problem is still there. need a solution.
  • aali12a Jan 29, 2008
    nice.. bt my problem that device has some firmware problem. so i ve replaced that already and now its working fine. even im using Symantac Corporate Edition Antivirus with firewall in our office,(but it might be a problem)
I uninstalled the Norton Antivirus from my PC. Now it is working fine.
Posted on Jan 29, 2008
The HP 3055 network printer, connected to 3 dell inspiron laptops doesn't says it's offline, even though the screen on the printer says "ready." I tried adding a printer profile and...
Check the IP of the printer, it should be manually assigned, if you are not confirmed,
  1. Press menu/enter .
  2. Use the or the > button to select Reports , and then press menu/enter .
  3. Use the or the > button to select Config report , and then pressmenu/enter .
  4. The printer exits the menu settings and prints the report.
Try re installing the printer software from the cd, or download the full version from the links below for your area
HP LaserJet 3050/3052/3055/3390/3392 Asia Pacific Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 Eastern Europe Full Software Solution
HP LaserJet 3050/3052/3055/3390/3392 North America/Western Europe Full Software Solution
(The full software solution provides print, fax and scan functionality. This software solution is the same solution as the Version 4.0 in-box CD that came with your HP LaserJet 3050/3052/3055/3390/3392.)
You can download Printer manual from the link below
Printer Manual
If you require more assistance in this regard feel free to reply to this post
Best regards-BA
Jan 20, 2011 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 scan over network. How does one set the Laserjet 3055 up to scan over the network? I'm running XP professional.I set the printer up through Control panel - printer and faxes - Add a...
If you have installed the printer using Add printer and faxes then you have just install the printer drivers which will allow you to print over the network.
However if you want to scan over the network than you have to install the complete software of the printer .
If you do not have Software CD than you can download and install the software fom Link below.
Thanks and Regards
Neeraj Sharma
Jun 29, 2009 | HP LaserJet 3055 All-In-One Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
I have a HP LaserJet 3055. I bought it when I was using XP but I now have a new computer using Vista. I have downloaded and installed from HP the installation setup program for Vista - followed all the...
As i understand that you u r able to print and copy fine which ensure that there is no issue with the connectivity and scanning device.
However next troubleshooting comes in picture is software as per you have mentioned that yoiu have downloaded and installed the complete software couple of times still the issue persists.
In that case we need to Programn Scan to option in the printer software and on your all in one.
HP LaserJet 3050, 3052, 3055, 3390 and 3392 AiO Printer series - How to Program the Scan To Button and Create New Destinations
The Scan To button must be programmed before it can get used. However, some destinations are programmed by default if the all-in-one is directly connected to the computer.
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above step
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
Dec 21, 2008 | HP LaserJet 3055 All-In-One Printer
Scanning from the network
Dear Friend,
Install the printer driver on your computer and than download fix scan utility from After installing fix scan utility You will be able to scan.
You have to do the same on every computer from where you want to scan.
Under Trainee
Dec 17, 2008 | HP LaserJet 3055 All-In-One Printer
HP laserjet 3055 all in one Scan problem
which OS are u using ?
try uninstall and reinstall the driver from the cd itself
Oct 31, 2008 | HP LaserJet 3055 All-In-One Printer
Unable to set up scan feature.
First question is do you have universal send on the copier. If you have a Send tab on the touch screen you have it, if you only have a scan tab you do not.
With the send tab you can set the device up to scan, create a file and send it to a network destination. With the scan button you have to install the color network scan gear program on your computer.
This software is just a twain driver that interfaces with the copier through the network. It does not give you any software to drive the scanner, it only gives you a choice for the copier in your list of scanners. You have to use some other program (i.e. Acrobat standard or MS document imaging) to drive. After you install it open it up, let it discover the machine on the netowrk and close it. The interface only points to the device on the wore, it is not directly used for scanning.
If you have a send button I would recommend for your situation that you scan to a shared folder on your desktop. First you create the shared folder, and make sure you can see it from another PC on the network. If your other PC's can't see it the copier won't either. Create a user on the computer with the shared folder for the copier to use. Set that users password to never expire.
Press the additional functions hard button
Press the touch screen button for address book
Add an address to address book # 1
The type of address will be SMB
Register a name for the address (Scan to PC is fine)
there should be a browse button on the screen, press it
Use the up and down arrow to browse up and down the tree
when you see your network browse from the domain to the PC you are scanning to
When you try to expand the PC you will have to enter in the user and password you created for scanning
point to the shared folder you will use
OK your way back out to the user screens
Have fun scanning
Aug 20, 2008 | Canon imageRUNNER C3220 Color Copier
Does HP LJ 3055 printer scan over the wireless network?
Scan over wireless network is not supported with this printer. You can try set it up and get scanner to work with usb and then change port from usb to HP standard TCP/IP for the device, but I don't think it will work.
Apr 08, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 Won't Scan
My hp 3055 is working fine on the network bt problem is "SCAN TO" Button is not being configured with the PCs.It displays all the PC names bt not able to scan. it diplays an error "Unable to Connect".
can any body help me out of this matter
Dec 27, 2007 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
175 people viewed this question
Ben Johnson
