Question about Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276... went in sleep mode.
Laptop was hanged after i try to switch off through alt ctrl and del keys but nothing . after i switchoff laptop throgh maim on/off button . now laptop is in sleep mode . now when i an trying to switch on only power on indication is on if it is runing on battery . when i am connected AC then AC,Power on and battery indication are up . please help me
  • zestize Feb 21, 2008
    my a135 is also in some sort of sleep mode what should i do
  • 89 Answers
Try pressing power button once. Does Windows logon screen come up?
Posted on Jan 14, 2008
6ya staff
SOURCE:
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
Apr 03, 2015 | Computers & Internet
Toshiba satellite A135 At the power on disk read error comes on & says press ctrl+alt+del to restart, but after restarting, the same reading comes on!
Disk read error is, most likely, a bad hard drive. Seeing this message means that the operating system (Windows) didn't even get a chance to load before running aground. This model uses 2.5" SATA drives and 80G is the smallest size ever sold. You can probably get a replacement drive (new or used) locally or thru eBay or Amazon, and they should be pretty cheap (new ones should run for about 20 cents to 25 cents per gig. That'd be your best bet.
Aug 31, 2011 | Toshiba Satellite A135-S2276 Notebook
I have had the computer for over three years. it is now asking for a password when i turn it on..can you help
reboot your system and use the following steps 1.press ctrl+alt+del two times 2.then in username type administrator 3. password leave blank 4. press enter 5. then in control panel remove the password thank you to ask question don't forget to give ration&vote
Dec 27, 2010 | Toshiba Satellite A135-S2276 Notebook
Forgot password for toshiba laptop model ps210e.can i unlock?
Restart your Laptop and press F8 as soon as logo displays and go to safe mode. There you will get a warning message and click on Yes. Then Press ALT+CTRL+DELETE and enter user name as Administrator and log in without entering password. It will log in. Normally Admin accounts does not have passwords. If its not working please revert. we will send the software to break the passwords.Hope this helps!
Feb 19, 2010 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 PC Display screen
Maybe it is just disabled they can be set to... Screen on Laptop ONLY... External Screen ONLY, Both Screens on together. Try to find the keys that toggle those modes? in your manual.
Feb 03, 2010 | Toshiba Satellite A135-S2276 Notebook
Keeps freezing
starting the machine without a power cable isnt bad, especially since its a laptop and is made to run on battery power. as for the freezing, if it was dropped alot then something could have come loose meaning it mite not be covered under warrenty. i would just try to get it fixed at the place it was purchased at.
Jul 20, 2009 | Toshiba Satellite A135-S2276 Notebook
TOSHIBA A135-S2386- I HAVE AN ERROR WHEN TURNING ON MY LAPTOP
You most likely have a faulty hard drive, especially if it is making a clicking sound.
You wil need to purchase a new hard drive and install Windows again with the Toshiba Recovery CD.
Jan 21, 2009 | Toshiba Satellite A135-S2386 Notebook
Rewaking my toshiba laptop
hold down the ALT CTRL DEL Key If that don't work hold esc for 5 seconds or hold down the power button for 10 seconds
Sep 06, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba
windows vista is know for having glitches and bugs of high intensity... also BSOD (blue screen of death)
mah suggestion would be to hit F8 which will take you into a boot selection. select safe mode and it should take you into your OS without the issues of booting
from there troubleshoot your computer and it should fix the problems for you
Apr 07, 2008 | Toshiba Satellite A135-S2276 Notebook
Toshiba satellite A135-S4727 PC
First F8 and choose "last known good configuration".
Second, there is a small button atop the mousepad which turns the mouse on and off; might check that.
Good luck
Oct 15, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A135-S2276 Notebook Logo
463 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
