Question about Bose 3·2·1 II System
BOSE 3-2-1 -
Will not play DVDs corrrectly ~ in fact, I wish the unit had a tracking wheel to slow down the vertical scrolling of the images...how can I fix this problem? Is the Laser off track? Should I replace the optical cables (from the unit to the TV)?
Tjanks...
  • Lewis James May 11, 2010
    Check the bottom of the media centre - is this an AV321 or AV321 II? How is this connected to your TV? What brand is your TV?
    This sounds like either a loose cable or set up issue.
A little more background data...the 321 player has been working properly for years...and just recently decided not to play an image without scrolling north and south.
To answer the questions above, the unit is an AV321; connnected via optical cable (for the image) to a Sony LCD TV.
Posted on Jan 16, 2008
DVR620KU From the HDMI connector, how to get non-pinched vertical HDMI images on the TV monitor and on the DVD. Recorded DVD's have been Finalized
Using a DVD-RW disk, try ALL different recording settings even if they don't seem probable and record a sample. If output is correct with all BUT the HDMI-cable, go through ALL picture format settings on the TV when a HDMI-cable is used. Different discs and HDMI cables don't have anything to do with this. I'm still chewing on this...
Dec 15, 2014 | Toshiba DVR620 DVD Recorder/VCR
I HAVE A TOSHIBA VCR/DVD COMBINATION MACINE. THERE IS NO TRACKING BUTTON. iS THERE A WAY TO AUTOMATICALLY ADJUST THE TRACKING??
Usually VCRs do not offer specifically labelled tracking buttons as such, however they may incorporate tracking into their channel UP/DOWN buttons, both on the front of the main unit and/or remote. Some brands also offer V-LOCK (vertical lock or still image adjustment) (in pause mode during playback) to stabilise the image, reducing vertical jitter, which again can be adjusted as required using the same buttons as used for tracking. In most cases, pressing both CH UP and CH DOWN together while the tape is playing should centre track (revert back to auto tracking) the unit.
I am sure if your VCR has channel buttons on it, try pressing either one while a tape is playing. See if it affects the tracking at all. If it does, press both buttons together for 5 seconds or so, then release - auto/centre tracking takes over.
It costs nothing to try this, and it won't hurt your machine or your tapes.
Apr 20, 2011 | Toshiba W522 VHS VCR
Cd player starts, but stops play by 2nd track
Sounds like tracking motor and/or gear problem!
Check for a small crack on the tracking gear.
Parts not avalible from Bose though, they'll only
fix as a "flat rate"!
Apr 12, 2010 | Bose Acoustic Wave (32022) 5-Disc CD...
I have a Bose 321, 5 years old. It has started dropping the dialogue track on DVDs but the music track still plays. It is tempremental about the DVDs it plays, often reads bad disk or the DVD freezes. ...
BOSE offered a software upgrade to address the issue of freezing and not playing certain disks. You can get that right from BOSE by calling tech support. I am not sure that that will help with the newest symptom though (the humming).
Sep 07, 2009 | Bose 3 2 1 GSX System
Cannot stop shuffling
You need to go into your Play Mode ssettings and select "Repeat All" to turn off this feature:
Play mode
You can set your player to play music tracks randomly (Shuffle All ) or repeatedly (Repeat One or
Repeat All ).
1. From the main menu, select Settings > Play mode.
2. Use the VERTICAL TOUCH STRIP to scroll up or down the options.
3. Press § to select an option.
4. Press § again to deselect an option.
Mar 14, 2009 | Philips GoGear HDD1830 MP3 Player
Steering problems with my 98 Chevrolet k1500
There is a unit in the steering column called a steering speed sensor. Replace it and all is well. I had to do it on my 1998 Chevy at 140,000 miles and all is good. Have since done it on another 1500 and it corrected its problem too.
Jan 21, 2009 | 1998 Chevrolet K1500
Format unsupported
Format unsupported simply means the unit can not read the disc. The problem is either the disc or the player.
Contact Bose technical support if you are sure the discs are good. 800-367-4008
Jul 31, 2008 | Bose 3 2 1 GSX System
No vertical hold
Do you have it hooked up to a VCR? If so, it's the Macrovision kicking in.
Oct 24, 2006 | Protron PD-800 DVD Player
Bose 3·2·1 II System Logo
148 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
