Question about Hitachi Deskstar T7K500 320 GB ATA-133 Hard Drive
Installation setting hard drive to master . booting from disk, error reading disc appears
  • guitarist Mar 02, 2008
    thanks for the help. I have been using that drive for storage, but i will now try your solution. Thanks
    Problem Solver:
  • 7 Answers
What ATA setting does your computer support? Hitachi makes a program you can drop the ATA settings down on your drive and that might fix your read error problems. It's called Feature Tools and it is on there website. http://www.hitachigst.com
Posted on Mar 02, 2008
How do I fix error codes pxe-e61 and pxe-mof
The fix will depend on exactly what is wrong. The messages mean that your computer can't read the hard disc and find a boot OS. The drive may have failed, the cable might be loose, or the MBR (masterboot record) is bad.
First make sure that you do not have a CD/DVD in your optical drive, a floppy in your 3.5" drive or an external hard drive attached to one of the USB ports. (The computer may be trying to boot to one of them.)
Next press F2 when you turn on the computer (press repeatedly). This will let you enter the BIOS to set the disc boot order. (Check that the hard disk is listed first. This also indicates that the computer sees a hard drive in the machine.) If you get the error message again, try the entire procedure again from turning on the computer.
Next try using the appropriate Windows install/update disc to repair your system.(The Dell 4600 came with XP and you need the correct SP on the disc. If you kept up on the updates, it should be SP3.) Put the CD in the optical drive then restart the computer. Press F12 repeatedly to get the boot selection menu. (The same repeat routine may be needed if you miss the timing.) Use this disk to enter the Recovery Console and attempt to repair the Master Boot record.
Use the directions here: http://support.dell.com/support/edocs/systems/dim4600/en/4600i/sm/index.htm to check if the cable is connected properly. You will need to open the case.
This Dell came with an IDE hard drive. These often have a jumper that indicates the boot order. The jumper must be set to master or cable select and be attached at the master position on the IDE cable. This is the connection at the very end of the cable. The IDE cable can come loose from the motherboard, as well. You can also try a different cable.
The final option is to replace the hard disc. Unplug the old hard drive from the IDE cable first. You'll need the Windows install disc and then to reinstall all of your drivers and programs. Move the bad disc to the slave position on the IDE cable. See if you can salvage any of your files from the hard drive. (Sometimes, putting the drive in a ziploc bag and placing it in the freezer for several days will let you read the disk when you put it back in the computer.)
I hope this helps.
May 03, 2012 | Dell Dimension 4600 PC Desktop
My laptop wont start up, It says "system disc or non system disc error, replace and press any key.." why? :(
you have it set to boot from cd so when you startup the computer it attempts to read the cd and than boot an operating system for you either remove the disk or enter your bios menu and set your boot order to negate the cd drive
Oct 25, 2010 | Computers & Internet
Disk Read Error upon startup
It is likely a bad hard drive. You can boot the system to a CD or DVD if you have a windows disk, this will somewhat check all other functions, and will not boot to the hard drive. You may have to go into the BIOS and switch the boot order to have the dvd drive before the hard drive. This may help troubleshoot. Some OS dvds will also have system diagnostics on them to help you troubleshoot, has to be a bad hard drive though. When you buy a new one, just see if you have the large cable (IDE 20-40 pin wire) or the small cable (SATA narrow 1/2" wire) going to the motherboard. Buy the corresponding drive and install. You may have to purchase windows discs from your manufacturer.
Jun 03, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
Error Loading operating system
CHECK your bios setting first, and make sure, in hard disk boot priority section, your external hard disk is recognised and set as the first boot device. YOU NEED TO BE SURE YOUR BIOS SUPPORT BOOTING FROM USB FIRST.
IF the hard disk is there u can do several stuff to boot it:(unplug any internal hard disk first, TO MAKE BYPASS CONFLECT ISSUES)
- make sure the drive is seen, whene you are trying to install windows.
- go to recovery console in the setup disk, and reset you master boot record, type:1- fixmbr (or fixmbr c:) >>> WHERE "C:" IS YOU WINDOWS INSTALLATION DESTINATION!
2- fixboot
and then restart and try again......
- try to download plopboot manager, burn it to disk, and boot it, try to load your hard disk frome there.
- install any boot loader, like lilo or grub if you are familiar with, they can boot any os you like!
You can always install Grub to your Master Boot Record of the initial internel hard disk, **** you need to have basic knowlege on how to edit the menu.lst inside grub folder, and basic knowlege of linux partitioning schemr, becoz GRUB need to be installed there as well, **** whene you are already familiar with its use, you can boot any thing you like, even with a friendly boot menu at startup alowing you to choose the option you want to boot.
N.B: make sure you have googled and read about grub, and how to install in, if u have a windows installation on the internal hard disk and afraid to loos it, there is a tool called super grub disk, google for it and download it, it can be installed from windows, and it can automaticaly load windows ntldr/boot.ini.
dg luck.
Dec 31, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
It is sayingpri master disk s.m.a.r.t.status bad back up and replace . and wen i try to boot it is saying fileootcd status;oxc000000f.info an error occuredwhile attemting to read the boot configuration...
This error is indicating a physical problem with your hard disk drive or occasionally with the hard disk drive controller.
The S.M.A.R.T. status error means that there is a physical problem - not a windows installation problem.
The second error you are getting during start-up is secondary the the hard drive problems. The system cannot read some of the information on the hard drive. The area is cannot read contains necessary operating system information.
You need a new hard drive for this computer. If it is still under warranty then call or email Gateway support so that they can send a replacement drive. If not then you will need to purchase a new drive. If a new drive does not solve then problem then the problem is on the motherboard.
You did not specify which model laptop this is. Most of Gateway's laptops have built-in cdrom drives, but a few do not. The systems that do not will accept an external cd-rom drive, and should have been shipped with an external cd-rom drive so that it can be reloaded. You will need a cdrom drive to load your operating system onto your new hard disk drive once you replace it.
Dec 28, 2009 | Computers & Internet
Sony vaio pcv rx680g desktop
First, ensure that the bios is reading the hard drive and that the hard drive is part of the boot sequence. If you have a known working drive and the drive is not been read by the bios, you will get the Disc Boot failure error because windows resides on the disc which the bios cannot access.
Secondly, if the bios is reading the disc then ensure that the disc is set as part of the boot sequence-preferably the item after DVD drive should be Hard Disc in the boot menu.
If both of these items are in correct order then you could have a bad boot sector on the drive. Run a C:Chkdsk. If no bad sectors are found try C:Fixmbr-ensure that the Windows installation disc is in the CD/DVD drive when running Fixmbr.
If that fails do a clean install of windows.
Good Luck
Sep 28, 2009 | Sony VAIO Digital Studio PCV-RX680G...
Laptop won't boot up
In set up, set your your optical drive to be the first boot option and put your restore disk in the drive then reboot.
This should then read from your disk before trying to access any hare drives.
Feb 23, 2009 | Sony VAIO FR130 Notebook
NTLDR is missing
Fixes for NTLDR Errors
  1. Restart the PC. The NTLDR error could be a fluke.
  2. Check your floppy and optical (CD/DVD) drives for media. Often times, the "NTLDR is Missing" error will appear if your PC is trying to boot to a non-bootable floppy disk or CD/DVD.
    Note: If you find that this is the cause of your problem and it's happening a lot, you might want to consider changing the boot order in BIOS so the hard drive is listed first.
  3. Check the hard drive and other drive settings in BIOS and ensure they are correct. The BIOS configuration tells the computer how to use a drive so incorrect settings can cause problems, including NTLDR errors. There is usually an Auto setting for hard drive and optical drive configurations in BIOS which is usually a safe bet if you're not sure what to do.
  4. Restore the NTLDR and ntdetect.com files from the Windows XP CD. Restoring these two important system files from the original Windows XP CD may do the trick.
  5. Repair or replace the boot.ini file. This will prevent the NTLDR error if the cause of the problem is a boot.ini file that is not configured properly for your Windows XP installation.
  6. Write a new partition boot sector to the Windows XP system partition. If the partition boot sector has become corrupt or isn't properly configured, you may receive the "NTLDR is Missing" error.
  7. Repair the Windows XP master boot record. NTLDR error messages may also appear if the master boot record is corrupt.
  8. Open your computer's case and ensure that the cable that connects the hard drive to the motherboard is firmly in place. If this does not resolve the issue, try replacing the cable. NTLDR error messages could be caused by loose or malfunctioning IDE cables.
  9. Update your motherboard's BIOS. Occasionally, an outdated BIOS version can cause the "NTLDR is Missing" error.
  10. Perform a repair installation of Windows XP. This type of installation should replace any missing or corrupt files. Continue troubleshooting if this does not resolve the issue.
  11. Perform a clean installation of Windows XP. This type of installation will completely remove Windows XP from your PC and install it again from scratch. While this will almost certainly resolve any NTLDR errors, it is a time consuming process due to the fact that all of your data must be backed up and then later restored.
    If you can't gain access to your files to back them up, understand that you will lose them all if you continue with a clean installation of Windows XP.
  12. Finally, if all else has failed, including the clean installation from the last step, you're most likely facing a hardware issue with your hard drive. Replace the hard drive and then perform a new installation of Windows XP.
Jan 17, 2009 | Computers & Internet
Boot up problem..
i dont think the internet files had a difference.
a disk read error mean thateither you have a floppy in your computer or the hard drive is corrupt. that cannnot be fixed so i recomend getting a new hard drive.
Jaddude
Jan 07, 2009 | Dell Latitude D600 Notebook
Hitachi Deskstar  T7K500 320 GB ATA-133 Hard Drive Logo
155 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
