Yes mirrors are sold as an entire unit,unless you are saying that the paint is chipped then you can have a body shop repair the chip and it will look as good as new!
If you have to purchase a new mirror,search the internet for Mazda OEM parts and you will find a good deal out there and get your baby looking great again.Good luck!
Have a body shop give u an estimate car is to new to get a salvage one, or dealer is ur other option---or u can live with the chip
Steps to follow
1.Buy the replacement mirror, making sure that it is an exact match to your vehicle's make, model and year. You can order it through your dealership. If you'd like to save more money, you can order a mirror online or buy one from a junkyard or a salvage yard that sells auto parts.
2.Roll down your window and shut your vehicle off.
3.Disconnect the battery's negative cable. This is important, because there is a risk of electrocution if you do not perform this step.
4.Take off the interior door panel by using your pry tool to remove the trim pieces. Then use the screwdriver to remove the screws holding the panel in place. You may have to remove a corner trim piece before the door panel lifts off.
5.Unplug the wiring harness if you have power-controlled mirrors. If you have manual roll-down windows, skip this step.
6.Take out the mirror bolts with either a socket wrench or a nut driver, so that you can remove the entire mirror assembly from the car.
7.Separate the actual mirror from the mirror assembly. Use a torx driver to extract the screws, and then pry the plastic tabs on the backing until the two pieces separate.
8.Attach the new mirror to the assembly by snapping it onto the backing with the tabs.
9.Put the new mirror, attached to the backing, into the mirror assembly.
10.Reverse the steps to reinstall the entire mirror assembly back onto the vehicle.
