Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
LCD Tv turns off automatically within few seconds
I have a sony LCD tv it turns off automatically within few seconds.Can anybody help in this problem.
  • Dave Bies
    Dave Bies May 11, 2010
    Is the red light blinking on the front of the tv. If so how many times does it blink? It will usually blink so many times then stop then blink again. The blink code will help to determine the problem.
It is a software problem sony was fixing for free untill 03/01/08
You can unplug your set from the outlet for 30 seconds and it will work fine untill several hours of use acrue again. Found this out on the sony website. hope it helps.
Posted on Mar 11, 2008
I have the same problem but i havent check to see how many times the red light blinks its not the lamp light either tv turns off after 5 seconds
Posted on Mar 08, 2008
  • Sony Master
  • 8,617 Answers
If you would like help in troubleshooting your set. Go to the enclosed link. They offer your service manual and unlimited chat support to help you repair yoir set for 10.99. Just click on the manufacturer of your set and you will see your manual. Then click on the contact us link and provide your email address and thy will email your manual and instructions on how to obtain the chat support. I am one of their techs.
http://servicemanuals.vstore.ca/
Posted on Jan 14, 2008
Sound comes and goes constantly on a sony tv model KP60XBR800
About 27,600,000 results (1.16 seconds) Search Results
    Sony TV sound issues - Forums - CNET
    www.cnet.com > Forums > Sony
    CNETJun 11, 2015 - I have a Sony Bravia KDL52V5100 LCD TV & after only having since May 2009, I am now having sound ... I'm going to purchase a new HDMI cable to see if that might solve the sound cutting out problem. ... Has anybody come across problems like these 2? .... Sony is and always has been one of the best TV's on the market. Netflix app on Samsung Smart TV audio dropping out
    Jun 11, 2015
    sony bravia automatically turning off and on
    Jul 7, 2012
    Clicking noise after powering off sony kdl-40v3000 lcd hdtv ...
    Oct 25, 2007
    More results from www.cnet.com
    A loud humming or buzzing noise is coming from ... - SONY
Jan 05, 2016 | Sony Televison & Video
Picture went out and red light on the front by power button is blinking. When I turn TV on I can hear sound but no picture,, then TV turns off automatically after a few seconds.
It seems problem with low screen voltage to three picture tubes in this rear projection tv.
If standby light blinks 5 times after three seconds long pause then adjust screen volts of each picture tube to solve this issue.
Screen volt adjustment requires expertise and job of professional so please call local tv repairman to help you.
Thanks.
Feb 27, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
Within seconds of turning my sony bravia it automaticly goes to standby
Check the lamp, if its ok you can contact sony, some of these s2000 series tvs have an extended warranty until 2010. good luck Julio at Millenium tv - (702) 736-1091 milleniumtvsvc@gmail.com
Jul 19, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Screen automatically goes black after a few minutes
Lamp in TV got weak and TV needs new lamp.
Lamp replacement procedure is written in instruction manual and buy should buy Sony original lamp from Sony Accessories Store for your Sony TV.
Apr 30, 2009 | Sony Grand WEGA KDF55E2000 55" Projection...
Tv cuts off and green light flashes
If your set was manufactured around July 2005, you may need a firmware upgrade to solve this issue. On the Sony website you can enter your model # and serial # to see if you TV is affected. If so, it is easy to have done and may be free from Sony. It sounds like the issue they described in the writeup on the required formware update. I had mine done within few months of when i bought it (purchased in Dec 2005) and it has been working flawlessly since.
Donnieboy999
Jul 19, 2008 | Sony KDF-E42A10 42 in. LCD Television
TV shuts off within 5 seconds of turning on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Feb 15, 2008 | Sony KDF-E42A10 42 in. LCD Television
PS3 Hi Def to normal tv
press front power switch to turn it on and hold for a few seconds, it will beep a few times and turn off automatically. now everything you setup for hd tv will be defaulted to normal.
Dec 12, 2007 | Sony PlayStation® 3 (60 GB) Console
Lcd tv shuts down by its self
All you need to do is remove the back cover, then remove the metal cover that covered the power supply. Watch tv w/o cover, it won't shut down again. Try it and post here if it works.
Sep 12, 2007 | Televison & Video
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
1,210 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
